Question about Vacuums
Blocked vacuum hose
My new vauum has a wet sock stuck in its hose pipe
  • 328 Answers
You'll need a sturdy stick like a thick bamboo stick to push this out but remove the hose FIRST from the vacuum and compact the hose up before inserting the stick. Either that or you may have to order a new hose which can be cheap. What model is it you have?
Posted on May 09, 2008
There is a sock stuck in the hose of my dyson dc23 animal motorhead how do I get it out
Hi, this is Jim with Crucial Vacuum,
Detach the hose and stretch it out completely, if the sock is in a hard to reach place use a broom handle to push it out. Be careful to mind the edges of the hose you don't want to cause a tear, which would lead to poor suction.
You can purchase replacement parts for your Dyson DC23 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
May 08, 2015 | Dyson DC28 Animal Upright Vacuum New DC 28...
Was using vacuum and sock is now lodged in vacuum hose. How can I get the sock out?
The easiest way to remove an article of clothing from the hose is to remove one end of the hose from the vacuum, and reach in with a piece of wire with the end bent into a hook. A wire coathanger will work well for this. Just straighten out the coathanger, take a pair of pliers, and put a small bend at the end of the wire, in a J, or hook shape. Then, reach the wire into the hose, and when you feel the obstruction, twist the wire, so that the hook gets stuck on the sock. Then, pull it out, and reattatch the end of the hose back on the vacuum.
It doesn't matter which end of the hose you remove, just whichever is easier, and hopefully closest to the clog.
Do not try to push it out, as it will just bunch up tighter. It must be pulled out.
Jun 17, 2011 | Kenmore 31913 Progressive Direct Drive...
Does not pick any thing up
Check the filter and the hoses for blockages and clogging. If you can, **** backwards through the pipes to dislodge any foreign stuff stuck in them. See it there is suction when the hoses are removed, this will tell you if the hose is blocked. Also check the attachments you are using in case they are blocked. Using a vacuum that is not sucking means that there is no cooling air going over the motor and it will overheat.
Mar 22, 2011 | Filter Queen Majestic Canister Vacuum
Sock stuck in hose midway. Unable to getit out with wire or brrom handle. Is there a way to take hose apart at either end.
If the sock is midway, taking either or both ends apart won't help. Take it to a vacuum repair shop and ask them to try to unplug it. You may need to buy a new hose.
Feb 22, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
We have a DC 21 bagless. There's suction when the hose is not attached. When the hose is attached, there's no suction. We've tried to determine if something is stuck in the hose, but without success. Is...
If you suspect the hose is blocked, I would push stiff wire through it (gently) you dont want to puncture the hose.I have had so many blocked hoses in v/cleaners ( I service them) . try blowing through it. Sound silly but why not. I have had hair grips, paper, pencils, sweets, coins etc stuck in the bend of v/cleaner pipes.
Nov 22, 2010 | Dyson DC21 Bagless Canister Cyclonic...
Sock in hose???
just push a longer rod down the hose its the only way to get this out i bet its right at the hover end to and a wire hook may get at it from were the hose gos into the hover bag,(mine gets blocked up there every time)
i use a lenth of welding wire with a hook bent in it but a coat hanger would do if you straiten it out first then bend just the first inch of it so it fits inside the hose
Jan 19, 2010 | Electrolux Central Vacuum
My vauum will not pick up anything. i have checked all places.
Check your hose from the end to end, you have to have something stuck in there. If its clear then your motor is not vacuuming. Also is the belt broke that spins the brush?
Nov 06, 2009 | Euro-Pro Fantom FM740 Upright Vacuum
Sock stuck in hose
Yes there is a small clip on the purple/yellow part on bottom of hose. its hardly an inch thick pll back on the tab and up on the hose
Oct 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a sock stuck in the hose of my vacuum cleaner. Rennaisance canister model. Because of the design of the handle I can't utilize the reverse blower. Please advise. Thanks
Try taping a fishing hook or some such onto the end of a straightened out coat hanger. See if you can push it up the hose and hook the sock.
Or, remove the hose entirely, and push a broom handle down the hose.
That's all I got...
May 07, 2008 | Vacuums
Stuck sock
first off how did u get the sock that but yes it (can but it is a pain and u chance tearin the hose but if ufeel like u have to better get a roll of duct tape just in case)but i would try the coat hanger a little more put a bend at the very end of hanger hook the sock and pull
Dec 30, 2007 | Electrolux Lux 5500 Canister Vacuum
Vacuums Logo
150 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
