Question about Maytag Dryers
I have a Magtag Neptune dryer that recently began taking a long time to dry the clothes. I noticed that the exhaust hose was not very secure at the dryer and there was a lot of excess lint could that cause the dryer to take so long to dry the clothes
    President:
  • 3,074 Answers
A vent hose that is full of lint or clogged/restricted will cause the dry to take longer to dry or leave the clothes damp. if you clean/get the hose unrestricted this should rectify the problem. Hope this helped tim
Posted on Sep 01, 2010
Dryer drying slower
Check lint filter. Check blockages in the exhaust hose. Check that the flap outside your wall is not blocked and that the slats or flap opens OK. To get fast drying you have to have a good airflow into the drum and out of it.
Oct 22, 2015 | Maytag Neptune MDE5500AY Electric Dryer
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Most recently, the dryer function is not drying
Run a cycle with the Dryer vent hose off. If the clothes come out dry, you need to have a duct cleaning company come out and vacuum out the duct.
Oct 20, 2009 | Splendide 2000S Front Load Washer / Dryer
Maytag dryer not drying clothes properly
Have you tried cleaning off the sensor? Many of the newer dryers have a sensor that, when dirty, can no longer determine the moisture level of the clothes. Some manufacturers recommend using a light vinegar solution. Check your owners manual for location and recommended cleanier. Also, make sure your exhaust hose is clear of obstructions and that you vacuum out your lint trap area. HTH.
Aug 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer has heat but won't dry. Seems like no air is blowing into the clothes??? so takes long long time to dry.
Have you checked to make sure your lint filter is clean? also don't stack items on the dryer. and make sure exhaust vent hose isn't kinked or blocked.
Jul 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
MAYTAG NEPTUNE dryer takes long time to dry, notice water coming
your vent is very very cloged you need to take off vent hose and clean lint out of dryer.(do not use until you do.
Jun 26, 2009 | Dryers
I have a neptune drying center and it's taking 3 hours to dry
Check the exhaust duct again. There must be a blockage, a kink, or a disconnected vent pipe.
May 03, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Dryer wont dry
do you have the dryer set on high heat,did you clean out the dryer lint shut,hose and exhaust?mike
Apr 20, 2009 | Dryers
Longer time to dry clothes
Remove the rear connecting vent and run a 45 minute timed dry load. If it works correctly repair the connecting vent and or blockage in the wall.
If this does not correct the problem make sure the glow bar is cycling at the gas valve and report back for further repair.
Apr 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Dryers Logo
88 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
