Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
Neff S4752 My dishwasher starts but only for 30 seconds it stops at the first request for water. I've checked the inlet filter and there is definitley water getting through. Is there a solinid somewhere that is not operating?
I had the same problem with mine. I ended up having to pull the dishwasher out from under the counter and tipped in on it's face. My problem was apparently with the pump motor. It would come on, and I knew this because I could hear the hum. Well when I pulled the dishwasher out from the counter I noticed the motor was extremely hot, which to me says there was a block in the pump's way. I pulled the motor by loosening the set screw, 10mm with a 1/4in socket wrench and extension, which is located on top of the motor. First you have to disconnect the power by squeezing the tabs together and pulling upward. After that a quarter turn counterclockwise will unlock the motor. Pull the motor back and check the screens and impeller. I cleaned the screens and manually turned the impeller. Put it back together by doing the steps in reverse, clean up any spilled water thoroughly before plugging it back in and re-plumbing. That solved my problem, good luck.
Posted on Mar 20, 2009
    President:
  • 1,314 Answers
There is a float in the washer a dome shaped piece remove the lower kick panel and check to see if the rod on the float is sitting on the water fill safety switch if its slipped off it wont fill if the switch is bad it wont fill if the solenoid on the water valve is bad it wont fill just follow the water line from the sink where it connects to the valve on top is the solenoid
Posted on May 09, 2008
Neff s5443x1GB/29 dishwasher starts and stops
The pressure chamber or hose (pressure chamber to sump) may be blocked and the microswitch is being activated because the water is not entering the tank quick enough. Isolate from electric, remove lid and left panel (looking from the front). There is a plastic chamber bottom right of left side with two microswitches, either this is blocked or the hose that runs from it to the right and along the back of the kick panel and into the sump. Clear either or both (make sure all hoses are pushed true when repositioning).
Apr 16, 2013 | Neff Dishwashers
The machine is on but the water has stopped coming through to it please advise
If the inlet tap under the kitchen is ok and the water pressure is ok, then it is possible the water inlet valve in the dishwasher is faulty. you can locate the part on this diagram.
Aug 03, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwasher is not working will not fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Jul 20, 2011 | Neff 24 in. S5543X2 Built-in Dishwasher
No water intake
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Daniel
May 06, 2011 | Neff Dishwashers
My neff dishwasher is not filling with water
Hello
Water inlet valve is responsible for filling water in your dishwasher, when that goes bad either the dishwasher wont fill at all or will fill the water slowly. Please check the inlet screens and also try to clean the water lines for any clogs/obstructions. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Neff Dishwashers
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
We have a neff dishwasher and the pump is draining all the time (even when the door is open) but there is no water in the dishwasher. Is there a way to stop the pump and reset the setting for the flood...
The water which has activated the antiflood device is actually underneath the appliance it is held in the sump tray and this has to be drained before the A.F.D.will cancel.You will have to remove the dishwasher to get at the underneath but when you have got rid of the water you will still have to trace what caused it.The seal on the circulation pump could be a suspect or a pin hole in the drain hose.
Hope this helps.
May 09, 2010 | Neff 24 in. S5409X0 Built-in Dishwasher
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Neff Dishwasher
Hallo Champer, 1)Be sure water supply is arriving with enough pressure. 2)If the hose between the crane and dishwasher has an aqua-stop ( or water-stop) which you recognize at the hose being enlarged twice the size close to the crane, possibly water supply can be blocked there. You can change it temporarily with a regular hose ( for garden or car-wash ...). If dishwasher is doing the job buy a new hose with Aqua-stop in a regular electro- household appliances shop. 3) If this solution is not the good one, you might check in fact to the inlet valve, which you find at the other side of the metal plate where the watersupply is flooding inside the diswasher. Generally a white coloured threaded plastic pipe. Unplug your dishwasher, close water supply (!) and disconnect the water hose. Open the dishwasher ( either top-plate and/or back-panel). Now you see the inlet-valve ; unscrew this one and mark the position of the 2 electrical wires, which you also unplug then. Also unplug the internal water drain, and ask again a regular shop (see 2) if they can check this valve and if necessary get a spare part. Oeffti, hopefully this helps else let know.
Nov 01, 2006 | Neff 18 in. S5943 Slim-Line Built-in...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
233 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
