Washer wont drain pump makes noise Sears model 970-c43072-00 purchased october 2004
  • Washing Mach... Master
  • 17,129 Answers
The pump is clogged with dirt in the inlet filter and the suction has dropped. Remvoe the pump and do a good clean up job, use the pump to be activatted on desk to test the pumping action. Use a back flush also to clean off all dirt in the pump. If test of pump is good then set it back and test.
Posted on Sep 01, 2010
My kenmore washing machine (front loader, model #970-C42062-00) is not spinning the clothes dry. sometime water is left in the drum other times not. the drum is making a squeaky noise as well. what...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 22, 2011 | Washing Machines
Buzing noise and failure to drain during spin cycly washer wont spin
This is a very common issue on these units, the drain pump needs to be cleaned. You can access the drain pump by removing the back panel of the washer. If you find that the drain pump has failed you can purchase the part from the link below.
http://www.appliancerepairlesson.com/
Mar 06, 2011 | Frigidaire ATF6000ES Front Load Washer
KENMORE 90 SERIES TOP LOAD WASHER WONT SPIN LOUD NOISE, SOUNDS MOTOR RELATED. WILL DRAIN SLOWLY CLOTHES ARE STILL WET AT END OF CYCLE.
does it agitate???. if it does not then you need the motor coupling. you need to remove the cabinet, yes, I said the cabinet, remove the pump,motor and you got to the coupling. replace all part in kit. reassemble and test. go to the website of sears parts WITH THE COMPLETE MODEL. and get the part. model starts like 110.xxxxxxxxxxx
good luck to you.
Feb 07, 2011 | Kenmore 15864/15862 Top Load Washer
I have a top loading kenmore washer. It is making a load noise on draining. Probably something at my pump filter, I guess. but how do I get there to look???
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following illustrated description of how to access the pump on these washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=516937a95eebc772fcc85c8de447bd5b
Dec 15, 2009 | Kenmore Washing Machines
Can one purchase or order the detergent drawer assembly?
You can order this part directly from Sears. Sears has a very good parts dept. and you can order online.
Oct 09, 2009 | Kenmore 44102 Front Load Washer
Will not pump Kenmore model 970-c45072-00, purchased in 2005
Pump blocked probably something stopping it, sock, coin etc
Mar 13, 2009 | Kenmore 43142 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
