Question about Maytag MSD2756G Side by Side Refrigerator
Water leaking under the freezer door on my Maytag side by side refrigerator/freezer. ModelMSD2654GR. Depends on the weather, humidity....
    Brigadier General:
  • 3,917 Answers
Hi
Please check this link bellow to have an indepth knowledge to the problem of your refrigerator…
http://www.repairclinic.com/Refrigerator-Troubleshooting#Itleaks
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Sep 01, 2010
Small water leak on floor on both sides of door. w ater is not coming from refrigerator or bottom freezer unit
Did you notice any moisture on the main cabinet at the area the doors seal against? Some models have a heater imbedded in the cabinet edge at the door seal to keep the metal cabinet from sweating much like a glass does when filled with water and ice cubes. If the heater is not on the metal sweats and leaks down to the floor. Some refrigerators have an option switch called and energy saver that can turn that heater on or off. Off is OK for winter but needs to be on in humid weather if house is not air conditioned. Heater could also be burned out (bad).
Apr 30, 2015 | Maytag Refrigerators
Maytag fridge side by side freezer door leaks water
If the insulation in the door has blown, it cannot be replaced. If there is a dispenser in the door, look at all the plastic parts for any splits or leaks. To test if it is the dispenser, turn off the water supply for a few days. If the water stops collecting in the door it's a good sign.
Apr 22, 2014 | Maytag MZD2766GES Side by Side...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag Side by side MSD2356AEW unit. Everything was OK for years till the maid cleaned it. Afterwards we noticed water under the bottom drawer on the refrigerator side. Slowly in the course of 2...
Do a manual defrost overnight by unplugging and leaving the doors open the opening should not be frozen. Alot of humidity or constantly opening the door sometimes causes the frostup.
Mar 13, 2010 | Maytag MSD2651 HE Side by Side...
Puddle underneath fridge on occasion--tube coming down seems ok
This happens when the water from the defrost cycle exceeds the capacity of the pan under the fridge. The amount of water depends upon the door traffic (how many times opened in the day) humidity, and believe it or not, the door seals. If the doors to not seal or close properly, it will allow air, and the humidity that it carries, into the box, and that means more defrost water. You might also check the pan for physical damage that may make it leak.
Feb 02, 2010 | LG Bottom Freezer Refrigerator w/ Swing...
Pan that catches water under freezer side overflows
That is pretty unusual unless you live in a humid area. Some units have a switch that allows you to adjust for this and it simply defrosts every 12 instead of 24 hours. Also, the fan that cools the coils under the unit may not be running at normal speed since the warmth of the coils and the fan generally suffice to return the accumulated water into the air. You are right to check the door seals since if these are no longer seating well, external humidity will be gathered by the cooling coils and subsequently become the water collected below that is plaguing you.
Apr 30, 2009 | Whirlpool Refrigerators
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Leak running down front
Take the recess cup out and seal the area around it right where the front stainless steel panel meets the recess (right at the front of the recess) with clear silicone to prevent water from getting inside the door, then running out of the plastic frame area around the dispenser and running down the freezer door or out the bottom of the door. After the silicone has set, replace drip cup.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
167 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
