Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Message " Windows cannot find "AdmINisTRAtoR.Exe"
    Guru:
  • 302 Answers
Seems like a virus or something. Update your antivrus and run a full scan of your system.
Posted on Sep 01, 2010
  • 808 Answers
Its looking the registry error in ur system so do a registry repair scan with Intel software partner Reg In Out registry cleaner
2 Suggested Answers
jonniewalker
  • 1029 Answers
SOURCE: AdMINIsTrATor.exe missing
is a malicious malware code created to open security holes in Windows and give third parties control over your compromised computer. After installation Administrator.exe may stay active in the memory and install nasty files in Windows folders. Administrator.exe is a security risk that may harm your system files and computer hardware.
Clean and protect your computer from all varieties of malware threats. Scan and remove Administrator.exe malware and all its related files, clones and aliases.
but Microsoft provides a replacement for the Admin.exe file included with versions 3.2 and 3.2a of Microsoft Mail for PC Networks.
For complete information about obtaining and installing the Admin.exe file, see the following sections: http://support.microsoft.com/kb/107443
Posted on Nov 09, 2009
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
I have an hp compaq 6910p lap top which a friend has password it in the setup and i am finding it difficult to use it. what should i do to clear the password in the setup. eric
please follow the steps as mentioned below >>TURN ON THE COMPUTER >>TAP F11 IT GOES TO RECOVERY MANAGER >>PRESS ALT+D >>NOWCOMMANDPROMPTOPENS>>TYPE=CD\ HITENTER>>TYPE C: HITENTER>>TYPE CDWINDOWS HITENTER>>TYPE CDSYSTEM32 HITENTER>> C:\Windows\System32>>TYPE REN C:\Windows\System32\UTILMAN.EXE OLDUTILMAN.EXE HIT ENTER>>TYPE REN CMD.EXE UTILMAN.EXE HIT ENTER>>RESTART THE COMPUTER >>IN THE LOGIN SCREEN CLICK ON THE ?EASE OF ACCESS ? WHICH IS LOCATED ON THE BOTTON LEFT CORNER. IT OPENS THE COMMAND WINDOW>>TYPE: NET USER ADMINISTRATOR /ACTIVE:YES (THERE IS A SPACE)>>TYPE EXIT>>AND RESTART THE COMPUTER>NOW AFTER RESTART YOU SEE THE ?ADMINISTRATOR? USER NAME>>CLICK ON IT YOU WILL LOGIN TO THE DESKTOP>>YOU CAN NOW REMOVE THE FORGOTTEN ADMINISTRATOR ACCOUNT PASSWORD BY GOING TO CONTROL PANEL>>AND AGAIN TURN OFF THE COMPUTER AND RESTART THE COMPUTER AND GOTO THE ?RECOVERY MANAGER >>AND PRESS ALT +D >>NOW COMMAND PROMPT OPENS >>TYPE CD\ AND HIT ENTER >>TYPE C: HIT ENTER >>TYPE CD WINDOWS HIT ENTER >>TYPE CD SYSTEM32 HIT ENTER >> C:\Windows\System32>>TYPE REN c:\windows\system32\UTILMAN.EXE CMD.EXE (This is important as we have renamed CMD.exe)>>TYPE REN OLDUTILMAN.EXE TO UTILMAN.EXEAND RESTART THE COMPUTER>> NOW LOGIN TO THE OLD ADMINISTRATOR ACCOUNT AND DISABLE THE NEW ADMINISTRATOR ACCOUNT>> OPEN ?CMD.EXE? >> TYPE: NET USER ADMINISTRATOR /ACTIVE:NO
Apr 20, 2010 | HP Compaq 6910p Notebook PC PC Notebook
Forgot master password...need to reset... did not create password backup disk...help
>>TURN ON THE COMPUTER >>TAP F11 IT GOES TO RECOVERY MANAGER >>PRESS ALT+D >>NOW COMMAND PROMPT OPENS >>TYPE - CD\ AND HIT ENTER >>TYPE C: HIT ENTER >>TYPE CD WINDOWS HIT ENTER >>TYPE CD SYSTEM32 HIT ENTER >> c:\windows\system32 >>TYPE REN c:\windows\system32\UTILMAN.EXE OLDUTILMAN.EXE HIT ENTER >>TYPE REN CMD.EXE UTILMAN.EXE >>RESTART THE COMPUTER >>IN THE LOGIN SCREEN CLICK ON THE ?EASE OF ACCESS ? WHICH IS LOCATED ON THE BOTTON LEFT CORNER. IT OPENS THE COMMAND WINDOW >>NOW TYPE :NET USER ADMINISTRATOR /ACTIVE:YES ( THERE IS A SPACE) >>TYPE EXIT >>AND RESTART THE COMPUTER >>NOW AFTER RESTART YOU SEE THE ?ADMINISTRATOR? USER NAME >>CLICK ON IT YOU WILL LOGIN TO THE DESKTOP >>YOU CAN NOW REMOVE THE FORGOTTEN ADMINISTRATOR ACCOUNT PASSWORD BY GOING TO CONTROL PANEL >>AND AGAIN TURN OFF THE COMPUTER AND AND RESTART THE COMPUTER AND GOTO THE ?RECOVERY MANAGER >>AND PRESS ALT +D >>NOW COMMAND PROMPT OPENS >>TYPE CD\ AND HIT ENTER >>C: HIT ENTER >>CD WINDOWS HIT ENTER >>CD SYSTEM32 HIT ENTER >> c:\windows\system32 >>TYPE REN c:\windows\system32\UTILMAN.EXE CMD.EXE (This is important as we have renamed CMD.exe) >>TYPE REN OLDUTILMAN.EXE TO UTILMAN.EXE AND RESTART THE COMPUTER >> NOW LOGIN TO THE OLD ADMINISTRATOR ACCOUNT AND DISABLE THE NEW ADMINISTRATOR ACCOUNT >> GO TO CMD.EXE. TYPE NET USER ADMINISTRATOR /ACTIVE:NO note : it is strictly for hp computer running vista. FOR xp ------go to safe mode with networking from advanced option, go into administrator, go to control pannel - user a/c change your password
Mar 30, 2010 | Computers & Internet
I'm having problems connecting. I ran the initial CD setup and everything seemed to run fine but when I try to access the 10.0.0.253 I receive an error message. The camera is set to wired and is...
"I receive an error message" (sic) What is it exactly, what happens? Also Install everything as Administrator, ALSO set the setup/install program's .exe in, Compatibility Mode for XP SP2. and Run the actual program's .exe as Administrator, too. Ensure all network settings are correct too.
Feb 22, 2010 | Panasonic BL-C131 Network Camera
Admin password has changed somehow
Hi, man. Don’t worry, there are many people forget their admin password or lost it, and there is a popular solution for those who have been locked out by computer. For this solution, what you need is a second computer that can connect to Internet and then freely download Windows Password Recovery 6.0 at http://www.recoverlostpassword.com/products/windowspasswordrecoery.html With it, you can create a reset CD which can be used to reset Windows admin password without erasing anything.
Jan 23, 2010 | Toshiba Satellite M100 Notebook
Nov 09, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How to register ocx on vista
[Solution # 1]
Drag and drop it onto regsvr32.exe in Windows\system32 folder. Make a shortcut for regsvr32.exe in the same folder the OCX is in and drag and drop it that way
[Solution # 2] Just run cmd.exe as administrator and try again. This is the key.
Here, step by step:
1. find the folder of cmd: it is usually on C:\windows\system32\cmd.exe
2. Do right click over cmd.exe and click on "run as Administrator"
3. now just use regsvr32.exe as you used to do!
For example, to register most Blackd Proxy ocxs, you might need to type this in "Administrator" cmd:
regsvr32.exe c:\windows\system32\richtx32.ocx
regsvr32.exe c:\windows\system32\comdlg32.ocx
regsvr32.exe c:\windows\system32\mswinsck.ocx
regsvr32.exe c:\windows\system32\msflxgrd.ocx
regsvr32.exe c:\windows\system32\msinet.ocx
regsvr32.exe C:\windows\system32\comctl32.ocx
A side result for Visual Basic 6.0 users: this seems to be the way to use components in Windows Vista properly. Just register the components of your proyect with "Administrator" cmd before adding them to your proyect (or before opening a proyect that already had such components)
[Solution # 3]
use this in command line
REGSVR32 /V then ur ocx or dll name
ex:
REGSVR32 /V CRPAIG32.DLL
[Solution # 4]
right-clicking the batch file and selecting
'run as administrator'.
richtx32.ocx
comdlg32.ocx
mscomctl.ocx
dxtmeta2.dll
Good luck
Mar 03, 2009 | Microsoft Windows Vista Ultimate Edition
Page Maker 6.5 + Windows Vista
Go to the PM folder on the CD, right click setup.exe and "Run as Administrator"
Mar 09, 2008 | Computers & Internet
Windows cannot find scvhost.exe
This is the Internet Virus , to overcome this , you may kindly be taken following steps .
Step 1: Write click on the start button task bar .
Step 2: Select Task manager by left click of you mouse.
Step 3. Under the process option , select line
svchost.exe system Administrator
Step 4. Select End process .
Step 5. Repeat Step 3 & 4 until the end of the bellow message.
svchost.exe System Administrator
Step 6. Close the Windows Task Manager by click X button .
or
Run the Original Quick Heal / AVG antivirus software in your system .
The steps are the solution for your problem.
OK
nilamani
nkjbbsr@yahoo.co.in , nkjbbsr@rediffmail.com
Dec 21, 2007 | Microsoft Windows XP Professional for PC
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
78 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
