Question about Autodesk AutoCAD 2004 for PC
Configuration file may be locked by another process or have been set read only(cfg.bak)
What should I do to delete all configurations of the Huawei S2300?
To delete all the configurations, delete the vrpcfg.cfg file from the flash memory, and then restart the Huawei S2300 switch. The vrpcfg.cfg file cannot be deleted when it is running because it is used as the system file. To delete the file forcibly, perform the following steps:
1. Restart the Huawei S2300 switch and press Ctrl+B to enter the BootROM menu, and then enter the default password huawei.
2. Press Ctrl+Z to enter the hidden menu, and then select option 2 to enter flash memory.
3. Delete the vrpcfg.cfg file from the flash memory, and then restart the device.
Dec 25, 2017 | Huawei Computers & Internet
How to delete all configurations of the S2300?
More related:
Huawei S2309TP-EI-AC
Huawei S2309TP-EI-DC
Huawei S2309TP-PWR-EI
May 17, 2017 | Cell Phones
Barracuda web filter 310 was reset now, I have a backup .bak file how can I restore this file?
if the web filter recognises .bak files you should be able to restore it with that if not you can try to rename the extension to what the web filter recognises but this might make the file unreadable. First make a copy of the file so that you do not lose the original format. Best thing to do is write down your network configuration information and keep on hard copy so that in the future you will have a reference to fall back on. I know hard copy yuck but sometimes it is needed. There is software out there that you can map your network setup showing all devices and there settings.
Jan 07, 2014 | Barracuda Networks Computers & Internet
How can i open my account its been locked
If you ever want to allow Yahoo! Instant Messenger to be able to make updates, all you need to do is follow the process outlined above and change the file extension back to "exe" instead of "bak."
  • If you disable Yahoo! Instant Messenger, it will not make any Yahoo-sponsored updates to your computer until it the process has been reversed.
  • Read more: http://fixya1.blogspot.com/2011/11/i-click-on-yahoo-messager-it-opens-then.html
    http://problemslotioncsp.blogspot.com/
    Nov 29, 2011 | Yahoo Messenger
    I dont kno the default 4ne code for my voda4ne 125 handset
    hi
    Carefully reading user manuals help in most of cases :)
    Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
    Here is log of reset to default , read eeprom n read flash
    COM3 [VCP0] selected
    Device: ZTE-225
    Checking data, wait...
    Action: reset
    Boot...
    Press Power button now !
    Checking...
    boot answer: 01
    Boot Done
    Set Baud...
    Set Baud Done
    Connecting...
    flash: 0001:22C4
    Connecting Done
    Check free space...
    flash chip supported
    Check free space Done
    Check parameters...
    Check parameters Done
    backup critical area...
    Reading [eeprom-sta]...
    file saved: backup_eeprom-sta_20080118-132834.B1E.bin
    loading data...
    wrong database file: z225_eep65535.cfg
    error: can't load database[11]
    Reading [eeprom-sec]...
    file saved: backup_eeprom-sec_20080118-132834.B1E.bin
    Reading [eeprom-dyn]...
    file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
    backup critical area Done
    Check memory...
    Check memory Done
    Write...
    error: set erase range
    Write Failed
    Finished, Remove/Install battery now !
    Time used: 22 sec
    Device: ZTE-225
    Action: read eeprom
    Boot...
    Checking...
    boot answer: 01
    Boot Done
    Set Baud...
    Set Baud Done
    Connecting...
    flash: 0001:22C4
    Connecting Done
    Check free space...
    Check parameters...
    file saved: backup_eeprom-sta_20080118-133742.B1E.bin
    loading data...
    file saved: backup_eeprom-sec_20080118-133742.B1E.bin
    file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
    Check memory...
    Reading [eeprom-complete]...
    file saved: backup_eeprom-complete_20080118-133750.B1E.bin
    Completed
    Time used: 21 sec
    Device: ZTE-225
    Action: read flash
    Boot...
    Checking...
    boot answer: 01
    Boot Done
    Set Baud...
    Set Baud Done
    Connecting...
    flash: 0001:22C4
    Connecting Done
    Check free space...
    Check parameters...
    file saved: backup_eeprom-sta_20080118-133815.B1E.bin
    loading data...
    file saved: backup_eeprom-sec_20080118-133816.B1E.bin
    file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
    Check memory...
    Reading [flash]...
    file saved: backup_flash_20080118-134506.B1X.bin
    Completed
    Time used: 425 sec
    I uploaded all files....
    http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
    Plz add this model in infinity software....Thx....for ratting
    May 30, 2011 | Cell Phones
    COD 1.3 build win-x86 Mar 2 2004 -----
    For this you have to back up your file and they it can work or you can restore the computer that day when it was good . Just cilcke on Strat then click on programmes and accress and system tools and and at last clike on system restore ...
    Jul 11, 2009 | Computers & Internet
    Cant' play the game : Rap[ala Pro Fishing (Activision)
    A. There is a known fix to the problem that you have experienced and if you follow the instructions below, you will be able to resolve it. What you're going to need to do is find the file called 'Console.cfg'. This is located in your game's install folder (My Computer -> C:\Program Files\ActivisionValue\MagicWand\Rapala\Rapala\Cfg) inside the \Cfg folder. It might be easiest to just do a search from the start menu for 'Console.cfg'. Once you find that file, open it up with notepad or wordpad. You will see a series of lines, the 5th line says: "addvar r_windowed int; r_windowed = 0". You're going to want to change that to: "addvar r_windowed int; r_windowed = 1". Towards the bottom of the file (scroll down) you'll see two lines: "addvar rWaterReflect int; rWaterReflect = 1" and "addvar rWaterRefract int; rWaterRefract = 1" . You're going to want to change those to: "addvar rWaterReflect int; rWaterReflect = 0" and "addvar rWaterRefract int; rWaterRefract = 0". Make sure you save the file and that it asks you to replace it when you save. Then you can start the game. It will not take up the whole screen, but you can fix that by going into the options menu from the main menu and increasing the resolution.
    Apr 08, 2009 | Activision Rapala Pro Fishing for Windows
    3680-2682 ACEER ONCE THE COMPUTER TURNS ON IT ASKS DO YOU WANT TO START WINDOWS NORMALLY...YES IS THE ANSWER...THEN IS STARTS CONFIGURING UPDATES...THEN IT SHUTS DOWN...THE PROCESS CONTINUES. I LEFT...
    Hi Teeortay,
    Here are the possibilities:
    1) Hard drive has too many read element failures
    or
    2) windows system files needs repairing or operating system needs re-installation.
    Try these:
    1) Reboot your pc and get into BIOS. Then set to default setting and save. Then try booting. If this does not fix issue, take next step.
    2) Insert the operating system cd and go thru the repair process.
    This should fix your issue and good luck.
    Jul 27, 2008 | Acer Computers & Internet
    Burning to cd
    According to hp help and support
    When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
    In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
    1. Open iTunes.
    2. In the iTunes Help menu, click Run CD Diagnostics .
    3. Insert an audio CD in the optical drive.
    4. Click OK .
    5. View the results in the CD Diagnostics window:
      • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
      • If another drive name is listed, this document does not apply to your computer.
    Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
    1. Close iTunes and any other files and software that are open.
    2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
    3. Locate the file gcdrtype.cfg in the CD Configuration folder.
    4. Right-click the file gcdrtype.cfg .
    5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
    6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
    7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
    8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
    9. At the top of the Notepad window, click File , Save .
    10. At the top of the Notepad window, click File , Exit to close the window.
    11. At the top of the CD Configuration window, click File , Close to close the window
    12. Restart the computer.
    You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
    Thanks for using fixya support..You have a wonderful day
    Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
    Faulty DFL-700 image - missing FWCore.cfg
    Possible problems:
    1. IDE Flash device is damaged
    2. IDE controller is damaged
    2. Firmware is corrupt
    Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
    Download Link:
    http://www.opendrivers.com/freedownload/232591/d-link-dfl-700-vpn-firewall-firmware-1.33su-download.html
    May 05, 2008 | D-Link NetDefend DFL-700 Firewall
    Autodesk AutoCAD 2004 for PC Logo
    1,317 people viewed this question
    Top Autodesk Computers & Internet Experts
    JM Computer Service
    JM Computer Service
    Jerry
    Jerry
    Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
