Question about HP Photosmart 475 InkJet Printer
Power loss loss of during shutdown. could not switch back on.
    Genius:
  • 3,587 Answers
Hmmm..check the power supply cord being installed correctly, eh?
Posted on May 09, 2008
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Screen goes black but audio still works fine.
It sounds like the vertical output IC may have some solder issues. Often bad solder in the vertical circuit will cause the CRT'S ( Picture tubes) to shutdown for protection during loss of deflection and audio will continue to function. I would inspect the solder on the Vertical IC first.
Jun 22, 2010 | Zenith R56W36 56" Rear Projection...
On start, I get a "No bootable device--insert boot disk and press any key" message
This means that the Boot sequence part of Windows has becoming corrupted. If the FIXBOOT boot command does not work for you during the repair option, when inserting your system discs, then you have no alternative than to reinstall Windows.
If there is data on the drive that you need, then I would advise getting a USB to hard drive adapter and transfering the files to another PC before reformating.
This fault usually occurs during incorrect shutdowns,, hard resets, or power loss whilst the computer is switched on.
Mar 07, 2010 | Compaq Presario 700 470024-192 Notebook
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
Abrupt loss of picture during DIRECTV-source
Ur main video backllight board it dying,must be replaced.
Oct 14, 2009 | Fujitsu Plasmavision PDS-4209 42 in....
Netbook 2oo 70%battery power loss wheb switched
Toshiba has many ways to log off, you need to make sure that you click start and click on the right arrow and then shutdown, as it sound that your computer go to hibernation or sleep mode and not totally off.…Hope that help you and please do not forget to rate my service to be able to improve on it and help everyone
Sep 19, 2009 | Computers & Internet
Loss of power
First thing I would check is your regulator, a small rectangular box, that regulates electrics.
Dec 20, 2008 | 2006 Harley Davidson FXDCI Dyna Super...
Tv Powers up and immediately back off
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB
Aug 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
What do you look for when the tv want stay on?
Feb 05, 2007 | Mitsubishi VS-5043 50" Rear Projection...
HP Photosmart 475 InkJet Printer Logo
70 people viewed this question
Seeker5211
Seeker5211
