Question about NetGear WGR614 Router
Serial number Have recently just purchased the wgr614nar router from a friend, and for some reason i cant find the serial number there is nothing on paper and after speaking to my friend he doesnt know it either, he has used it before, is there anyway of find out the serial number? Thanks in advance. Steven stevenables@hotmail.co.uk
  • 47 Answers
There is usually a sticker on the bottom of the router with the serial number. If it is not there, you are in trouble because there is no other way to get it. I have always thought they should put the serial number in the router settings that you can access, but unfortunately they do not do this.
Posted on May 11, 2008
I purchased a serial port that is not compatable with my sewing machine, I also purchased an updated software with Bernina to make my embroidery machine user friendly. however,I am unable to connect
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
Dec 02, 2011 | Bernina Artista 180
I recently received an MTD Yard Maching 4.0 22" cut model 11a-084e352 from a friend but with no operator's manual. I need to give it a tune up. What kind of spark plug does it take? I'm...
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1 that's where you can find your manual. Just put in your model number, and serial number too and your manual(s) will be accessible.
May 16, 2011 | Mtd 22" Yard Machine Push Mower
Serial number won't work
Check your license for your program. You are entitled to the number of installations noted on that license. In other words, if you have installed using that SN o more than two or three computers, you probably maxed your license out.
That is why NO ONE should be posting their serial number on an open forum like this. You should NEVER give out your serial number to friends for the same reason.
You should not assume that is the issue however. Go to Adobe's Dreamweaver and check your registration to see why you're number is not working.There a about 100 conflicts and glitches that can occur with a new operating system.
You can help me to help others more effectively by rating this answer. If you have a minute, please let me know if this was helpful.
Dec 23, 2009 | Macromedia Dreamweaver MX 2004
Unlock security code
Hi Friend,
The IMEI Number is nothing but the Serial number remove the back cover, battery,there you will be having serial number its IMEI number
Regards,
Ayyasam
Jun 03, 2009 | Nokia 2760 Cellular Phone
Ford Fiesta Radio Lock
have you disconected the battery for half hour or so this oftern resets the lock code but you normally only have 3 chances before it locks out again.
if not also post your radio serial number and model number and i will be able to clarify your code.
Dec 23, 2008 | Code-Alarm Code Alarm Transponder
Hp1040 fax and copy machine
I solved this problem by returning my fax machine to where I purchased it and exchanged it for another type of hp machine and it automatically goes in long format when it scans long format paper. If it scans short letter form, it automatically copies itself and adjusts itself. Thank you aniway, durl
Nov 25, 2008 | HP 1040 Plain Paper Inkjet Fax
Router cant b found
Locate the reset button on the rear of the router.
Should be below the antenna and recessed use a paper clip or similar to hold in for 10 secs.
This will reset the router back to factory defaults.
Type in 192.168.2.1 into your browser and you should get the routers setup page. Click the login button, no password is required. You can set this up yourself once in the router setup.
Be aware this router is NOT on the Xbox live supported list.
Check link below for supported Live Routers.
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
If you have only bought thi recently get it swapped out if you cannot connect to live once reset.
Let me know how you get on.
Feb 26, 2008 | Belkin (F5D7230-4) Router (587009)
NetGear WGR614 Router Logo
323 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
