Question about Acer Aspire 55421462 Notebook
DC connector loose in laptop,no power in the laptop
  • 734 Answers
Hi There,
I deal with this problem often for my local clients. I used to disasseble and repair or replace the Dc Power Jacks but you have to remove the motherboard and know your soldering well to do so. Nowadays, I just send all laptops with this problem in to any one of several different repair vendors on eBay.
Go to eBay and in the search box type, Laptop DC Power Jack Repair. You'll find a host of reliable companies there and with the repair and shipping you should expect to pay around 80 to 100 dollars. If you can find someone locally you trust to do the replacement for less then take that route.
Best Regards
Posted on Sep 01, 2010
  • 466 Answers
Apparently the DC connector broke. If the warranty is still in operation, have it repaired; else, the damage can be easily fixed by any electronics shop, or even by yourself if you're familiar with a soldering iron for electronics. This guide is for a different model, but the DC section is practically the same in all laptops:
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/
My Q430's power connection is loose and not changing battery. Do I have to swap out motherboard?
The DC Power Jack is the jack you plug the AC adapter (Charger) into. (DC_IN)
The DC Power Jack for the Samsung Q430 series of Notebook PC's, consists of a;
1) DC Power Jack, which is connected to two wires.
2) The wires end in a small male plug connector.
It is now a DC Power Harness,
http://www.laptopjacks.com/part/Samsung-Q430-DC-Power-Jack-J-SM371300C1.html
FOLLOWING Anti-Static Procedures, the laptop is disassembled far enough to unplug the DC Power Harness, and plug a new one in.
Regards,
joecoolvette
Sep 10, 2011 | Samsung Q430 Laptop
No power! power cord is good, but when inserted in the charging jack(laptop) the inside is loose and no charge is being sent to the battery. How do I replace the inside thing so power can be sent to the...
Here below is a guide about how to repair laptop DC jack, may it will help.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Jan 20, 2011 | Balance Computers & Internet
Computer is not charging the battery.
Your DC connector is probably loose from the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 05, 2011 | ASUS F8Sn-C1 PC Notebook
I have an ASUS eee netbook. Recently the power cord hasn't been connecting well to the computer and now it doesn't even register. It's plugged in but isn't charging. Is it the cord or the laptop?
You have a bad DC connector, which came loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
Here is a tutorial on how to fix a DC connector problem. You may want to have a tech fix it.
Nov 30, 2010 | ASUS Computers & Internet
My elitegroup laptop was no power at all, then the pin positive is shorted to pin negative
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Oct 09, 2010 | EliteGroup G320 Notebook
My acer aspire 3680 could not power on by bat and adaptor
DC Jack diagnosis:
Oct 08, 2010 | Acer Aspire 3680 Laptop
I have an Acer Aspire 7736z which wont charge. Ive already found that the battery connector/battery pin/battery port whichever youd like to call it has snapped off. Any information on how to fix it? where...
DC Jack diagnosis:
Sep 28, 2010 | Acer Computers & Internet
The ac power plug was broken loose on my sony vaio vgn fw140e and finally the laptop failed to power up. I'm pretty sure the power adapter came loose from the mother board . I just don't know how to fix...
Sep 09, 2010 | Sony VAIO VGN-FW140E/W Laptop
Power socket is loose
dc jack socket for Sony VAIO VGN-FW is very easy to loose, I think you can replace the cabled dc jack, no solder work, plug in and work, see this reference page: http://www.lapdiy.com/sony-vaio-vgnfw-series-power-jack-port-connector-dc-in-cable-p-2647.html
the above item is with ground cable, it is known that sony FW uses both harnesses with or without ground cable, you can cut the ground cable directly if your laptop does not use it, or order from this page for the one without ground cable: http://www.lapdiy.com/sony-vaio-07300012492a-power-jack-port-connector-dc-in-cable-p-2782.html
hope this can help you
Feb 04, 2010 | Sony VAIO FW Series VGNFW275JH
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
You have either a faulty connector plug on the power adapter which connects into the laptop or the loose power input socket on the laptop is faulty. This is because you need to press the connector upwards to make electrical contact.
Test the connectot plug on the power adapter with a multi-meter, wriggle the connector to see if your get the voltage to fluctuate, if it does not then the connector is OK anf the fault is in the laptop power input socket.
If the fault is in the power adapter plug or the laptop's power input socket, this can be repaired, a techo would have no trouble in repairing these faults.
May 22, 2009 | Dell Inspiron E1505 Notebook
Acer Aspire 55421462 Notebook Logo
140 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
