Question about Microwave Ovens
Instruction manuel for GE spacemaker - Microwave Ovens
  • Anonymous Aug 29, 2008
    i have a ge spacemaker oven. however i do not have the installation instructions.
  • Anonymous Jan 01, 2009
    This takes me to the url but when it tries to load it just sets there -4-5minute wait and no info displayed. Is there something wrong with the server connection? I'm on a dial-up modem.
    sparky3735@aol.com
  • Microwave Ovens Master
  • 9,098 Answers
Please reply back with your full model number or enter it here:
http://www.geappliances.com/service_and_support/literature/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 10, 2008
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
My GE Spacesaver microwave is on LOCKED and I do not have a manuel for it. How do I get it unlocked and cleared?
You can download GE owner's manuals and installation instructions here.
May 25, 2011 | GE Spacemaker JVM1740 Microwave Oven
Need installation instructions so I can remove a GE spacemaker xl model jvm1330wwc.
You can also download GE owner's manuals and installation instructions here.
You can find handy exploded views and order parts by model number
here.
If you need simple do it yourself repair tips or a free estimate, let us know.
Aug 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker II clock not working (1994)
Are you working with the owner's manual?
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions and owners manual
Apr 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Who do you install the GE spacemaker microwave
You should be able to find the installation instructions and owners manual at the GE website.
Dec 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to install GE Spacemaker Microwave
You can find handy exploded views and order parts by model number here.
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven
Aug 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No instruction manuel for model J VM152H 002 (was installed when we moved_
The Owners Manual for the GE JVM152H can be found, saved, and printed from this page: Owners Manual
Hope this helps!
Aug 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
