Question about Intel ASUS P4SC Socket 478 Pentium 4 Motherboard w/ Audio LAN - P4SC-LAN-DP
Doing a clean install windows xp home. It shuts off each time I choose the "install windows" comes up; it simply turns itself off
  • 68 Answers
This problem is due to your MOtherboard.
Sometimes you can have successful installations but in a few days it will just shutdown. Try to Get a new Motherboard.
Unless if its new its another story. If its new, try to remove the CMOS battery and wipe it with some cloths and put it back again. and Turn your Machine on.
Hope that helps.. And if so please rate this.
Posted on Sep 03, 2010
I can not upgrade windows, javaor my restore point/ what can I do ?
Windows XP comes in two editions: Home and Professional. The Home edition is intended for a casual computer user while Professional is intended for an office context. If you are experiencing slow performance in Windows XP Home Edition, you may want to reboot the operating system, which is defined as simply reloading the operating system by restarting the computer.
Turn off all peripheral devices connected to your computer, including speakers, printers, scanners and external hard drives. Click the "Start" button located in the bottom left corner of the desktop and select "Turn off Computer." From the "Turn off Computer" menu, select "Turn Off." Allow the computer to completely shut down. Give the computer sufficient time to rest and make sure that there is absolutely no noise coming out of the computer. Unplug the power cord from the power source and wait at least five seconds. Plug the power cord back into the power source. Turn the computer back on by pressing the "Power" button on the computer and wait for Windows XP to reload. or factory settings Restart the computer. Press the "F8" key after the computer reboots but before the "Windows" logo appears on the screen. You should now see the "Advanced Boot" menu. Scroll down through the menu options using the down arrow key. Stop when "Repair Your Computer" is highlighted and hit the "Enter" key. Select the language you wish to use and press the "Enter" key. Type in the computer's administrator ID and password. Press the "Enter" key. Scroll through the options using the down arrow key. Choose "Restore (name of computer manufacturer) Settings." Press the "Enter" key. Choose "Yes" when asked if you want to reformat the hard drive. Press the "Enter" key to begin the reformatting process. The process takes a few minutes, so be patient. Do not turn off the computer or attempt to stop the process after it has begun, or this may result in major damage to the hard drive. Choose "Finish" and press the "Enter" key to restart the computer. The computer will restart with the original factory settings.
Hope this helps.
Jan 18, 2013 | Microsoft Windows XP Home Edition
0x0000008E (0xC0000005,0x805D946E,0xF78032FC,0x00000000)
Remove all USB attached devices like drives. You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode. To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time. Re-install Windows. Clean install works best, but all data will be lost. Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Dec 11, 2012 | Microsoft Windows XP Home Edition English...
I has delete file on memory's intermec cn3, How to recovery file ?
REPAIR YOUR OPERATING SYSTEM AS FOLLOWS
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
Apr 20, 2011 | Computers & Internet
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
or
Apr 19, 2011 | Microsoft Windows XP Professional
Haha! I deleted folders inside the Local Disk C:\Program files then after that the computer would always ask to restart it, every time I try starting it. Huhu Help, and these folders are not inside the...
or
Apr 18, 2011 | Computers & Internet
MICROSOFT WINDOWS XP PROFESSIONAL BLUE SCREEN
Only ever trust Microsoft updates. You could try doing a system restore to a point before this happened if that doesnt work i would boot PC from XP Home CD and choose the repair install option. You wont lose any programs or documents by doing this but no updates will be installed which in yourposition is a good thing. If all above fails its down to a format and complete reinstall. If you have anything i would backup before doing anything just incase. Good luck from Scott
Mar 15, 2010 | Microsoft Windows XP Professional With...
My computer was fixed by a person who installed xp pro on it but he didn't have a validation key. Well i found my original install cd with the xp home edition and i want to do a clean install to install...
really simple just turn put the cd in turn off the pc and reboot, your cd drive should pick it up on boot up from there its simply following directions
Jun 24, 2009 | Computers & Internet
Acer Aspire T180 PC Desktop
if you have windows 98 boot disk put that in, the firt thing you do is to go to f-disk and change the partions in it, then format c: drive. take out disk in A drive put in New windows XP CD and restart. the disk will run and install itself. and thats it. right now your partions are set to read only windows 95, 98, there are 2 options to choose from I belive the one you need is 32.
Dec 17, 2007 | Acer Aspire™ T180 PC Desktop
Pc gone dead
Do you have the recovery discs that originally came with the computer? If you do, I would use these to reformat the hard drive and reinstall windows. This would be the fastest option.
To do this:
Insert the disc into the CD-ROM
During boot-up and before the 'Use last known good configuration screen' you're speaking of, it'll ask you do 'hit a key to boot from CD' -- Do so
Follow the on-screen instructions. Your objective is to clean the hard drive completely (reformat) and reinstall windows (recover).
If you do not have the recovery disc that came with the computer, you can use the exact same steps above with a Windows XP disc. Be sure to 'format' and 'install' windows--not just 'repair.'
Doing the above will make you lose all information on the computer, but at least the computer will then be usable. If there is information on the computer that simply must be saved, there are ways of doing that as well; but the explanation will be a bit more in depth.
Nov 13, 2007 | Computers & Internet
HELP: Activesync XP Reboot Problems!
Now don't laugh :-) on win 98 windows - I'm told - had a certain limited ability to fix itself. I don't know if xp does or not. Anyway on 98 if you ran into a problem you could let it reboot three or four times without doing anything but booting and shutting down - it at times would correct itself. This was normally on boot problems, but it might do some good - don't know of anything else to suggest. In your case I'd try this then try running active sync two or three times without doing anything else. Anyway that would keep you busy till a good tip comes along :-)
Sep 06, 2005 | Casio Cassiopeia E-115
Intel ASUS P4SC Socket 478 Pentium 4 Motherboard w/ Audio LAN - P4SC-LAN-DP Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
