Question about Canon ZR300 Mini DV Digital Camcorder
Capturing Video from Camera to PC
The problem I am having is transferring the video from the digital camera to the computer.
When I try to capture the video from the camera to Premiere the option says the device is offline. The computer is not picking up the camera. I know the camera is able to transfer the data. I have created DVDs before.
So, what do you advice me to do? Is it a hardware or software problem? What options do I have?
    Novelist:
  • 130 Answers
It sounds like it could be a hardware issue. You may need to check under your computer to see if the camera is showing up there. If it's not, check your device manager to see if the camera shows up there. If it shows up with a yellow icon next to it, you may need a driver and you can try to update it via the automatic update by right clicking on the device. Also if you have more than one device showing up there, you may want to disable or power off the other device and any other imaging software that may be conflicting with the connection.
Hope this helps!
Posted on May 30, 2008
What cable do I use to connect my Canon ZR800 to my MacBook Pro 13" to download the video? Thank you.
It is your USB cable you will use to transfer your videos from your camera. Connect your camera to your computer. Play the video. As the video begins to play you will select “capture” from the menu (depending on the application you are using to playback the video). Adobe Premiere and Ulead Visual Studio are very good for capturing/downloading videos from camera. The fact is video editing applications are perfect for capturing. Please note Downloading videos from camera is always achievable only by “capturing” and to capture a video you must play it back. You cannot download videos like mp3s by simply copying.
Dec 08, 2009 | Canon ZR800 Mini DV Digital Camcorder
Faulty playback after transfer to PC - Kodak M1033
1. Try playing the same vedio in camera itself. If it plays well then there is no problem in camera and also in capturing.
2. If playback is problem in camera itself, then try resetting the camera back to factory setting.
3. If problem is not with your camera, then try playing those vedio in players like klmegacodec or VLC player. Because most of the vedios captured in camera or mobile phone finds difficult to played on normal media players in system.
Aug 12, 2009 | Kodak EasyShare M1033 Digital Camera
When I copy a film from my camera to my computer I couldnot get the voice( the audio)part , only the movie transfers how could I transfer both. Even if I connect it perfectly I couln't hear the voice only...
Dear sir,
Welcome to fixya customer Support
We will help You.
I think u r transfering movies or videos wrong way.Actual Procedure is Like this
1.First Connect the camera to the Video capturing cards or Ports of computer.
2.Open Video Capturing Application installed in your pc (comes along with Your capturing device)
3.then Play the videos in Your Camera
4. Then Start Capture in computer.
This is the actual way of capturing Videos to the PC.I think it helps
If it is not Just check the camera audio video jacks.Adjust the TV system(PAL or NTSC) in camera and PC.
If it is not solves u r Problem.Come back with further Information.
Good Luck
Thanking u
for Choosing Fixya Customer Support
Chandrashekhar
Jul 14, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
No sound after capture on computer
Can you tell my from the menu on the camera how you connected it to your computer?
Apr 02, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
No sound when capturing video from Handycam to computer
There is no sound carrier on an S video connection. It's Video only. use the AV left and right cables for the sound. It is normal not to monitor audio when capturing.
Dec 02, 2007 | Canon ZR60 Mini DV Digital Camcorder
Can't transfer video from cam to pc
While capturing the video you have to change the Video mode to PAL or NTFS mode & store the Video's in Memory card,
When you want to transper the video's, remove the card or directly plug in to the camera to Computer USB port
Now you can transper the Movie's easily..
Try it out.
good luck..
Dec 02, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Video capturing
You might need a specific driver for this camera. Do you know if you've installed a driver specific for this camera?
Sep 09, 2006 | Ulead Videostudio 8 for PC
Putting video footage on my computer
To get your footage into the computer from DV tape you need a four pin firewire (IEEE1493 or iLink) cable from the camera to a six pin cable into the computer. USB will not do a proper job, it's for downloding photos or as you already mentioned, Web caming.
Sep 15, 2005 | Panasonic NV-GS50 Mini DV Digital...
Transferring analog to DVD
I envisage two options for you: 1. Install a video capture card in your pc. Choose one that has ports that match your analog camcorder ports. Best option: Separate capturing using S-video + a separate audio connection. Common and simpler option: Campture "composite" video using one video + one audio jacks. You don't need a new camera to make DVDs from your analog tapes. 2. Buy a pass-through (must be this type, not all digital cameras have this function!) digital camera. Connection and flow: analog camera (or your analog VHS VCR)to digital camera (via RCA cables); digital camera to pc (preferably using Firewire)- all simultaneously. Here, the digital camera will perform the function of a capture card. You will certainly need a software to capture via capture card/pass-through digital camera to your pc hard disc. Your captured video on pc can be initially in AVI/ DV AVI(better options to edit) and then convert to MPEG2 (DVD) format, or directly in mpeg format (with poor editability). Frame size (capture resolutions) should be as big as possible. In any case you will need some basic knowledge on digital video, capturing, and editing. And all the nitty-gritty that you will need to know can be found somewhere like "Digital Video Primer" and "DVD Primer".
Sep 06, 2005 | Panasonic AG-185 Camcorder
Can I connect my VHS-C or S-VHS-C camera to my computer?
Since VHSC camcorders feature only analog outputs: it is not possible to connect the camcorder directly to a PC (unless a computer video card is equipped with analog inputs). The only way to transfer images from the camcorder to a PC will be using an external device capable of analog/digital signal conversion. JVC has released a capture device model, GV-CB3U which has the capability of video capture of a single frame in either Bitmap or JPEG format. The GV-CB3 can be connected to any video source through a standard video or S-Video connector and download single image to a PC using serial port (RS232C communication port). The JLIP Video Capture software necessary to transfer images to the computer as well as connecting cables are supplied with this product. You can also use 3rd party hardware (Video Capturing device) to send information from your camera to a PC. Visit your local PC or Office store for more information on other video capturing devices.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Canon ZR300 Mini DV Digital Camcorder Logo
228 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
