Question about EliteGroup ECS P4VXASD2 VIA P4X266A Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (59815) Motherboard
SOURCE: hd audio driver requierd for ecs fsb audio driver
if your computer came with a motherboard disc the sound drivers could be on it have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Feb 05, 2011
SOURCE: need driver for ecs gf7050vt-m5 with integrated video, sound, lan
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=3993&areaid=2&LanID=0
NVIDIA MCP73 IDE Driver (Vista) v.6.11
Posted on Mar 26, 2009
Nov 30, 2013 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Nov 24, 2012 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Dec 23, 2011 | EliteGroup ECS G31T-M Motherboard - Quad...
Jun 19, 2011 | Computers & Internet
Oct 20, 2009 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Jun 08, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Apr 16, 2009 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Jan 17, 2009 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Sep 18, 2008 | VIA ECS K7VMM+ KM266 Chipset Ultra ATA 100...
Oct 27, 2010 | EliteGroup ECS P4VXASD2 VIA P4X266A...
Jun 03, 2009 | EliteGroup ECS P4VXASD2 VIA P4X266A...
6,807 people viewed this question
