Question about Huffy Sport & Outdoor - Others
Require assembly instructions for a 6 year old tuff stuff slam portable hoop please
5 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: Need English assembly instructions for Reebok
Hi, ask here, they have found already some hard-to-find Reebok manuals.
Posted on Aug 23, 2009
SOURCE: assembly instructions for portable basketball hoop
we put all three poles into one by mistake on our new portable hoop we managed to get the screw out but cannot get the poles apart help!
Posted on May 18, 2010
  • 5 Answers
SOURCE: assembly instructions for a lifetime basketball
oly god knows
Posted on May 27, 2010
walesarumi
  • 6993 Answers
SOURCE: I have an old huffy
Follow the below assemble instruction as requested for your huffy sports basketball hoop;
Insert the mounting screws through the mounting holes of the backboard, then lay the backboard face down. Lay the mounting brackets on top of the backboard so the mounting screws of the backboard go through the mounting holes of the brackets. Tighten the screws with a wrench.
Insert the adjustment hardware between the brackets and insert the screws connecting to the brackets to the adjustment hardware, then add a nut to the screw and tighten with a wrench. These screws will be inserted horizontally through the brackets into the adjustment hardware. The adjustment hardware allows you to adjust the height of your basketball hoop.
Line up the holes of the rim to the holes of the backboard and install the rim screws through the rim into the backboard and secure them with a nut. Tighten the nut with a wrench. Thread the nut through the wire holes of the rim.
Assemble the pole. Dig a hole with a shovel where you want to install the basketball hoop. For the exact size of the hole, you will need to consult the directions on your Huffy basketball hoop. To achieve the regulation height of 10 feet, this step strongly depends on the size of the particular basketball pole and a specific measuring depth. Measure the hole with a tape measure for accuracy. Mix a bag of cement in a wheelbarrow with water. Consult the directions on the cement bag for exact mixing instructions.
Place the pole in the hole and shovel in the cement. Allow the cement to dry.
Use a ladder to reach up and connect the mounting arms to the mounting brackets and then to the top piece of the basketball pole. Each of mounting arms has a hole at the end that you need to line up to the mounting bracket and secure with a screw, add a nut and tighten with a wrench.
Line up the holes at the end of the two top arms to the top holes of the top of the basketball pole. Insert the long screw through the holes of the arms and pole, secure it with a nut and tighten it with a wrench. Install the bottom arms to the lower holes of the basketball pole.
I hope the above helps.....
Good luck.
Posted on Apr 03, 2011
I was looking for the assembly instruction for this older model.
I was looking your other question about Classic Sport Triple Threat 222 portable basketball hoop assembly instructionsand couldn't find it on line so didn't answer it. But looks you was looking assembly instruction for that older model? Maybe you could provide the denimination for that older model
Jul 13, 2015 | Sport & Outdoor - Others
How to setup a rawling softee hoop set
Unfortunately, I couldn't find a manual or instruction guide online. Here is the contact page of the Rawlings website. They should be able to help you assemble it.
Feb 24, 2013 | Rawlings Michigan Wolverines Slam Dunk...
HOW DO YOU INSTALL A DOOR LOCK ON WHIRLPOOL DUET I NEED STEP BY STEP DIRECTIONS PLEASE HELP
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need instructions to replace door latch-kenmore elite top loader
1. Unplug washer.
Oct 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Door won't latch on our Whirlpool Duet Washing Machine
1. Unplug washer.
Sep 19, 2009 | Kenmore Elite 45986 Front Load Washer
Assembly instructions for portable basketball hoop
Sep 10, 2009 | Huffy Sport & Outdoor - Others
Door shut, display says ''door open please close'' Wash cycle wont start..Most likely faulty door lock sensor, or is it!
1. Unplug washer.
Jun 21, 2009 | Washing Machines
Kenmore 417.44052400 Front Load Washing Machine about 3 years old. The door wont lock. Is there an easy fix to a problem like this?
1. Unplug washer.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Apr 04, 2009 | Kenmore Washing Machines
WHIRLPOOL DUET WASHER
Failed Door Latch
1. Unplug washer.
Feb 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Door not locking
Here ya go. Read through the instructions carefully before beginning any disassembly. This repair is not difficult as long as you follow these steps:
1. Unplug washer.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO **T remove the rubber bellow from the wash tub. This requires more steps, which means removing more parts, which means more time (plus patience).
Once you've completed these steps make sure the door closes and latches properly. ***** slam a door with an electronic latch. They can break easily.
Now plug the washer back in. At the control panel select:
DRAIN SPIN
** SPIN
and under OPTIONS press any key (has the be the same key) 4 times.
This places the washer into diagnostics mode. "C00" will be displayed on the screen and you should hear a distinctive "click" of the door latch. If diagnostics passes, the washer will run through a series of tests, tumble, drain and then spin. When completed, the unit will make an audible "beep" and the CLEAN light will be lit.
You can stop this process at any time by press the PAUSE/CANCEL button. Good luck to you and let me know if you have any further questions.
Mar 09, 2008 | Kenmore Elite 45986 Front Load Washer
Sport & Outdoor - Others Logo
69 people viewed this question
Top Huffy Sport & Outdoor - Others Experts
Are you a Huffy Sport and Outdoor - Other Expert? Answer questions, earn points and help others
