HP Photosmart C6180 All-In-One InkJet Printer
Problem for HP Photosmart C6180 All-In-One InkJet Printer
HP Photosmart C6100
By FROGPRINCE on May 09, 2008
I sent a request for help to fix my photosmart printer c6100 which just stopped working all of a sudden and no-one has given me any solutions yet.
Clarification Request
Posted by Khalsa007 on May 26, 2008
i would like to know has the machine stopped printing or copying , scanning > which function is not working.
Solution #1
posted on Jun 05, 2008
Somewhat Helpful)
B00mshankar
Rank: Wiz
Rating: 86%, 20 votes
hi try to reinstall the drivers from HP website directly..
uninstall the drivers and software and then reinstall it..
if your printer is not powering on then check the power cable unplug it and press the on button for 15 seconds..
Was this helpful?
Yes
No
Solution #2
posted on Nov 02, 2008
Not Rated)
Khalsa007
Rank: Wiz  HP Expert
Rating: 83%, 69 votes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
You can try to reset the unit to its factory defaults by performing the following steps .
unplug the power cord from the back of the unit without turning off the printer.
press n hold # key and 6 key together n do not release the keys ,while holding them down plug in the power cord back into the unit.
wait for a few seconds as it would make certain noises and turn off , when the unit turns off release the keys .
after a few seconds turn on the printer , wait as it wud go into initialisation mode > might ask to press 1 for language (please follow instructions ) it would give 2 or 3 allignment sheets.
5
after its done try to copy.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} note - after the RESET fax seeting are to be done again as it goes to factory default settings .
Thanks
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart C6180 All-In-One
Questions and Unsolved Problems for HP Photosmart C6180 All-In-One
Do you recommend HP Photosmart C6180 All-In-One InkJet Printer?
Answer
Answer
I replaced an ink cartridge and the ink gauge still indicates it as being empty.
Answer
can't get my photosmart c6180 to print on the 4x6 photo paper it wants to use the regular paper. ... (More)
Answer
Following the instrcutions I have placed a document under the glass, pressed scan menu, then wen to... (More)
Answer
improper shut down, now the printer will not start up
Answer
Had a message to replace yellow ink cartridge. Replaced the cartridge and still receive the same... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
