Question about Toshiba Satellite A205-S4617 Notebook
When using AC Power my laptop hang-up...then using battery operate normally. What is the problem of my laptop? please help me?
  • Toshiba Master
  • 12,061 Answers
You most likely have a faulty power supply, usually there is a break or short circuit in the Cable, sometimes the internal electronics fault. If the LED power ON indicator is lit and when you plug it in it goes OUT, then your may have a short circuit in the Cable. If there is NO LED on the unit to indicate power on, then most likely then the supply itself is faulty. One could replace the Cord, if the problem in the cord could be found, however the best approach, would be to replace the PSU, once and for all.
Posted on Sep 01, 2010
My toshiba Satelite A200 is hang when AC adaptor is insert
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Feb 08, 2012 | Computers & Internet
The labtop do work with battery but doesnt work well with adapter instead with will hang or shutdown after 3 or 4min put the adapter
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 20, 2011 | Toshiba Satellite Pro L300 Notebook
It hang, i can't turn it off
Forcely shutdown the laptop by pressing the power button 5secs.Unplug the ac adapter (charger), remove the battery(located on the bottom) and without the power sources (w/o battery and ac adapter), hold down na power button 10 secs. Put the power sources back and turn ON the laptop.
Mar 01, 2011 | Samsung Computers & Internet
I have a Dell Latitude D800. I want to run it on AC power. Do I have to take the battery pack out of it before I ru it on AC power?
Hello Paula, Hi Never remove the battery out when powering with AC, your Dell will get busted, run ac with the battery. The AC power produces a voltage above the normal operating voltage of the Dell, the over voltage is for charging the battery and powering the DELL, if you remove the battery, the over voltage will bust the laptop in seconds. So operate the laptop with AC and battery.
Feb 11, 2011 | Computers & Internet
Insert battery hang not working
have you tried using an extra battery? or remove and put back in the battery? if it still wont work, try updating your BIOS, check your website if they have one available.
Apr 03, 2010 | Acer Aspire 5050-3242 Notebook
Satellite A205 hang on AC power in Vista, Win7 but not XP?
Probably you will have to upgrade your drivers, specially power management.
Mar 12, 2010 | Toshiba Satellite A205-S4617 Notebook
My hp pavillion laptop won't start at all whats wrong?. It hasn't been dropped.
Remove the battery and the AC adapter then press and hold the power button for 30 secs. Put back battery and plug back AC then power ON as normal.------
Also try with ONLY battery (AC removed) and vice-versa.--
Basically I would check output of my AC adapter first. If everything is OK with that, I will check the power button.
---- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 24, 2010 | HP Pavilion dv6000z Notebook
Acer 5670 boots ok but keyboard and mouse don't work. External mouse doesn't work either. can you help?
Just remove the battery
a bad battery disconnects your keyboard from windows
all so you buy a new computer
Oct 05, 2009 | Acer Aspire 5670 Notebook
Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Jan 29, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
121 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
