Question about Mag Innovision InnoVision LT 765S 17" Flat Panel LCD Monitor
SPEAKERS IHAVE NO SOUND FROM SPEAKERS WHICH I THINK ARE BUILT IN TO THE MONITOR MAG INNOVISION LT765S 17" LCD SCREEN PLEASE HELP! BETTY
  • Anonymous May 10, 2008
    built
  • Propfan2004 May 03, 2009
    No sound from speakers when stereo cable is connected from computer to monitor.
Does a MAG monitor model 900P have in built speakers?
Yes the Mag 900P has built in speakers. The audio lead for them is attached to the blue VGA connector and has a green tipped plug like a set of desktop speakers.
Oct 10, 2010 | Mag Innovision LT776s 17" LCD Monitor
MAG LT765s monitor, model 780; where do i plug in adapter
Sometimes the power adapters on flat screens face the floor. So, if you look under the screen under the stand, you will likely see the plug.
May 22, 2010 | Mag Innovision InnoVision LT765 17" Flat...
I have a MAG INNOVISION LT765s LCD monitor. When the computer boots up, the power button on the monitor won't stay on so the display won't come on. It sometimes takes an hour of fooling around with the...
I have had similar problems with my Mag LCD monitor. I recently dicovered that the problem was with the adapter and not the monitor. Try replacing the power adapter.
Sep 21, 2009 | Mag Innovision InnoVision LT765 17" Flat...
Intergraded speakers?
I have the LT765s and it has speakers. Don't know about the 765.
If it supports sound there will be two inputs, line in and line out, on the back. The "line in" jack goes to your sound card output.
Dec 23, 2008 | Mag Innovision InnoVision LT765 17" Flat...
MAG Innovision LT765S Model 780 = no audio
If your monitor supports sound (might have to be the LT765s product?), there will be two inputs on the back (to the right when looking at it from the back). One's labeled "Line in." This is where you'd plug the audio cable from your sound card.
Dec 13, 2008 | Mag Innovision InnoVision LT765 17" Flat...
Speakers
make sure windows volume control is up.
its the speaker next to the time and date ,on tool bar ,bottom left normally.
play a song or video or such.
then check the cable in back of monitor it has a plug/connector that looks like a headphone jack /plug
follow it to the back of computer its color coded.
be certain the speakers have power if needed they will plug into monitor dc jack if the speakers are removable.
and check the vol control on the speakers.
May 11, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
SCREEN DISPLAY BOUNCES UP AND DOWN
Check and make sure that the speakers and any power supply (UPS) are not placed very close to the monitor.
Feb 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision product # LT765s model #780
monitor is looking for the video signals--move mouse and try power on
Jan 07, 2008 | Mag Innovision LT776s 17" LCD Monitor
Connections
you will have a mains lead with an electric kettle type connection on one end which plugs into the rear of the screen and another similar lead for the pc.
the video lead from the screen will plug into a small dovetailed shaped connector coloured blue on the rear of the computer ( it can only fit one way round , as its broader on one side than the other )
the speaker leads will probably be small jack plugs one for left and one for right, and they plug into the rear of the computer, audio out / left / right.
Jan 05, 2008 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision InnoVision LT 765S 17" Flat Panel LCD Monitor Logo
255 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
