Question about HP Deskjet 2360 InkJet Printer
No power for printer. Power and printer cables firmly in place, but no power light.
  • HP Master
  • 17,130 Answers
The printer has an SMPS unit and can be faulty. You will need to open the printer and the power supply unit is housed at the point of the plug in of the power plug. Take the unit out, if the fuse is blown , check for short in the suge protector, the rectifiers, the filter capacitors or the SM driver,/ IC. replace the shorted component and the fuse .
The Sm transformer is a rare case too.but if there is short at the secondary section , the same issues of the power cut off can happen. So if primary side is Ok check on the sec. side disconnect to bring power back and trace.
Posted on Sep 01, 2010
My 6313 is dead
1st check your cables from the outlet to the machine........are all the cables firmly in place.
2nd check the outlet......do you have power coming to your machine.....(this can be checked by plugging something else into the outlet and seeing if t works).
Try these two things first, as further repairs will cost money.
Nov 06, 2014 | HP Officejet 6310 All-In-One InkJet...
My printer will not pring
1. Please check if the ink cartridge is empty or not. If empty or nearly empty, better to change a brand new cartridge as per instructions;
2. Please check if the printer driver installed in the PC is still damaged or not. Suggest to re-install the printer driver once again;
3. Please check if the printer cable (USB/Network cable) is connected firmly from the PC to the printer. If found loosen, please connect it firmly;
4. If you found the printer led light is not turned on even you have plugged the power cable correctly, please change another power cable for testing; or may be the power bar is not working properly;
5. After you tried all these steps and the printer still couldn't work, please disconnect it and send it to the Canon repair center for proper repair and maintenance. Please do not open the chasis of the printer by yourselves.
Jul 23, 2014 | Canon Pixma MP600 Printer
I replaced the black ink cartiridge now I try to power up printer and it wont power up what do I do?
First you can make sure the outlet you plug your printer into has electricity by unplugging the printer and plugging in a lamp or something to show the electricity is working. Unplug the other end of the power to the printer if it will unplug - so the printer power cable is unplugged at both ends.
If the electricity is okay then plug both ends of the printer power cable back in and see if the printer comes on. If it does not, lift the lid where you replaced the ink cartridge and see if you can remove and reinstall the ink cartridge. Make sure the latch holding the cartridge is firmly in place. Finally, make sure the lid is down and solidly in place.
Usually one of the above suggestions corrects the power problem. If not, please come back & remind us you have followed these suggestions and we can continue to try to correct your problem..
Good luck.................................Pete
Jul 22, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Why my printer doesn't work?
Things to check.
Check the power cable and the power switch is on. The power light ON.
Check the printer cable, conneced firmly in the printer and the computer.
Do a test print to test printer.
Try installing the printer driver again.
Mar 20, 2011 | Office Equipment & Supplies
Printer will not turn on the little light on front is on ther is pwer to the printer
Hi there !
Check the power supply if your accidentally plug your printer to 110 volts and surely it will not print and as you mention that there is a little on the printer.
If not turn off your computer. Turn your printer and remove the power supply cable from the power supply and to the printer and return the power connection back firmly. Turn on your printer and computer and try to print again.
I hope it helps you and thank you for using FixYa !
Jan 08, 2011 | HP Photosmart Premium C309g multifunction...
Where is the toner cartridge and how do I find it?
Plug the Lexmark 2600 into an electrical outlet and press the power button. Allow the unit to power up. The power button will turn green when ready.
Turn on the Printer and Open the top cover of the Lexmark 2600 by lifting the cover upward. you will find all cartridges down there.
Now you see how to replace them
Remove the black ink cartridge from it's packaging. Remove the tape from the black ink cartridge first and place the cartridge into the left ink cartridge holder. Press the cartridge down into until you hear it lock into place. Close the ink cartridge holder lid by pressing it down firmly. This secures the ink cartridge in place.
Remove the colored ink cartridge from the packaging and remove the tape from the cartridge. Place the cartridge into the right cartridge holder and press down until it clicks into place. Push down the cartridge holder lid.
Close the lid of the Lexmark 2600 and allow the print cartridges to align. The power light will be blinking while the cartridges are being aligned; once the power light turns solid, the printer is ready for use.
Do rate, if found helpful
Nov 27, 2010 | Lexmark X2600 InkJet Printer
Power is not coming .
Check to make sure the power cord is in an active outlet some times they may go bad. or also could be on a light switch. Ensure light switch is on. Also make sure if the wires connect to a power adapter that they are firmly in place. If it does not resolve your issue the printer may have went ka ~ poot! May not work anymore.
Oct 22, 2010 | Office Equipment & Supplies
Check power source. Also, if you have a voltmeter, check the power going into the printer. If all is good there, unplug the printer from the computer and try to power it on. If it powers up while not connected to the computer, this could indicate a problem with the USB cable or the port on the computer. Try another cable or available port (if you have one). If the printer is connected via an external USB hub, try connecting it directly to the computer instead. If none of these work, post back here & I'll assist you further.
May 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Wont turn on!
Unless the power cord is loose, it sounds like the unit is defective. There are two places to check the power cord. The 'brick' has to be firmly inserted into the back of the printer and the cord has to be properly fitting into the brick. If all is well there, it sounds like something more drastic is wrong.
Steve
Feb 26, 2009 | Lexmark X2350 All-In-One InkJet Printer
My Heward Packard desktop 932C will not connect to my Dell laptop
what kind of connectivity you are trying to connect, most connectors comes as a USB cables, this comes as a easy connector that should be no problem at all, pls follow this info...
This document describes the hardware setup for a new printer. Unpack the printer
  2. Turn the knob on the rear access door of the printer counter-clockwise.
  4. Push the module back into the printer until it snaps firmly into place. (Do not press the buttons on the ends of the module while replacing it.) c00107976.gif
Insert paper
  1. Slide the paper adjuster out as far as it will go.
  2. Flip up the OUT tray so that you can see the IN tray more easily. c00107977.gif
  3. Place up to 100 sheets of printer paper face down in the IN tray.
  4. Slide the paper adjusters to fit snugly against the edges of the paper.
Turn on the power
  1. Locate the power module for the printer.
  2. Insert the rectangular end of the power supply cord into the power outlet on the back of the printer.
  3. Insert the two-prong end of the cord into an electrical outlet. c00107979.gif
Insert cartridges
  1. Open the top cover of the printer. When you open the cover of the printer, the RESUME button will flash until you close the cover. The printer part that will hold the cartridges (called the cartridge cradle) moves to the center of the printer.
  2. Remove the ink cartridges from the box.
  3. Remove the tape from the cartridges. c00107981.gif CAUTION: Do not touch the copper contacts (on the back of the cartridges) or the ink nozzles (on the bottom of the cartridges).
  4. Lift the cradle latches inside the printer.
  5. Hold the black ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  6. Push the black ink cartridge firmly down into the cradle on the right. c00107982.gif
  7. Hold the color ink cartridge vertical, with the copper electrical contacts toward the rear of the printer.
  8. Push the color ink cartridge firmly down into the cradle on the left.
  9. Close both latches. When you push down the latches, you will hear a click and feel resistance.
  10. Close the lid of the printer. You will hear the sound of the cartridge cradles as they move to the right side of the printer.
Attach the printer Attach the printer to the computer with a parallel cable or a USB cable. Print a test page Turn the printer on and press the RESUME button to print a test page.
  1. If the RESUME light continues to flash, press it again.
  2. If the printer cable is firmly attached to the printer, then check to be sure that the printer cartridges are seated securely in their cradles.
  3. If the printer cartridges are seated firmly in their cradles, then check for any tape or packing material that you may have left inside the printer or on the cartridges.
  4. If you press the RESUME button for too long, you may print several test pages unnecessarily.
check it out.... goodluck
Jul 27, 2008 | Office Equipment & Supplies
HP Deskjet 2360 InkJet Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
