Question about Car Audio & Video
Where is the fuse for cig lighter, radio & interior lights on a c15 w reg van
  • 4 Answers
Find a car lot with your van and ask to look inside. Use that vans fuse lid.
Posted on Sep 01, 2010
WHERE IS THE FUSE FOR CIG LIGHTER IN 2006 CHEVYEXPRESS VAN
cigarette lighter is fuse #30 in the engine compartment. It is located to the right as you face the engine compartment. It is a 15 amp fuse.
Dec 26, 2013 | 2006 Chevrolet Express Cargo Van
2004 Acura RL, I put a phone charger in the cig lighter and the lighter and the radio has stopped worker. I checked all fuses and they are fine.
Applicable fuses:
Under-hood fuse relay box: 7.5A BACK-UP RADIO fuse 56, 20A INTERIOR LIGHTS fuse 67
Under-dash fuse relay box: 10A ACC RADIO fuse 4, 20A BOSE SYSTEM fuse 9
If all of these are fine, everything should be working
Sep 27, 2012 | Cars & Trucks
What fuse controls 12v outlet for cig lighter?
check the fuse box, look for the acc fuse, others have interior fuse that concerns the radio, lights, panels, and that cigarette lighter... or maybe your cigattere lighter is busted...
Mar 31, 2011 | 2000 Toyota Avalon
Radio won't turn on. Fuse blocks don't identify a radio fuse?
w/out amplifier; dome, and Cig. hint if you cigarette lighter is working and your dome light is working ,the problem is not fuse is the radio.
With amplifier. Amp, Cig, and Dome; again if cigarette lighter and dome light and amp fuse is good then amplifier is bad, or Radio is bad the only hint in this one is that the amplifier control sound if radio has ilumination then the amplifier could be the cause.
All this fuses are located by the lower left side of the steering column.
Jan 03, 2011 | 2005 Toyota Corolla
Clock and dash lights dont work or radio--
These items clock, radio, dash lights are usually fused on the same circuit. Please check the fuses for this problem. The fuse or fuses should be listed on the fuse box cover inside the interior fuse box. Replace the blown fuse if that is that problem. If it blows again, then the cig lighter circuit may be involved. Make sure the cig lighter is free of any objects, remove lighter, (push in part). Try new fuse while lighter is out, and if problem goes away, push in may be bad.
Oct 31, 2010 | 1998 Honda Accord
Could not find toyota matrix fuse box for radio and cigarette lighter
cigarette lighter & radio fuse should be a 15 amp fuse in the interior fuse panel listed as; 15A CIG if you need a wiring diagram let me know if you have an audio system with an integral amplifier or separate amplifier.
Apr 30, 2010 | 2006 Toyota Matrix
Cig lighter, radio, and clock not working
It is a 15 amp dome fuse. Located in the cabin. It controls clock, radio, door/headlight chimes, dome lights, power locks, security remote
Sep 25, 2009 | 2004 Toyota 4Runner
Radio does not turn on. the clock shows,the light
The memory wire of the radio,(the power for the clock and channel settings) is usually connected to the same circuit as the cigarette lighter. (there is a seperate fuse for radio) Check your cigarette lighter socket for damage or dirt, etc. could be causing the memory fuse to blow. Also check your cig lighter accesories (like cell phone chargers,etc.)
P.S. The backlight is also a seperate circuit (connected to interior light/parking light circuit)
Jul 21, 2009 | 2004 Saturn VUE
Cig lighter fuse blew. renewed but cig lighter and remote key not
you probably didnt change the right fuse and had another one blown at the same time you also could have a primary fuse under the hood that blew. once fixed dont use pump again. not same amps drawn
May 06, 2009 | 2003 Toyota Corolla
1999 Astro Van power locks
Try... Check 20 amp cig lighter fuse in location 13 of interior fusebox.. I replaced with a 25-30 amp, as I run 110/500watt power converter.. Owner's manual is on line, somewhere..
Oct 19, 2008 | 1999 Chevrolet Astro
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
