Question about Tyco Toys
Found old tyco train set. how do i hook up power pack????
4 Suggested Answers
captjack163
  • 13 Answers
SOURCE: tyco trains are set up have power but trains will not move
Check the engine and transformer by taking the two wires from the transformer and, while holding the engine upside down put on wire against one side wheels and the other wire on the other sides wheels...that will tell you if the engine is at fault.
Posted on May 04, 2010
  • 1015 Answers
SOURCE: tyco toy train does not
I would start by making sure all the connectors on the track are clean and locked together firmly.Wipe off track rails and all electrical connections with clean soft cloth such as a wash rag.Try to not touch electrical connections with bare hands as even small amounts of body oils or hand lotions can interfere with good connections. Check hook ups from transformer to track. Clean electrical pick up points on engine with pencil eraser and soft rag, you can use eraser to clean track surface also.
Hope this is helpful and have a good new year. Thanks
Posted on Dec 28, 2010
How do i set up electric tyco train set- model 899v hobby transformer?
There are 2 wires from the transformer to the power rail screws on the track. Hook up the wires and watch the direction the engine moves when you move the lever to forward. If the engine moves in reverse, either swap the wires or turn the engine around on the track.
Nov 01, 2014 | Crafts & Hobbies
I need a replacement remote for a Jeremy McGrath Tyco X-treme cycle
I had the same problem and found I was able to use a remote from a similar Tyco R/C toy. Many of these R/C toys from the same manufacturer and era have compatible control signals and will work with another's controller if they are using the same frequencies. I found a similar 49Mhz Tyco remote from a local thrift store and it works for me, perhaps you can as well..
Jan 24, 2013 | Tyco Toys
New bright santas christmas express no, 187 train wont smoke
This goes back about 40 years for me. Both Lionel and TYCO had "smokers" in their train sets. My recollection was that the "special smoke oil" was a mixture of very highly refined kerosene and parafin wax. Try a hobby shop such as Hobby Town or some such.
Nov 27, 2012 | New Bright 384 Holiday Express Animated...
Need the 6bdc battery pack for tyco sea arrow
there should be a battery box that holds four AA batteries. The box fits in the boat.
May 11, 2012 | Tyco Radio Control Sea Arrow Boat 27mhz
1998 Tyco Boat needs battery
This is not the reason. The dual contacts in the boat are there to accommodate two types of battery packs. Only one pair is used at a time.
Mar 23, 2012 | Tyco Radio Control Sea Arrow Boat 27mhz
I have power to the train and it runs but it moves extremely slowly and sommetimes comes to a stop.
I'm assuming the train is track powered with a power pack, and not battery powered, so there's actually a few possible solutions. I'll work from the easiest/cheapest, to the more advanced/expensive.
First, especially if the track is old or been in storage a while, the track may have a thin film of dirt, oil, or rust that is insulating the wheels from picking up the power they need from the track. Try cleaning the track with a mild soap but BE SURE TO DRY IT COMPLETELY before reattaching the power. Also, clean the wheels but use a cotton swab and very little water. One drop inside the motor might destroy it from the inside. You can also try a special track cleaning solution sold at your local hobby shop that has HO model train sets. That will work better, especially on lightly rusted parts. Also, make sure all the track connections are tight and free from contaminants.
Then, if you're feeling brave, you can check the motor of the train itself. Disassemble the locomotive and find the motor inside the housing. Check the wires leading from the wheel area to the motor for any corrosion, or loose/broken wires. If it's not the wires which are easy to solder back in place, I wouldn't recommend going any deeper into the motor as it's better and less frustrating to just buy a whole new set.
Finally, the problem may lay in the power pack (inverter) itself. I personally don't bother trying to fix a power pack, but if you know your electronics you could run some tests of the output voltage to the track, and the voltage on the track at various points. Again, it's not worth the time or effort to mess with the power pack unless you know what you're doing. You could get seriously injured or killed by the voltage/amperage running through those things. They even have enough stored electricity after they're unplugged to cause some nasty electrical burns from the capacitors.
Hope this helps and you're able to fix the problem so you can get back to enjoying the train set. I've always enjoyed watching them for hours, especially when I set up my track around the Christmas tree every year! Good luck!
Dec 19, 2010 | New Bright 384 Holiday Express Animated...
Tyco trains are set up have power but trains will not move
Jan 28, 2010 | Tyco Ho Vintage Wm Flat Car W/ Tractors...
I have an old tyco slot or racing set and i would like to build it again,But i have no layout instructions,Could any one help,It's about 20 years old, comes with 2 indy or F1 type cars,
I found some layout instructions on the Mattel website (Mattel owns the company/products formerly known as Tyco) at:
http::/service.mattel.com
or you can call their Consumer Relations at 800-524-8697, Mon-Fri 9am-6pm ET. In fact, I just spoke with them, and they are very helpful.Unfortunately, they no longer carry the parts I needed for my 13-year old Tyco Lamborghini Championship set... :-(
Jul 08, 2009 | Mattel Tyco R/C Speed Racer
Need motor brushes for Penn Line and Tyco HO
If you go to :
www.hoseeker.net
they have old catalogs and part numbers for Penn Line trains. Then try:
www.yardbirdtrains.com
for parts or a replacement motor or they may be able to point you to someone who may have the parts. Good luck.
Bob D.
Apr 25, 2009 | Electric Vintage Tyco Ho Scale Trains...
Toys Logo
440 people viewed this question
Top Tyco Toys Experts
john h
ray gallant
Tom Chichester
Are you a Tyco Toy Expert? Answer questions, earn points and help others
