Leaking from base of spin tube area of GE washing machine
  • 176 Answers
Check the all hoses
Posted on Sep 01, 2010
My GE washer leaks water during spin cycle only, seemingly from bottom of valve(?) where water hoses hook up, hoses look to be in good shape, only a year or so old.
If it is leaking at where the drain hose comes out of the wash machine, make sure the plastic spider clamp is seated securely in the groove on the drain hose. If that's not it, then, yes, you'll need to open up your washer to gain access to the inside of it. I don't know which model GE wash machine you have, but most of the GE top loaders can be opened by following the instructions in this youtube video:
Oct 19, 2014 | Washing Machines
Washing machine
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 04, 2008 | GE WJSR2070B Top Load Washer
How to fix a GE Topload Washer leaking down the inside center of the machine back pannel?
check the tube that goes from near the bottom of the tub up to the level control switch
Jul 09, 2017 | Washing Machines
I have a GE washing machine the model number is WHDSR209DZWW. It will not agitate during the wash cycle. It will also not stop filling with water during this time. The water leaks out of the bottom. The...
You need to check to see if the pressure tube and switch are ok this is how the machine detects it;s water level. Eg the tube may have just popped off or there could be a hole in the Pressure tube. Any questions feel free to ask Cheers
May 15, 2009 | GE WDSR2080D Top Load Washer
Washer leaks under tub
Can you see exactly where the water is coming from? When the machine is spinning and you lift the lid does it stop in less than four seconds? Does the water come from the side of the tub near an area where a tube attaches? Is there water staining down the side of the tub and an area near the top shows leaking? Is there rust and oil stains at the base of the gear case? Please blog back, SearsTechToo.
Oct 06, 2008 | Washing Machines
GE profile washer
Thanks for the questionOn a ge washer theres a over flow tube located at the back left side Sometimes if you use a high sudzing detergent , it could leak not to much to worry about just change detergent to a low sudzing one THanks for the question The appliance doc
Sep 03, 2008 | GE WHRE5260E Top Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Washing machine doesn't respond to the low, medium or high water settings and keeps filling. Spin and drain cycle works. Won't stop filling and doesn't go into the wash cycle.
My GE WSM2780DAWW stack set dryer and washer was encountering the same problem (water kept filling up not stopping). I saw this page, but the SOLUTION described didn't really draw a picture for me.
Here's how I fixed the leaking washer. Sitting in front of the washer I removed two small screws on the bottom left and right of the front panel. Then sliding the front panel DOWN, it comes off. This allows a view into the machine. Around the LEFT side of the wash basin you will find a white tube. This tube is about the diameter of a pencil. My tube was not attached, and when the wash basin filled up past the point where it should stop, water came out. Reaching around the side of the wash basin with my left hand I could feel where the white tube was supposed to connect properly. Then I attached the white tube. This fixed the problem.
I left the front panel off for a day to make sure it didn't continue to leak and also for the area to dry out.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_6ddd78f70d3cfe52
Jun 17, 2006 | GE WSM2780DWW Unitized Spacemaker Washer...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
