Im working on a Muratek 2830 and its calling for service with no specific error, but its wont print, fax or copy. Is there a reset in service mode? of is it something else I can do ti fix this. If so how do I get in Service mode? please assist Thanks
  • 944 Answers
This will help you out to solve the issue
If you need more help i will give the repair pdf for you..
The errors messages and an explanation of each are outlined below.
RX Motor Error
Suggested corrective action steps:
1. Check the connection between RX motor and the Connect A PCB (P90).
2. Verify the RX motor rotates when the power is on. If OK, see step 6.
3. Check the power is supplied to the Rx motor. If it does not, see step 5.
4. Replace the RX motor if it doesn’t rotate.
5. Replace the Connect A PCB.
6. If the problem is not correct, replace the main control board.
Fan Error
1. Verify the inside fan rotates when the power is on.
2. Check the connection between the fan and Connect A PCB(P87), Connect A PCB (P80C) and the main board.
3. Replace the fan motor if it doesn’t rotate.
4. Replace the Connect A PCB.
5. Replace the main control board.
Fuser Error
1. Turn on the power again, and verify the fuser warms up. If it does not, see step 4.
2. Check the contact between Fusing thermistor and Connect A PCB(P89).
3. Check the contact between Connect A PCB (P80C) and the main board.
4. Replace the Fuser.
5. After replacing the Fuser, verify the fuser warms up when the power is on.
6. Replace the main control PCB.
Drum Error
1. Verify the drum cartridge is set correctly.
2. Check the point of contacts between drum cartridge and Connect A PCB (P86).
4. Replace the drum cartridge.
Developer Error
1. Verify the toner cartridge is set correctly.
2. Check the point of contacts between toner cartridge and Connect A PCB (P86).
4. Replace the toner cartridge.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 01, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 01, 2010
    Please add a comment of Your mail id so i can send you the document.Please do not down rate solution and add a comment,You can just add a comment.so i can send you.
Error 0548H Ricoh fax 4420L
Fuser Error. Check fuser thermistor. reset fuser error. Go to Service Mode press 1 0 7 , clear/stop , 1 copy, 5 mode, ok, 810, ok, change to 1, press half tone and ok simultaneously. fax will rebook automatically and fuser error is reset.
Jun 20, 2015 | Ricoh Office Equipment & Supplies
HP 3380 All-in-one. wont send faxes. dials, says connecting, and even sometimes starts to send page, but comes up comm error. I have vonage phone service.
Vonage claims to work with all fax machines. However, some customers report having had trouble sending and/or receiving faxes with Vonage and other voice-over IP (VoIP) providers. The difficulties are a frequent topic in help forums and even made the Wikipedia entry for Vonage. Frustratingly, the problems have been intermittent and hard to diagnose, and some customers have resorted to buying a new fax machine that better-suits Vonage’s optimum specifications. The company’s official “help” resource suggests lowering the baud rate on the fax machine to 9600 (or “slow”) as well as disabling the machine’s ECM (error correction mode) feature, if applicable. Also, make sure the fax machine is on the “standard” setting. Some users have had good luck adding *99 before dialing, as that resets the bandwidth for that call.
Vonage also allows its customers to send faxes over the Internet, without a fax machine, by uploading documents to the Vonage web site. There is no additional charge for this service if you’re on the company’s “Unlimited Plan.” Per-minute customers will see fax use applied toward their monthly minutes allowance. Hope this helps.
Apr 20, 2010 | HP LaserJet 3380 All-In-One Printer
Muratec 2830 drum cartridge problem.
The drum cartridge is different from the toner cartridge. The drum has reached its life cycle and must be replaced. This is normal for any copier of that class.
The drum is not too expensive and not difficult to replace.
Hope this helps!
Sep 09, 2009 | Office Equipment & Supplies
Can't fax out on my Epson Stylus CX5800X
Verizon is lying to you. Fax machines are analog devices.
Mar 14, 2009 | Epson Stylus Multifunction Inkjet Printer/...
BLOCKED CALLS
If you subscribe to a caller ID service through your phone provider, you can block
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
number in the blocked fax numbers list, the fax is not printed.
Set the junk fax mode
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
service through your phone provider, or do not want to use this feature, you can turn
off this setting.
To set the junk fax mode
▲ Some models have a Block Junk Fax button. Depending on the model you have,
do one of the following:
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Kx-flm600 call service lp
I have the same problem !!!
and same fax.
Dec 10, 2008 | Panasonic KX-FLM600 Printer
Intellifax 4100 won't receive faxes
Make sure the green light that says "FAX" is lit by pressing the "Mode" button in the upper right corner of the unit
Feb 07, 2008 | Brother IntelliFAX 4100 Laser Fax
IntelliFAX 4750E - Printer Busy
The printers memory may be full depending on the type of documents they are printing. The first and most simple step is to unplug the power cord from the back of the unit for 30 seconds, put your finger on the stop key while plugging the unit back up and continue holding the stop key until the time and date are back on the display of the Brother unit.
If that does not work unplug the USB cable from the PC. Unplug the power cord from the unit again. Put your finger on the menu key first and then plug the unit back up. You want to hold the menu key unit the until the LCD says maintanence and all the lights are flashing. Let the menu key go and press the number 82 and will give you an error code. If the error code is 00 then there are no errors. If there is an error code record it and contact brother or check a service manual if you have one. Most laser products all have the same error codes with Brother.
To reset the unit press stop and then 91, this will reset the unit and all faxes or print jobs will be lost. This should clear the issue.
Jan 02, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Call Service 3
Press Menu first, then #9000*, next press 550, press Start, wait for printing, unplug the electric cord, wait 10s or more, plug it again, it's done.
Dec 19, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
26 people viewed this question
k24674
