Question about Refrigerators
Maytag side by side mzd2667heq stop working is not cooling, fan in back is working, compressor has a click then in about 15 secs another click, I bought a relay to see if that was my problem part #MZD2667HEQ but is diferent from mine since thisone does not have a plug for the wires that connect toit once is attached to the compressor
  • 21 Answers
Problem is either start capacitor if fitted is no good if so replace not deer. or compresser is seized if so new compresser and gas plus dryer in australia approx $550.00 to repair
Posted on Sep 01, 2010
2005 Maytag Refrigerator Fan Stopped WOrking
What is the model number and is the compressor kicking on?
Oct 28, 2012 | Maytag Refrigerators
Refrigerator not cooling: Maytag Plus: Model MSD2756GEQ
Your PTC relay is bad and needs to be replaced. It is on the side of the compressor that connects the wires to it. Cost is about 50 maytag price or you could go with a 3 in 1 cost about 15. If you need any help get back with me and can walk you though it. Ken
Aug 15, 2009 | Maytag MSD2758G Side by Side Refrigerator
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Maytag, side by side refrigerator stopped working
Check the thermostat which is located in the top left hand coner of the refrigerator. Also check the relay on the compressor to make sure it is not staying open all the time. Also there has been a huge recall on Maytag side by side refridgerators made between 2001 and 2005. I would also try calling Maytag and get the problem fixed by them by recall
Apr 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Nov 29, 2007 | Maytag MSD2454G Side by Side Refrigerator
Fan runs but no cool air on both freezer side and cold side
If you hear the compressor try to start then click off, you probably have a bad compressor or a bad relay. If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge. The relay is only covered for a year. With it being a Maytag, I bet it is compressor. There have been a few models with control board problems that have caused this symptom, but that's not likely to be your problem.
Oct 06, 2007 | Maytag MSD2756GES Side by Side...
I have a Maytag msd2422gr side-by-side that has gradually stopped cooling 2 or 3 times.  The solution is cheap and easy: Your unit isn't cooling because the space in which the fan is housed is so full of ice you are getting no cold air circulation. The compressor and everything else is functioning, but the cold that is being produced is blocked by ice. All you need to do is to unplug the unit and entirely unload the freezer. Locate a panel with vent slots on the back wall of the freezer compartment that covers the fan. It is held on by about 4 screws. Lift out the panel and behold the glacier of ice covering the coils. You might want to use a hair dryer or space heater to hasten the melting, but I would warn against trying to chip or break it out because you will probably ruin or puncture an important part. Once all the ice is gone, reassemble and plug it back in. As I recall, it takes a few minutes for the compressor to get going again, but be patient because, if there was ice, that was your problem and if it is now gone, that is your solution. It can't help but work. And from now on, you know to be careful not over-load and block those vent slots in the back of your freezer.  If all else fails go here and get great, free help and every part you could possibly need:  http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Mar 27, 2007 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
