Question about Garmin nuvi 260W GPS Receiver
My GPS keeps reseting itself! I turn it on, the Garmin sign shows up and it dies! and then I turn it on again and it dies again! So, I cannot use my GPS at all! It was working just fine and its been couple of days that it is doing this!
  • 466 Answers
A file might have corrupted on the system.
If you uploaded some POI file just before the crash, it might be a defective POI database. You can delete it by booting in test mode (turn device off, press on the lower left corner, keeping pressed turn the device on, wait for the test menu to appear. If the unit stays on, you can connect it to a computer and see its memory, locating the poi.gpi file in the POI folder. Move it on your computer (just to have a backup; one never knows), safely remove and disconnect the USB device from the PC and power cycle the Nuvi).
Assuming it's not the POI, you will have to perform the Firmware Restore on your device (or you might install the newest firmware from Garmin, as well). When in Test Mode (see above), the Garmin Web Updater function should work: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Also, you may try a Master Reset:
http://www.gpsdiscussion.com/garmin-gps/2183-your-nuvi-having-trouble-picking-up-signal-acting-lethargic-do-master-reset.html
Posted on Sep 01, 2010
Garmin forerunner 205 will not stay OFF and none of the buttons respond.
Yes you can restore your data from the TC after a hard reset. You have to go thtrough the setup menu like chose which language etc first.
Well I have exactly the same problem as you and a hard reset did not work either ...
Upgrading / downgrading the firmware also did not work.... the thing keeps on switching itself on regardless....
Do you have found out something more in the mean time?
Feb 16, 2012 | Garmin Forerunner 205 GPS Receiver
I have recently purchased the Garmin nuvi 765T and I have charged it and waited to use in the car but after a few seconds of turning it on, it turns itself off after showing the "Garmin" company...
Try to soft reset it by holding the power button for at least 20 seconds till it restarts.
If that doesn't help - try a master reset to factory defaults by holding the lower right corner during startup for at least 20 seconds. This will erase all user data and starts the Garmin in factory default.
If it restart I suggest updating the software to the latest version on Garmin.com
Jul 04, 2011 | Garmin nuvi 765T GPS Receiver
My garmin turns on but freezes when loading maps. I tryed to reset but did nothing.sometimes it will stay froze and sometimes it will turn itself off.serial #12p238176
Clear all ur installed apps/data/music/pictures first. Turn the unit off and then on. while on, reset it again. turn it on again and now connect it ur PC to load additional maps and see if it helps.
thanks
Aug 11, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin 250w keeps resetting itself, GARMIN logo comes on and then as to press dot, then reset and GARMIN logo comes on again. Try soft reset, still reset itself. Unable to upgrade firmware because...
Probably needs a new logic board at this point. If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult.
May 10, 2010 | Garmin nuvi 250W GPS Receiver
Format my gps usb restart show logo and restart
Well to avoid this problem you can do a hard reset, that reset set all the settings to factory default and it again format in fat file system, Turn the unit off. Hold your thumb on the bottom right of screen and turn it on, keeping your thumb there. Say "Yes" when prompted. Please post comments if further you have the same problem......
Good Luck!!
Thanks
Feb 15, 2010 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My uncle died and in his will, he left me a Garmin Nuvi, but he died before giving me the code or location, so I can reset the code, can you help
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Oct 17, 2009 | Garmin Nuvi 350 Car GPS Receiver
Shuts off, won't charge battery
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 26, 2009 | Garmin StreetPilot C330 GPS Receiver
Black Screen to no power
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Garmin nuvi 260W GPS Receiver Logo
271 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
