Question about LG Washing Machines
I own a LG WD-1290RD 9kg wash/ 5kg Dryer. The problem I have is the lint does not fall down to the lint basket but gets stuck inside the rubber of the tub. What is the best way to clean it? Is there a way to take the rubber away from the barrel? We find it extremely difficult to get lint and we find water does not drain from the fabric softner dispenser. Is there a blockage and how do we clean it?
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
gittos73
  • 244 Answers
SOURCE: Fabric Softner section won't fully drain....
take your soap draw out pull the fabric softener tub out wash leave all of your soap draw in a bucket of hot water scrub with a brush this should clean a small hole which lets your conditioner out simply fix common fault m8
Posted on Aug 14, 2007
jsrock516
  • 5911 Answers
SOURCE: fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Posted on Oct 06, 2007
murdozzz2
  • 75 Answers
SOURCE: Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Posted on Feb 29, 2008
SOURCE: Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Posted on Jun 19, 2008
LG WD-1290RD manual
check searspartsdirect.com they usually have manuals available online.
Feb 27, 2015 | LG Washing Machines
Where is the lint collector on LG 7.5g model WD 1049C Front Loader washing machine.
The combo washer/dryer doesn't have a lint collector. Air is circulated through a condensate tube and is washed down during each drying cycle.
Jun 16, 2011 | Washing Machines
Hi I have an LG WD-1290RD and it won't spin at all - any ideas?
Possible that the main program controller is faulty if there is no output to the inlet valve or the motor. If not the motor can be stuck or the motor start capacitor is faulty.
Please check on these tips.
Mar 29, 2011 | LG Washing Machines
Would like a owners manual for my WD-1290RD can't seem to find one on the net anywhere.
Here's a link to a site with your manual, it's free. If you need a different manual for a different country, just use the search bar on the site to locate one.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WD-1290RD-_E
Hope this helps, and best regards!
Jul 31, 2009 | LG Washing Machines
Lint basket keeps falling out during drying.
Bent the spring tabs to tighten the hold of the basket to back of the drum . If that doesn't work you will have to buy a new one. I found that a lot are damaged by heat.
Apr 27, 2009 | GE WSM2780DWW Unitized Spacemaker Washer...
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
LG WD-12331. Front load washer and dryer machine
since it is a washer-dryer, the lint trap is in line with the drain. you have to empty the drain basket. there's an access door on the bottom left, first take the little tube out and drain the remaining water, then open the large drain cap to the right and clean out the trap. once you're done put it all back together and it should work. you're supposed to do this every few months. It was too much for me to deal with so i ended up buying a separate dryer and just use the washer .
Jul 28, 2008 | LG WM-2277HW Front Load Washer
LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
Unplug the unit to reset the computer.  Wait 5 minutes.  If the problem still occurs, you will need to have the control board replaced.
May 18, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
67 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
