Hi; I have a LCT3201TD 32 wide. The unit does not turn on or respond to the side bottons. The remote starts it but no other controls work. There is a volume bar stuck at 100 and no response. I put new bateries in the remote. Need help.
  • Abraham123 May 21, 2008
    not the problem.
    Opened and cleaned it.
    no working.
    thanks.
  • Abraham123 May 23, 2008
    How do i locate the correct bd?
  • 3,037 Answers
Try unplugging it for a few minutes and then overnight to see if either fixes the problem. If not the control board will most likely need to be replaced since this is happening on both the remote and the tv.
good luck on getting it working with the two resets I suggested. Please let me know if you have any further questions after you try my suggestions
Posted on May 21, 2008
  • Benjamin Patri
    Benjamin Patri May 23, 2008
    the easiest way to locate the board is to follow the wires from the side button control panel to the board.
  • Benjamin Patri
    Benjamin Patri May 27, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
  • 13,433 Answers
There may be a fault in the control board of the television. I would suggest haveing a look inside and possibly replaceing the board.
  • Ekse May 21, 2008
    ofcourse if your not experienced in electronics it might be better to contact a service tech.
    Genius:
  • 1,447 Answers
Hi chances are there are cables that are pinched or loose inside the television itself, if you want you can take the risk of opening it and check the cables and wires. make sure you turn it off and unplug it from power supply first.
Posted on May 12, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 14, 2008
    you can actually open up the remote and clean it from the inside, dust or dirt might accumulate on the pads thats why it doesnt respond
I CAN NOT GET THE REPLACEMENT REMOTE TO WORK FOR THIS UNIT
Try removing and reinstalling the batteries. Be sure there is no glass cabinet door between the remote and the Akai device. Try aiming the remote at an angle instead of straight on. Try installing new batteries
Feb 15, 2013 | Akai New Original LCT3201TD Remote Control
I HAVE MODEL LCT3201TD. I AM USING THE REMOTE THAT CAME WITH THE UNIT. THE REMOTE WILL TURN THE UNIT ON AND OFF,CHANGE VOLUME AND SLEEP TIMER. TO CHANGE CHANNELS I USE A SEPARATE REMOTE. I WOULD LIKE TO...
The tv remote that came with the tv unit.The tv remote might have channels buttons up/down buttons functions and numbers pads might be shorted and dead and no longer functions anymore.U have a Digital Camera turn it on take the tv rmote put in the front of the Digital Camera pushes each buttons one by one all the buttons that work u will able to see a flashing white light on the camera vewing screen,because the Digital Camera can read INFERED input signal to see a output u see on the the camera viewing screen.After u test it on the front of a Digital Camera any buttons don't have a white light flashes INFERED read out than those buttons functions are shorted and dead.Try website like Remotes.com to buy the tv original remote to replace and used.
Aug 29, 2011 | Akai LCT3201TD 32 in. LCD Television
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
My tv wont turn on even the standby botton isnt on
Hi
You have power supply problem.Please go to ebay and buy cheaper
price:
AKAI LCT3201TD POWER SUUPLY MLT169A REFURBISHED CHAINA
Thanks
GEORGE
Mar 03, 2009 | Akai LCT3201TD 32 in. LCD Television
Trouble turning on the tv at times
The next time I try to turn the unit on the remote will not work or I can not turn the unit on with the switch on the side.
This statement leads me to believe the IR receiver and associated set-top button circuit may be at fault.
If you haven't hammered the set to pieces yet, try this; next time it fails to respond to the remote, put the remote in your freezer for 2-5 minutes (not longer, the batteries won't appreciate it) and then try it again.
If it then functions normally, then a certain integrated circuit (PT2222 or PT2221) may be from the same lot as mine and is abnormally sensitive to warmth. If this does make a difference, try removing the battery compartment cover and intentionally leave the remote face down.
If these tests don't seem to make any difference to the remote, then it is likely that the receiver end in the set is faulty.
Jan 27, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
Power botton not responding
If it's not ejecting or responding to any of the buttons on the unit, or the remote, but is able to play a DVD, the display microprocessor(computer) within your Harman is damaged. For more information, please visit my website at audioserviceclinic.com. Thank you.
Dec 22, 2008 | Harman Multimedia HS 300 System
AKAI LCT3201TD
Is sounds more like a button got stuck or you could have a main board failure since the TV is powering up normal; but it could also be a power supply not providing the proper voltages to the main board circuitry and the microprcessor does not know what to do.
How old is your TV?
May 13, 2008 | Akai LCT3201TD 32 in. LCD Television
Ilo 32-hd
ILO TELEVISION TURN ON AND OFF BY IT"S SELF, IF I HOLD DOWN THE VOLUME BOTTON IT COMES ON,LET THE VOLUME BOTTON GO NO PICTURE
Aug 29, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
