Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Hdd is not showing in my computer - Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
  • 11,800 Answers
In that case it has died and can't be repaired - just junk it and buy a new one.
Posted on Sep 01, 2010
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
Transfering data from old HDD to new computer
Go to folder option . there uncheck hide system protected files and check show hidden folders . Then connect the HDD and go in . There you will have all the access .
Aug 18, 2012 | HP Computers & Internet
My computer burned 2 hdd
After i Read your Explaination,i really sure if the Problem is at your Computer POWER SUPPLY.
Change your Power Supply to Higher Watt.
i Recomended to you to Using SIMBADA Power Supply ATX.
and to Fix your HDD bad Sector,Try to use LLF (Low Level Format).
LLF will destroy all data and Partition.So after you Format using LLF,you need to make a New partition at your HDD.
LLF is Working for me to Fix Bad Sector in a So many times.
Jan 18, 2012 | Gigabyte Ga H55m D2h Desktop Motherboard...
Have installed two new SATA HDD's, but don't show up in CMOS
Just a tip: Your OS shouldn't be on RAID. RAID is for storage.
If it is a software RAID you will need to load drivers
Even if they are disabled in boot configuration, it will show them as being attacked. You should have two areas in your BIOS/CMOS for configuring & enabling, along with setting order of boot.
Apr 15, 2010 | Vision Computer VisionMan Pentium D 830...
Samsung R65 HDD not detected in bios
Chances are that your HDD is on it's way out the door; even if you get it to come up on another computers via USB adapter. There could be issues with your motherboard, but a faulty HDD is more likely. The only way to be sure is to put another HDD into your computer to see if it shows up or not. If it shows up, then that pretty much affirms that your current HDD is going bad. See MADHATTER COMPUTERS.
Mar 20, 2010 | Samsung R65 Notebook
I have hp d260 cpu, In my bios i have auto detect hdd settings, but it shows no hdd inspite of working hdd attached. when we tries to manualy detect the hdd it shows but as soon as we restart the pc it...
GO BACK TO BIOS AND SET TO LOAD SAFE DEFAUT SETTINGS.YOU SHOULD STAY OUT OF BIOS,ARE YOU A COMPUTER TECH PERSON.IF NOT STAY OUT OF BIOS OR LEARN THE HARD WAY........HOPE THIS HELPS!
Nov 30, 2009 | HP Computers & Internet
My computer shows to setup array and does not detect one hard disk
Please try to system reformat/reinstall OS to your HDD under SATA connection. then kindly check the jumper setting of HDD under IDE connection which I suggest to place it at Master while the SATA HDD will be automatically recognized as Slave by your computer. best regards
May 16, 2009 | ASUS Computers & Internet
USB HDD not showing in My Computer
It could be that the USB port on that computer is not delivering enough power.  Will your Drive accept external power?
May 12, 2009 | Computers & Internet
USB 2.5 inch HD does not show on PC
Data recovery software can only retrieve data if the HDD shows in windows. Some disks may not show in My Computer(if corrupted). Another way of checking if the HDD is being detected by windows is using disk management. Click Start,then run, then type compmgmt.msc. Click on Disk Management when the Computer Management box opens. If you HDD is showed among the list of drives there is a possibility of getting our data.If not you need advance data recovery where the HDD has to be physically taken apart.Let me know what your findings are.
Nov 10, 2008 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
246 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
