Question about Panasonic Televison & Video
My Panasonic NV-SD250 VCR displays FO4 message. The unit refuses to eject tapes.
  • Anonymous Mar 13, 2014
    Show fo4
  • Panasonic Master
  • 17,130 Answers
Possible fault with the failure of the servo system, the mechanism , front loading and forward loading or the failure of the drum servo/capstan servo.
You can remove the front panel and top panel and remove up the loading mechanism by unscrewing the mounting. carefully disconnect the cylinder head strips, the audio connections and remove. manually turn to unload off the tape. then check for belt failure or visible errors. Now set back use a dummy cap to cover the end sensor emitter at the centre and manually push the loading mechanism assisting . If there is no loading the capstan is faulty, if it loads and the drums does not work it is tthe cylinder servo.
You will need some knowledge of the circuits to proceed to the correct fault.
Posted on Sep 01, 2010
Error message E3 displayed
Its telling you to get real and purchase a new device.
Nov 11, 2013 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Nv-hv60 panasonic gone dead
Its dead...what can't you understand here?
Feb 02, 2013 | Panasonic NV-HV60EB VHS VCR
I have a VCR Panasonic NV - FJ623 and when I insert a video cassette into it for playback or recording purposes,it always ejects the video cassette.Can you help, please?
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
Oct 22, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
VCR does not play.. It keeps ejecting the tape
Does it eject right when you put a tape in? Or when you press play? Does it fast forward or rewind? if not a belt may need to be replaced or an idler tire is worn.
Jun 16, 2010 | Panasonic NV-HD680 VCR
Panasonic NV HD620 Error F06
You appear to have a model that uses the K Deck Chassis.
F06 in that case stands for: "Mechanism locks after unload". The cause being either the loading motor or the carriage alignment.
May 07, 2009 | Panasonic NV-HD680 VCR
How to time loading arm cogs on VCR?
Most Panasonic VCR use a mechanisms with a letter. For example the NV-HS900 uses a K Deck. What you need to do is type the model number into google and search for which deck it uses. Then with luck you might also find the instructions for setting the deck up correctly. I got the K-Deck one free.
Jan 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Tape wont play then ejects
I am this problem... please download service manual *pdf... jedlicka.j@gmail.com
Thanks
Oct 14, 2007 | Panasonic NV-HS1000 S-VHS VCR
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
266 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
