Question about Singer 8763 Curvy
The machine is dropping stitches, it appears there is a problem with the top thread tension. The needle is inserted correctly with the flat side to the back of the machine, it is the right size for the fabric, the bobbin is wound evenly, the machine appears to be threaded correct. What else can be set to correct the problem?
  • 340 Answers
According to the Singer site it could be the presser foot.
http://www.singerco.com/support/faqs.html
Click on the question about skipped stitches for the answer to appear. Hope this helps, Hazel
Posted on Sep 01, 2010
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Machine dropping stitches
Skipped stitches
1. A bent or dull needle
2. The wrong needle for your fabric
knit fabrics require a jersey or ballpoint tip. Most wovens do well with a universal tip, and specialty fibers, like leather or metallic, usually require specific needles.
3. Incorrect machine threading
4. Unbalanced needle thread tension
Start by making relatively small changes and run a test stitch to evaluate the impact. If you need to adjust the tension dial using woven cotton fabric with good quality all-purpose thread and a new needle
5.check the needle is inserted correctly. The needle needs to be pushed as far up the needle shaft as possible. It's easy to insert the needle half way, clamp it down and think it is inserted correctly.
the flat part of the needle should be positioned towards the back. If the needle is not inserted correctly, it will not be able to pull up the bobbin thread and will cause skipped stitches.
6. If the suggestions don't help then it is time for a tune-up.
Mar 22, 2016 | New Home Sewing Machines
I am having problems with tension and skipping stitches'
skipping stitches indicates a fault with the needle/hook timing
adjust tensions on both the needle and bobbin threads
take it in for a service.
May 04, 2015 | Sewing Machines
Skipping stitches
Skipped stitches
Nov 19, 2013 | Singer 7256 Fashion Mate Sewing Machine
Skipping Stitches My Singer Confidence machine is skipping stitches. I've cleaned the feed dogs and the stitch hook, changed needles three times, changed thread, adjusted the tension, etc.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
Oct 07, 2013 | Sewing Machines
How can I tighten the bobbin tension?
try adjusting the top thread tension
here are some link for a manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125_EN_272.PDF
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LS_2125i_EN_1628.PDF
Skipped stitches
Mar 01, 2013 | Brother LS-2125 Mechanical Sewing Machine
Bobbin case jumps out of place when free-motion quilting
Skipped stitches
bird nesting problems
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Sep 12, 2012 | Sewing Machines
My New Home skips stitches. I have cleaned it, changed needles, adjusted the tension and tried different bobbins .
Skipped stitches
it's also possible that the machine could be slightly out of time
Aug 29, 2012 | Sewing Machines
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Skipping stiches
1) It’s possible the machine is threaded incorrectly. Remove the thread completely and rethread the machine. Be sure to use good quality thread--don't buy the cheapest you can find. A good thread will help your machine perform better and your projects last longer.
2) Poor stitch quality can be caused by the needle. Make sure you're using a new needle that's right for the job. Many times machines are taken in for repairs and all they need is a new needle. If you can't remember the last time you changed the needle--it's past time. Needles should be changed at least every eight hours of sewing.
3) When inserting a new needle, make sure the flat side of the needle faces away from the bobbin area. For example, if your machine has a frontloading bobbin, the flat side of the needle faces the back of the machine. If your machine has a side-loading bobbin, the flat side faces the right side of the machine. Some older sergers require special needles that don't have a flat side. Refer to your owner's manual to properly install a serger needle.
4) Thread that shreds or breaks can be blamed on the needle. Use a good thread and make sure the needle eye is large enough for the thread type. Also use the right type of needle for the fabric;
5) The machine tension adjustments put stress on the thread so it doesn't simply flow through the machine. When the upper and lower tensions are balanced, the stitch forms correctly. Tension is easy to adjust--stitch on fabric samples with a different thread colour for the upper and lower threads. Observe the stitch, adjusting the tension until the stitch is formed correctly. As a general rule, adjust the upper tension first. If the stitch still isn't right, adjust the bobbin tension.
Feb 26, 2008 | Singer 2662
Singer 8763 Curvy Logo
99 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
