Question about Garmin GolfLogix GPS-8
I purchased a Garmin GPS-8 from Golflogix in April this year. It worked very well until a fortnight ago. I was playing and the screen started flickering off and on. I had new batteries at the time and have subsequently checked them and put another set of new ones in. After flicking off a few times it permanently lost the screen. I have emailed Golflogix three times, twice to technical support and one to customer relations. This has now been going on for 11 working days, they profess on their website that they will reply in one working day. I have had absolutely no reply. As I live in Australia I paid a substantial amount for the GPS, plus freight, plus software download, plus countless batteries. Do you have any suggestions, 1. How I can get a response from Golflogix 2. How I can get my GPS fixed as it is under warranty 3. What should I do next. Kind regards, Juliet Hugo
  • 4 Answers
SOURCE: GPS 60 unit shows "Searching the Sky" status message all the time
The "New Location" fix above brought my GPS 60 back to full operation. I did reload the GPS software from Garmin but the recovery depended on well charged batteries and as above: turn the unit on
press MENU button
scroll to "New Location"
wait 10 minutes for the GPS to recover.
Posted on Apr 02, 2008
sharcnet
  • 2130 Answers
SOURCE: Problem with the touch screen on my Garmin Nuvi 350
Have you tried the "recalibrate" touchscreen command?
Press the "wrench" symbol at the main menu, then the "display" icon, and then "recalibrate".
Go through pressing the dots as requested and see if that cures your problem.
- Jim
Posted on Oct 27, 2008
KingDWS
  • 1606 Answers
SOURCE: Replacement Memory Battery
The Garmin GPS III and III plus use a tabbed lithium coin battery. Its is a Panasonic BR-2032. You can buy these for about $2 from larger electronic suppliers. The problem is that the shipping or minimum order will make that $2 battery cost you about $25. For you cheap guys there is a solution. You buy a CP-2032 and a coin holder. $2-3 for the battery and $1-$2 for the holder. 6 screws to open the case, cut the wires close to the battery as possible. Solder the wires to the coin holder (good idea to heat shrink or cover the solder joints), put in the new battery and you are done the easy bit. You will most likely have to trim away some of the plastic on the holder such as legs or other things sticking out. Unfortunately you can't really do this with out fitting it in the case and you don't want to do that until you have the holder on the wires so it will be in the right place. Once you get that, simply play with it until you can put the screws back in. And tighten gently. Not too much or the gasket will be squeezed too far out. Put tAA'sx AA's back in, take it outside so it has an unobstructed view of the sky, set it down and go for a long coffee or three. It will now download the almanac and any other data which can take 15 minutes or more depending on the satellites. You should see a low battery error and other errors such as saved data lost. Ignore these. You can put it on a external power plug or just leave it off with the AA's and in 5-7 days it will have reset the error as it figures it it now charged. You get the battery error even with a new fresh charged battery. I think there is a Garmin reset code to force this but none of the codes I have tried have worked.
Posted on Nov 13, 2008
shannongreer
  • 75 Answers
SOURCE: screen freezes and display faints
Hopefully the usb adapter just confused the battery. Did you use it this time or a regular plug? Its always best to fully discharge a battery and fully recharge it for the next use. They will lose life and malfunction otherwise. Glad you've had some luck, hopefully it will work just fine now.
Posted on Jun 03, 2009
SOURCE: Garmin is unresponsive. Won't power up or turn
I have a Garmin c340 that would not turn on.
I found the hidden reset button and it works now.
With the display unit facing you, the aluminum cover plate has the the word GARMIN on it. Use you fingernail under the word Garmin and the cover plate comes off. The left part of the cover stays attached to GPS and the right side lifts up exposing the RESET button. I pressed RESET and POWER together and it works now.
Posted on Mar 13, 2010
Need to get a garmin golflogix usb cable i live in sout africa please help.
I would suggest garmin.com for original cable, amazom.com for other sources and ebay for worldwide sources.
Nov 26, 2013 | Garmin Golf Logix Gps 8 Replacement Cable...
GolfLogix GPS Receiver: I have a golflogix 8 and I can not get beyond the ...
The cable can be a pain. It has to be slid all the way down to the very bottom of the socket on the gps, even when its tight, it might not be connected all the way. I usually wiggle it left and right while pushing it down.
May 17, 2010 | Garmin GolfLogix GPS Receiver
The Unit is stuck at the Initial Screen and won't go into any menus.
Hello. Here is the contact info for Garmin
http://www.golflogix.com/WebSite/GarminHome.aspx
Contact them and ask if they can talk you through a factory reset. Otherwise, find out how to send it to them for repair. J.
Mar 22, 2010 | Garmin GolfLogix GPS-8
THE GOLF COURSE I PLAY IS NOT LISTED ON THE GARMIN 5 I JUST PURCHASED HOW CAN I GET THIS COURSE DOWN LOADED
garmin 5 is not a golflogix product, might want to reclass your question to get people that know it.
Feb 10, 2010 | Garmin Golf Logix GPS
Golflogix gps-8 wont connect to my mac and register
make sure its plugged into the mac itself and not a hub, or an extension on the keyboard. Also, make sure the cable is pushed ALL the way down on the back of the gps, it can be tricky. even when its tight, it might not be all the way down.
Jan 09, 2010 | Garmin GolfLogix GPS-8
Unit will not power up (with new batteries)
call golflogix at 8779770162. BE SURE TO TELL THEM THAT IT HAPPENED WHEN YOU LOADED THE SOFTWARE UPDATE! otherwise, they might not warranty it.
Aug 03, 2009 | Garmin Golf Logix GPS
Half of lcd doesn't work
there is not, the lcd is hardwired to the mother board, so not replaceable. Give them a call to see if you are still under warranty.
Apr 30, 2009 | Garmin GolfLogix GPS Receiver
MY GOLF LOGIX HAS WORKED FOR OVER 2 YEARS . NOW IT WILL NOT AQUIRE SATELLITES. OTHER GOLF LOGIX IN MY **** WORK FINE
The GolfLogix 7 had a problem that if you did a reset to factory defaults it wiped out the Almanac in the GPS. This is the Table of where the satelites are. Put in a fresh set of battery's....turn it on and put it out in the open sky for 4 to 8 hours. Sometimes this will work. If not contact Golflogix Tech Support. They ill probable ship you a replacement unit.
Apr 07, 2009 | Garmin Golf Logix GPS
Garmin GolfLogix GPS-8 Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
