Question about LG Televison & Video
Hi My LG DVR will not operate at all, it simply shows the HELLO, i have powered it down numerous tiomes with the same result ??? Regars Ken
  • LG Master
  • 11,800 Answers
The control processor inside the unit has crashed so badly it has corrupted the firmware - most likely because you has a hardware fault: open the unit and look for failed parts.
On very few units it's possible to update the firmware by connecting the unit to a pc.  If yours is not one of them then your only option is to have the unit sent to a repair shop. Get a quote before that, that might cost you more than what the DVR is worth.
Posted on Sep 01, 2010
DVR SOYO CAMERA SHOWS ON SCREEN OUT OF RANGE
Hello
You need to reduce the resolution of it from 1080 to 1024. It will solve the issue
Jan 06, 2018 | LG Computers & Internet
How to calculate log into decimal?
To convert a single symbolic result to a numeric result, press right-shift ENTER to invoke the ->NUM command.
To have all results come out in numeric form, turn on the numeric flag. Press MODE C down-arrow down-arrow left-arrow +/- ENTER ENTER .
Aug 27, 2012 | HP 50g Graphic Calculator
How to multiply matrix on fx-991ES calculator?
hi..
Its very easy to do matrix operations in FX 991ES
This calculator can operate up to three Matrices at a time, namely Matrix A (Mat A), Matrix B (MAT B), Matrix C(MAT C).
  1. First to do, is set the calculator in MATRIX Mode
    Its Easy
    Press MODE button and press 6.
    Your Display will show indication of MAT on upper side of screen to show now calculator is in MATRIX Mode
  2. Now we need to Define matrices and set its dimensions.
    This product supports matrix of order up to 3x3. That is you can operate matrix of No. of rows=3 and No. of columns=3
    To input matrix, Press SHIFT and then 4. This will Pop up Menu for Matrix. Now press 1
    Your screen will show as this,
    MAT A will be your First Matrix and MAT B will be your Second Matrix and so on.
    Press 1 , 2 , or 3 to select Matrix A , B, or C.
    here I will Proceed with Matrix A, so I press Numerical 1 Key
  3. Next screen will ask you about the size of matrix.
    Press UP or DOWN Keys to view options.
    Press Corresponding Numerical keys to select corresponding order.
  4. On Next Screen , enter values on each positions
    Press UP, DOWN, LEFT, RIGHT Keys to move around in matrix and specify each element.
  5. Now we inputed Details about Matrix A. If you want to specify other matrices (MATRIX B, MATRIX C) repeat STEPS 2 To STEP 4
  6. After Specifying required Matrices, we can tell calculator to do operations with them.
    Press SHIFT and then 4 and then It will show a menu contains
  7. For example, i need to multiply Matrix A with Matrix B, i'll enter as
    SHIFT + 4 + 3 to Input Matrix A
    X
    to enter operator (Here multiplication, You enter + - x / for corresponding arithmetic operations )
    SHIFT + 4 + 4 to Input Matrix B
    = To show Result
    Press UP DOWN LEFT RIGHT Keys to view extra fields, if any.
Hope this will help you.
have a good time with Casio FX 991ES
Mar 26, 2011 | Computers & Internet
Hi i am trying to figure decimal for natural logarithm can i do thi with a ti 89??
Yes. If the calculator is showing something like ln(2) for an answer, press diamond ENTER to convert to a numeric answer. To have all results come out numerically, press MODE F2, use down-arrow to move to Exact/Approx, right-arrow, and select APPROXIMATE. Press ENTER twice to save the change.
Oct 27, 2010 | Texas Instruments TI-89 Calculator
Will not record a program, can not access dvr recorded programs. When DVR button is pressed get the message " ERROR 024 Unable to access this feature at this time : data not available " .
Hello this is Matthew Gonzales with DISH Network customer service. With a 024 message, the best thing that we can do is hard reset the receiver. To do a hard reset, you simply unplug the receiver from the power outlet it is connected to, leave it unplugged for 20 seconds, then plug it back in. The receiver reboot process takes about 5 minutes. Once the show is back on, try accessing your DVR again, if it is still not working, the receiver will need to be replaced. If this is still a problem, please feel free to email me at matthew.gonzales@dishnetwork.com with your account number so we can get this resolved.
Sep 21, 2010 | DISH Network ViP722 DTV Receiver /...
No Owner's Manual Came with My P2500, 17" Gas String Trimmer
Hello, It would appear that manuals were not included in this model :) Here is the link you have requested. The page should show four choices for download by year of manufacture - click accordingly. If the selection does not show and the search parameters are blank, simply type P2500 into the "Type your search query (i.e. product name)" box and you will get the same results.
http://www.poulan.com/node7925.aspx
Hope this helps!
Jul 30, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Mar 09, 2009 | LG DR787T DVD Recorder
SANSA E200 NOT SHOWING THE MENU SCREEN
Try to format the SANSA E200.
You can do this by simply holding down the Power/Menu button for about 15 seconds. After the reset, any changes you have made to the e200 during its last use will be lost.
PLEASE RESET USING THE RESET PIN PRESENT IN THE SIDE.
AND FORMAT THE PLAYER . if this dosen't work your player is faulty
Nov 21, 2008 | Computers & Internet
CyberHome Manual
I just downloaded the manual yesterday from http://cms-system.cyberhome-dvd-help.com/modules.php?name=Downloads&d_op=viewdownload&cid=39. All I had to do was type "cyberhome dvr 1600 manual" into Google and it was the first result that popped up. Looks like they have other manuals available for download as well.
Dec 12, 2007 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
