Kindly provide the following technical data for York Air Cooled Reciprocating Chiller Model YEAJ65ES7 (50 Hz Power Supply, Twin Compressors JS 63 + JS 44 Models) a) Nominal Capacity? b) Power comsumption at full load at ARI Parameters? c) Power comsumption at 20%, 40%, 60%, 80% at ARI relief parameters? d) Provide Technical Manual e) Provide Operation & Maintenance Manual
SOURCE: SYSTEM NOT SWITCHING ON
i have same problem checked fuse was ok. Just went to turn on and system was dead. I would like to get some basic voltage values I could probe the power supply for.
Posted on Oct 14, 2008
  • 87 Answers
SOURCE: Code : M3
I think that is for waste toner bottle it is full just clean or change it .and reset all counters .MIAN AKHLAQ
Posted on Dec 31, 2008
  • 15 Answers
SOURCE: minolta Ep4000 show CodeM2
Set the copier into Tech. Rep. mode by pressing the following keys in this order : utilty meter count stop 0 stop 1 then from the menu select counter then select Maintenance select the conter then enter anew value from the 10-Key pad
Posted on Apr 11, 2009
shastalaker7
  • 1515 Answers
SOURCE: part no. expansion valve of Air cooled chiller
On a chiller with semi hermetic compressors can have different types of thermostatic expansion valves for metering. As far as a number, you will have to go to the evaporator to look at the tx valve and get the numbers. It may be a single ported, double ported, be externally equalized or not. You have to get the copper line sizes in and out also if you are planning to change the valve out. The valve will also have the type of freon the system uses if for some reason the data plate is worn off. That's the place to always find out is the expansion valve. If you need information other then what I have given you, contact me and I will help you.
Sincerely,
Shastalaker7
Posted on Mar 15, 2010
taminol
  • 62 Answers
SOURCE: konica minolta Bizhub C350. Following message
Hi katienash,
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.
Good luck
Regards
m-press.biz
Posted on Feb 25, 2011
York chiller YDAJ model chiller compressor trips in low oil pressure after running for sometime. To solve it i changed the oil & the oil transducer but still tripping what can i do
You could be light on charge or the oil pump is failing. There may be a delay setting that is set incorrectly. I see that with several 507 systems.
Nov 29, 2014 | Air Tools & Compressors
Ingersol rand single phase t-30 compressor with twin cyl slow/ dragging
Quincy QT-5, with an 80 gallon tank. I was very patient and found this on CL. If you are flush with cash, do as you wish. If you are looking for the best bang for the buck, CL will produce!
X2 on the CL find....
Picked up a basically new Ingersoll Rand, T30 220v/2 stage for $500
Increase Engine Horse Power.
Jun 04, 2012 | Ingersoll Rand - Rand Type - 30...
I have a Ingersoll Rand en6f75 compressor. Does it have to run in a particular direction as I cannot see any direction arrows on it.
We provide tech manuals for all of our products at www.irtechpubs.com. We also supply technical information on our website www.ingersollrandproducts.com. Hope this is helpful.
Ingersoll Rand Employee
May 13, 2011 | Ingersoll Rand - Rand Type - 30...
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
Can ypu please tell me the weight of the next chiller: MODEL: 50TJ-028-6B1YA SERIAL: 2806U15500 Or technical information Thanks
DEAR SIR
CARRIER STANDARD EFFICIENCY AIR-CONDITIONER,S DATA ARE GIVING BLOW:
Specifications:
ELECTRIC/ELECTRIC, HEATING & COOLING 50 SERIES - CONSTANT VOLUME, VERTICAL SUPPLY AND RETURN
MODEL
NUMBER
NOM
TONS
NOM
CFM
NET
COOLING
(Btuh)
NO.
COOLING
STAGES
EER IPLV
TOTAL
kW
HEATING CAPACITY (kW)
(kW@ 460/3/60) WT
(lbs)
DIMENSIONS
(in.)
Length Width Height 50TJ028
25
7,200
268,000
9.3
30.9
32 / 55 / 80
1,850
86.125
83.5
47.25
HOPE ANSWER THE QUESTION
THANK YOU
PLEASE VOTE1
Sep 29, 2010 | Carrier 50TJ028 Rooftop Electric Cool Air...
Sir, we have 5 IR compressoors in operation in our station for catering to compressed air need for starting of emergency diesel generators. Though the performance had been satisfactory for the past 25...
NRV's and discharge valves often fail due to dirt and oil carry over. Carbon build up can cause problems with the discharge valves also. The 242 pump is a very reliable pump that gives little problems. Have these pumps ever been rebuilt? If so how long ago. What type oil do you use? I would use a synthetic oil like t30 all season. This will help with carry over and carbon buildup. Are these parts being installed correctly? Use OEM parts. After market often don't include keepers,screws or other hardware.OEM has all the necessary hardware to correctly replace the valves.
Aug 31, 2010 | Ingersoll Rand - Rand Type - 30...
What type of oil does this unit take?
Air compressor oil. I prefer synthetic, but you can use regular compressor oil also.
Jun 26, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Part no. expansion valve of Air cooled chiller
Sincerely,
Shastalaker7
Mar 15, 2010 | Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
