Question about Refrigerators
Will not make ice but will give water model number is gss22wgmb ww
  • 1,073 Answers
Check the dual water valve one side is for the icemaker the other for the water in the door
either a water valve issue or a ice maker problem
if the valve checks good check the line off of the valve to the ice maker you should be able to blow thorugh the line to the ice maker if you caint blow through the line it is frozen in the freezer behind the icemaker and will need to be thawed
if you can blow though the line to the icemaker
replace the icemaker
Posted on May 09, 2008
Refrigerator GE SXS water dispenser works intermittently, ice etc works fine
I believe that you likely have a defective dispenser switch located at part location #72 in photo=> HERE This is that part number=> WR23X10224 Micro Switch I'm here should you have question, Thanks, Sea Breeze
Oct 06, 2015 | GE Refrigerators
Ice maker not dispensing ice on a GE model# GSS25LGMA WW
Try first by fill ice maker with tap water, turn on and let freeze. If Ice drops then the dual water control valve needs replaced. If the ice maker being electronic does nothing it will need to be replaced. Part click Here=> WR30X10093 The dual water control valve is part number Click here=> WR57X10023 can also be found here==> Sea Breeze Tip's Hope this help answer your question, Sea Breeze
Sep 30, 2010 | Refrigerators
I have a GE Refigerator (PSF26MGWA WW). the ice maker will not fill up with water. The tray heats up and the sweeper works. The fill solenoid for the ice maker does not work properly.The drinking water...
the ice maker is in control of the valve, however, the valve is one assembly containing the valve for the water dispenser and the one for the ice maker, take your model to the appliance parts store and get you a water valve assembly for your model number.
Dec 23, 2017 | GE Refrigerators
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Inside my side by side freezer side (hss25gfta ww)
The ice maker water inlet valve has failed allowing water to pass when it is not supposed to pass. The water valve is item 800 of this link.
Changing the water valve most always returns the ice maker operation back to normal.
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
The problem is most likely the water control valve on the rear of your refrigerator. You can test the ice maker by filling with water and let freeze. If ice dumps then the water valve must be replaced. Your model has 3 different choices of water control valves. If the ice maker does nothing but freeze the water and not cycle or dump the ice then I would say the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | GE Refrigerators
No ice or water, new filter was working when installed
check filter again. clean area before installing. check water. check to make shure power is on.
May 24, 2009 | GE Refrigerators
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
