Question about NRS KIRBY UG/DE&G3 SPRAY GUN ASSEMBLY
Can I use my Kirby Spray Gun for coating a paint over the wooden items like windows, wooden shelters etc.?
  • 240 Answers
It can be used, but be sure to use a water based, non-flammable paint or stain. Blow the dust out of the hose before attaching the spray gun.
Posted on Jan 19, 2011
What is the best way to lay down the clear coat over my finish coat on the fender I just painted but ruined when I shot the clear coat?
Refer to the paint manufacturer's data sheet to ensure the new gun has the right setup for clearcoat.
Could be the new gun was supplied setup for spraying a high solids primer or something that needs something like a 0.7 mm fluid tip. Clearcoat would need a 0.4 mm tip, an appropriate needle and a different air cap.
Data sheets are very valuable things. Don't forget to pick one up when you buy spray paint. A viscosity cup is another useful addition to the tool kit along with a graduated paint stirring stick.
Nov 24, 2015 | Air Tools & Compressors
Iam refinishing my wooden desk.Ihavesanded smoothand using my paint gun I'mspraying a clear coat but its not coming out even
It will most likely be your spray gun or the thickness of your clear, my rule of thumb is dip a screw driver in and pull it out, you should count about 4 seconds until it starts to drip, Failing that it may be your technique in spraying
Sep 03, 2013 | Air Tools & Compressors
I have the hds780rs0605 I need to know if I can use latex paint for my walls and how to with out it clogging up
Let me start by saying these types of paint sprayers are not usually recommended for painting large things like room walls because you're going to spend a lot of time refilling the paint cup. The cup only holds 20 ounces of paint and that won't go very far on your walls. If all your paint isn't mixed and properly thinned at the same time your walls could end up with a checker board look. You would usually be way further ahead to rent an airless paint sprayer.
If you have to use it; first run your paint through a paint strainer, avaliable at any paint or box store (The Home Deopt, Lowes, etc). Even new paint has impurities that will clog paint guns. It's highly recommended you mix in a paint conditioner like Flotrol but not absolutely necessary. Next, you're going to have to experiment with the consistency of the paint to get a good even flow out of the gun. The thinner you have to make the paint to get a good flow, the lighter and more coats you're going to have to apply. It's also recommended to run a paint soaked roller over the wall right after you spray it to even out the paint and remove any overlap marks.
Aug 05, 2012 | Air Tools & Compressors
Spray painting
It depends on what kind of spray gun you have. If you have a HVLP gun the pressure doesn't have to be as high, but you need a compressor that will keep up. The pressure is usually pretty low on these guns, about 15 PSI or less. The paint manufacture will usually give you a recommended pressure to paint their paint. A normal (old style) suction type gun takes more pressure, about 50 PSI. If you are asking this to decide on a compressor size, you will find that a one horse motor on a two cylinder compressor will not keep up. The newer supposedly five horsepower compressor will not keep up consistant pressure either. You need a five horsepower that runs on 220 and driving a belt driven two cylinder compressor minimum. You can get by on less, but have to wait half way during a coat on a car to wait on the compressor to catch up. This may be o.k. if you are just going to paint one car, but if you are looking to do this consistantly, then I would get a five horsepower motor on a two stage compressor. Make sure you drain the air tank of water and use a good air filter to remove moisture from the air before trying to paint. Hope some of this helps you.
Feb 16, 2012 | Bernina Sewing Machines
What is the correct concistancy the paint needs to be mixed at for the dynatec psg 45 electric spray gun
It depends on 3 things.
What you are painting.
Whether you are applying latex, oil-base, or primer.
What size TIP you are using.
We use spray equipment and use size 17 and 19 for latex, and 11 for oil.
Double-check the size that came with your gun and look at tips at Home Depot.
Old tips wallow out and the spray pattern is irregular/uneven and the gun blows out too much paint and our material costs go up.
The manual says "dilute correspondingly"
http://www.airless.com.au/Airless%20Sprayer.pdf
Let's say you are spraying oil-base stain: I would NOT dillute this material.
Oil-base primer: 1 thinner to 4 paint
Latex primer: use a roller and brush so you have a good undercoat for the paint.
Oil-base paint: I would add 1/8 thinner with 1 paint, and be careful of runs
Latex stain: try 1 water to 4 stain
Cheap interior flat latex: 1 water to 4 paint
Latex semi-gloss interior: 1-1/8 to 4 paint and apply very thin coats and let dry between coats.
Cheap exterior flat latex: 1+ to 4 paint, and add more or less water as needed
Good exterior latex paint: use a roller and brush because the purpose of latex exterior pain is to apply heavy protective coat over outdoor materials ... dilluted exterior latex will not give sun and mildew protection.
We use heavy spray equipment and apply exterior latex straight form the can. It's the only way to give lasting job, unless you're doing a temporary playhouse.
The key to successful spraying is to strain your paint to get out the lump and clogs - BEFORE putting paint into the gun.
We always strain the paint unless it's a freshly opened can.
If can was opened yesterday, we strain it.
That because paint gets a dry film that will clog the sprayer.
First you need to mix your material, so you need a couple buckets.
Pour the paint and thinning material in 1 bucket, and then to mix, pour back and forth between two or three buckets. This action will mix the paint thoroughly and save you an hour of rotating a paint stir stick.
Next, you need to strain the paint.
Wash out a 5-gallon bucket.
Buy 5 gallon strainer that fits into bucket.
Pour material into bucket with strainer, lift strainer up and then grab end of strainer and squeeze out all the paint.
Immediately put lid over paint so no drying film will form.
Wash out strainer.
You're ready to put paint in spray gun.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on paint project.
Jan 06, 2011 | Garden
I am in Davao, Philippines and just bought this spray gun. I have no experience of using spray guns and was surprised to find there is no manual. Not even basic info like which adjuster is for fluid and...
Im a professinal spray painted. Although i now what you have there are a lot of variblys this is called a conventional system. Is made for light meteral spraying on metals or fine finish objects. Paint quilty and thinning and proper air control feed and volume are the most critical as well as the envirment that you are working in do to the extened time it takes the meterial to set up and the number of coats to achive the mil thickness required for the product to proform at its specified levels. Looking at your gun if the picture is correct the upper control knob is the spray pattern control and the second knob is the paint or fulid control the amount of paint that comes out he tip that is also controlable but olny from vertical to horizontal pattern it should come out in a cone shape. And what you realy need hear is a regulator between the regulator at the compressor and the air supply at the air hook up on the gun and also a water trap in line before that so condensation drops woun't spit out the tip and pock mark the finish. Idon't know what you want to use this mechine for but it is a vary complex opperation and you had better do your homework if there is liabilty involved with what you are doing. good luck
Jan 02, 2011 | Buffalo Tools 1 Quart Capacity Air Paint...
G4can you spray paint with kirby if yes what part do you use
There are no parts for this as the kirby doesn't produce enough exhaust pressure to operate a spray gun.
Nov 06, 2010 | Kirby G4 Bagged Upright Vacuum
My Kirby G3 paint attachment isn't spraying the paint. I have everything hooked up according to the manual, and it sprays a continuous stream of air, but isn't sucking up the paint to spray. Sometimes I...
mcdevito75 here, Sounds like it"s cogged with paint, the paint is not being sucked up into the Spray gun itself, the air flows thru thr spray gun thru the trigger assembly. Follow the makers cleaning of the spray section of the spray gun. Try running paint thinner thru the spray system. Hpope this helps.
Jul 19, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Paint Supplies
if only painting exterior 1 can per item and two cans of clear coat. make several passes of paint use whole can per item and then use all clear coat for good finish and weather protection.
Jan 17, 2010 | 1994 Oldsmobile Bravada
I want to know how to camouflage a jeep the best
Knowing how to paint a Jeep in camo patterns means you can hide your Jeep in the woods, marshy areas or in open fields without it being easily seen. Using Mossy Oak's Shadow Grass pattern, paint your Jeep with natural-looking shadows and grass blades. The 3-D look of this pattern allows you to easily hide your Jeep from water fowl, doves, deer and big game.
Things You'll Need:
  • Sandpaper (120 and 800 grit)
  • Wax and grease remover
  • Lint-free towel
  • Camo stencil
  • Masking tape
  • Masking paper
  • Respirator mask
  • Automotive primer
  • Automotive paint (black, gray, light tan and brown)
  • Automotive clear coat
  1. Sand the surface of the Jeep with 120-grit sandpaper until the surface is dull. You can use a dual-action sander for this step to speed the process. This removes the top clear coat and prepares the surface for primer. Primer won't stick to a shiny surface.
  2. Mask off areas of the Jeep that won't be painted, such as the windows, tires and passenger area of the Jeep. Wipe the surface with wax and grease remover and a lint-free towel.
  3. Spray primer on the Jeep in three thin coats. Allow each coat to dry completely. Once the primer is dry, use 800-grit sandpaper to sand the top layer of primer until smooth. This leaves a smooth surface for the paint. Wipe again with wax and grease remover and a lint-free towel.
  4. Paint a thin base coat of gray on the Jeep. Cover all of the primered areas on the Jeep so that no primer can be seen. Allow the paint to dry.
  5. Go over the Jeep with brown paint, spraying small areas of brown paint in no particular pattern. The finished effect should look like the Jeep is equally painted gray and tan. Hold the first stencil against the Jeep and use black paint to fill it in. Move the stencil over and paint again. Start at the front of the Jeep and work towards the rear.
  6. Move on to the next stencil and use light tan paint to spray the grass pattern. The grass should start at the bottom of the Jeep and reach up towards the top. For longer grass, don't spray the tops of the grass but instead move the pattern up, spray the stems longer and then spray the tops, making the grass stems long. Repeat this around the Jeep and across the hood. Go back over the grass stems with black paint, lightly spraying a few of the stems to give them a shadow look.
  7. Finish by spraying three coats of clear coat paint onto the painted areas of the Jeep. This protects the paint from UV rays and keep the camo pattern looking good.
Tips & Warnings
  • Paint is best applied using a paint spray gun and air compressor, but canned spray paint will work.
  • Never sand or spray primer or paint without using a painter's respirator mask.
Resources: Customice Camo Stencils
I really hope help you with this (remember rated this help) Good luck.
Oct 21, 2009 | 1984 Jeep CJ7
NRS KIRBY UG/DE&G3 SPRAY GUN ASSEMBLY Logo
168 people viewed this question
Top NRS Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
 Kenneth
Kenneth
Are you a NRS Air Tool and Compressor Expert? Answer questions, earn points and help others
