Message appearing on windows Error code 4400:011A Msg. SCSI_0_000_Disk_0_:_compact_flash_target not ready
  • 808 Answers
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout registry cleaner it will solve ur problem
Posted on Sep 01, 2010
DELL INSPIRON 1750 stuck in start up loop error code OFOO:
HI,
Could be you just need to update your drivers, before you take it apart try this:
Follow the steps mentioned below to check what Updates are installed on the system.
See which Windows updates are installed
http://windows.microsoft.com/en-US/windows7/See-which-Windows-updates-are-installed
Error Code 0F00:133C
Msg: DISK- No suitable disk media is present.
This error message is encountered when you probably have a bad video card and/or flaky RAM.
Step 1:
Unplug all the External devices such as printers, scanners etc and check whether you encounter this error message.
Step 2:
I would suggest you to install the latest drivers for the Video card from the dell website and check
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
For further reference check the article mentioned below.
Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Step 3:
Iwould suggest you to configure Chkdsk to run when the system restarts next time. Follow the steps mentioned below to configure Chkdsk to run when the Windows Vista restarts next time.
a.Click Start and then Run.
b.In Open, type cmd and then press ENTER.
c.Use one of the following procedures:
Procedure 1: To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
Procedure 2:To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note: If one or more of the files on the hard disk are open, you will receive the following message:
a.Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
b.Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
Procedure 2: To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
I got this information @ 0F00 133C Error Code No suitable disk or media is present written by Thahaseena M, Microsoft Answers Support Engineer.
Feb 16, 2014 | Dell Inspiron Computers & Internet
Error message stop 0x00000024
which operating system ?
If you get the Windows blue screen, you can determine which stop code you have and determine what you need to do in order to get your computer back to working correctly.
First, make sure that you have this error code - Stop 0x00000024 or NTFS_FILE_SYSTEM. This message shows that a problem occurred within Ntfs.sys, the driver file that allows the system to read and write to NTFS file system drives. One possible problem is a malfunctioning SCSI and Advanced Technology Attachment (ATA) hardware or drivers. This can also adversely affect the system's ability to read and write to disk, causing errors. If the computer is using a SCSI hard drive, check both for cabling and termination problems between the SCSI controller and the disks. You will need to periodically check the Event Viewer for error messages related to SCSI or FASTFAT in the System log. You can also use Autochk in the Application log. Try the following. First, Double-click My Computer, select the hard disk you want to check. Then, on the File menu, click Properties. Then, click the Tools tab. Next, in the Error-checking box, click Check Now.
Finally, in Check disk options, select the scan for and attempt recovery of bad sectors check box. You can also select the Automatically fix file system errors check box.
http://answers.microsoft.com/en-us/windows/forum/windows_xp-system/windows-xp-blue-screen-error-message-0x00000024/9d6475ed-dc42-4fa7-a2a2-506c42f6ee63
Feb 24, 2013 | Computers & Internet
I am using a software package called Readsoft Forms. I create form definitions for different surveys using this software. when I change to a different form definition to scan I sometimes get an error...
Please try USB connectivity instead of SCSI. It is lot easier and unlike SCSI, there is no sequencing required. (With SCSI, you need to start the device before you start the Computer). You can switch on the scanner when you want!
S. Mohan, Chennai, india.
Jul 26, 2011 | Canon DR-9080C Path-Through Scanner
DELL INSPIRON 1545 (Windows 7) My laptop is displaying the message below when switched on: Internal hard disk drive not found. To resolve this issue, try to reseat the drive No bootable devices...
Hi
It seems that the Hard Disk is disconnected from it's connectors
It needs to be fixed and installed correctly.
To do that, there are screws in the back, remove them and disconnect the hard disk, and reconnect, fix it correctly.
If it's difficult to you, go to technician to do that.
Please, Tell us your results.
Good Luck
May 20, 2011 | Dell Inspiron 1545 Notebook
What do you when it says target disck is not ready on a duplicator
Your disk *WITH* the data is the "source" disk.
Your "blank" disk is the "target" media.
Try a different "blank" disk.
If not any better, then take the unit to a computer technician, to trouble-shoot the hardware that is used to write onto the "target" media.
Apr 02, 2010 | EZ Dupe 1-Target CD/DVD Duplicator with...
49.4401 service error on start up
Solution or Workaround:
1) TRY to flash the firmware.
2) Try cold reset and disk initializations.
3) Replace firmware dimm.
If you have a hard disk:
To resolve the issue it may be necessary to perform the Disk Init procedure.
Disk Init Procedure
1. Turn the printer off, then on
2. When the memory count starts on the control Panel, press and hold the Menu button until all 3 lights on the control panel are lid
3. Press the < button. The message “INITIALIZE DISK” appears in the display
4. Press the Check button. The printer will initialize the User space on the Compact flash and will continue it’s power-on sequence.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | HP LaserJet 4650dn Printer
Can't boot windows xp
it sounds like the easiest solution would to either run the repair sequence from a windows xp disk (may not be a perminant fix) if that doesent work just use the xp disk to format the drive and install a new operating system
May 10, 2009 | Microsoft Windows XP Home Edition
Long periods of hard drive activity
Most likely, it could be the amount of ram you have in your computer. If your running low on ram and it is using the virtual memory your computer can be running all the time causing a slow down in whatever you do. Check to see how much ram you have :)
Mar 24, 2009 | Computers & Internet
KOdak 2500 D -- cannot find target device
Go to Kodak's website and download the scan verification tool (the SVT), and see what it tells you. I use the 2500D with an Adaptec 2940 SCSI controller, and a 50-50 pin SCSI Cable.  I use the twain driver from Kodak's website and paperport 9 software.  This combination seems to work.
Jul 14, 2008 | Kodak Digital Science 2500D Path-Through...
Error messages
Try removing the jumper from the harddrive, then restart
or
Take the jumper off restart shut down and then put it back on again
or
remove the CMOS battery from system board and boot once after booting shutdown your system and insert the battery back, again start your system and press F1 next time it won't ask you for pressing F1. reset your BIOS after that (time,date,etc.)
Try these one should work.
Please let me know.
Dec 01, 2007 | Computers & Internet
Computers & Internet Logo
681 people viewed this question
David Payne
David Payne
