Question about Lexmark X6170 All-In-One InkJet Printer
Error message - cartridge error 50c will not print
I have followed all of the troubleshooting guidelines and can not resolve the problem. Please help!!
  • 1 more comment
  • mgwill May 10, 2008
    Thanks for your response. I have a Lexmark X6100 printer. Would be grateful for a resolution to the problem. Hope to get a resolution. Thanks.
  • Anonymous Jul 03, 2008
    Can't find user manual. What is cartridge error 50 C?
  • Daniel Blask
    Daniel Blask May 11, 2010
    The ultimate permanent fix for the A940 printer would be to purchase new cartridge snap-down levers (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). If you purchase snap down levers for a Lexmark printer series X5100 or X6100 or Z55 or Z65, the little guide peg inside the snap lever would work with an unmodified 83 and 82 Lexmark cartridge. All Lexmark did for Dell to make the Dell unique, was to put special Dell snap levers on the printer. I considered breaking off the little guide peg on the snap lever, but decided against it as it appears to help hold the cartridge in alignment.
    --Not sure what type of printer you have but this is how the issue was fixed for the dell a940...
I have a lexmark x6170 with a cartridge error 50c.
Please I need some help!!
Thank you.
Posted on Jul 11, 2008
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
6170 I HAVE A ERROR MESSAGE STATEING 50C CONSULT USER GUIDE AND I DO NOT HAVE A USER GUIDE
Hi. The error tells you that your print cartridge has shorted. Here's a link to the Lexmark website to give some instructions on how to remedy the problem. Just click on this link: http://bit.ly/aSWvpk . Good luck!
Mar 23, 2010 | Lexmark X6170 All-In-One InkJet Printer
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Not printing. shows error 50C
Cartridge Error 50C
Jun 13, 2009 | Dell A940 All-In-One InkJet Printer
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Cartridge Error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
LEXMARK X5150 CARTRIDGE ERROR
Try this --
Cartridge Error 50C
Cartridge Error
Nov 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
Error code 50c
Cartridge Error 50C
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
May 26, 2008 | Lexmark X5150 All-In-One InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Cartridge Error
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
264 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
