Question about Refrigerators
Water leaking from inside of refrig.I think it could be Ice maker
Water dripping bad down on the top shelf from vent holes in the top of the frige.Whirlpool- Model ET8CHMXKQ 4 Serial#ER1429506 Date MFG 04-04 How do I fix it .Thanks Harry D.
  • kalebdoc May 10, 2008
    When I shot the ice maker water off it only drips real slow now but still drips water.Thanks Harry.
  • Anonymous Apr 26, 2009
    same problem
    Genius:
  • 1,073 Answers
Defrost the freezer drain tube with a hair dryer
Posted on May 09, 2008
Water collecting on top shelf of refridgerator
Your defrost drain line in the freezer has stopped up. The defrost water is coming in through the air vent to the fresh food section.
Turn the unit off and use a hair dryer to defrost the drain hole located behind the freezer panel.
Jun 21, 2011 | Kenmore Top Freezer Refrigerator
MY ROPER FRIGE IS LEAKING WATER FROM THE FREEZER TO THE TOP SHELF IN THE FRIGE
the drain tube from the freezer to the lower compressor area is plugged with ice or debris,and when it defrosts the water in the drip pan behind the evaporator back cover inside the freezer thaws and cant drain down and overflows down thru the damper vent door to the refrigerator,remove the rear panel inside the freezer shut off unit and let thaw,then take a wire and work it down this drain hole till water comes out at the bottom of this drain tube located in the rear
Mar 19, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Water leaking from top rear left of refrigerator and dripping on coil line in the back of unit. Inside is dry and no water on floor yet. Is it the ice maker connection? If so how do I access it?
You will have to remove the ice maker , to have access to the fill tube . Only 3 screws , hold the ice maker on . After removing , make sure the tube is not frozen inside , and that it is securely , pushed inside the fill tube holder . If frozen inside , then the water valve behind the refrig , where the wall water line connects to , on the refrig , will need replaced also , due to " seeping " , not closing completely , after filling .
Dec 20, 2009 | KitchenAid Refrigerators
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dripping down on top shelf of refrigerator compartment.
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 18, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Water dripping from freezer when defrost kicks on.
You probably have a plugged drain in the freezer compartment. Open that up and check it. Hope this helps!
Feb 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
829 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
