Question about Inverter Xantrex MS2000 Sine Wave Charger 809-2010
I live in New Zealand which has 240 volt supply on the grid. The zantrex 2000 works with an input supply of 120 volts. How can I use it?
  • 12,061 Answers
Hi, OK, there are two ways to achieve this. One. Using an external STEP DOWN Transformer, 240 V AC, to 120 V AC. The ONLY thing that matters is KVA. As long as the KVA is the same ir will work. This means as long as the Output Voltage and Current are the same, it's irrelevant whats on the Secondary. So if
The second, is to remove the existing transformer, and substitute with an exactly the same Secondary Outputs, BUT with a 240 V AC,. Input winding. Most likely it is a simple step Down transformer anyway, that steps down, whatever the external voltage is, down to say 12 -18 V AC. Therefor ANY suitable 240 V AC transformer with the SAME secondary winding(s) will work, no problems. You can even get some transformers Overwound, for 240 V AC, a very common thing, depending on transformer construction. There are a few transformer manufacturers in the "Yellow Pages" contact one of them and inquire.
As a tip, sometimes the existing transformer has TWO 120 V windings, and sometimes only ONE side is used, for US power, and for 240 V AC, you simply connect the other winding in series, and NOW you have got your 240 V AC to whatever.
Posted on Sep 01, 2010
Ion tailgater speaker - changed the ac switch from 240 to 120 and now it wont work? Live in uk if it helps
Hi
The fact that you live in the UK is key to this. The mains voltage in the UK is normally 220 - 240 volts and your system should be set to 240 volts. If you changed the voltage switch to 120 volts and then tried to use it, you will have connected circuitry within the box designed for 120 volts to 240 volts. This will have damaged some of the circuitry for sure.
Your best bet is to return the ac switch to 240 volts and hope that the 120 volt and 240 volt sets of circuitry are completely isolated from each other within the box, so that resetting the ac switch will allow the kit to work.
I strongly suspect that the kit will need to be professionally repaired, and will be useless until it is.
Not perhaps the answer you would have preferred but hopefully of some help, if so would you please register that with Fixya
Cheers
Mar 06, 2015 | AC Cars & Trucks
Hi, in Antec 300watt power supply there is 3 cables or input or current 220volt. The cables are Black, Green and white. Which one is earth, which on is live(positive) and which one is negative?
For 120 volt operation use
black for the hot, White for the natural, Green for earth ground.
For 240 volt operation use;
Black and White for the 240 volt and Green for earth ground.
Black is generally designated as the "Hot" or "positive" .
You must make sure the switch on the power supply is set for the voltage you are using. ie: 120/240
Dec 15, 2014 | Antec Computers & Internet
Power supply
Question is a bit vague, does this apply to your washer dryer? This seems to imply that the appliance will need to have the 240v option selected on the appliance before it's connected to 230v. It's NOT the same as a device which can accept between 110- 250 volts, it's 120 OR 240 ( 240 is to all intents the same as 230). My answer is NO
Apr 19, 2014 | Kenmore 98702 Stacked Washer/Dryer
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
I live in germany (military) what is the power 120-240?
Good day!! The 120-240 power simply means the supply of your TV can be plug in to 120 Volts AC to 240 Volts AC that will come out to your outlet.For example your outlet is 120 Volts AC you can plug in your TV in there.In short your TV supply is auto-volt.
I hope this information could help you.Thank you.
Apr 17, 2011 | Proscan 24LED45QA TV
How do I know if my Hotpoint oven 920 years old0 is on a 220 0r 120 line? The serial plate says 120/220.
An oven uses both 120 & 220 -- actually it would be 120 volts and 240 volts or nominally, 110 volt and 220 volt.
The 120 is used for the lights. The 240 is used for the heating elements.
A 240 volt breaker (nominally 220 volt) -- supplies both 120 and 240 volts depending on how the supply is connected to the appliance.
There will be a 240 volt (nominally 220 volt) breaker in the main panel for the oven. This is two 120 volt breakers side-by-side with their toggle switches connected together with a strap across the top of the toggles.
Charlie
Jan 11, 2011 | Hotpoint Ovens
Dryer works but will not heat up and the timer does not turn
check the input power for 240 volts,sounds like you've lost one leg of power (120 volts) needed to operate the unit,the element requires 240 volts and the motor needs 120 volts and the timer needs 120 volts to operate and they normally split these two items to balance the power load
Oct 02, 2009 | Dryers
Just clicks and wont turn on
Hi Justin6992,
You have been very honest and told us the facts behind the fault, thanks for your good fault description...
Now what you have done by flicking that little switch is:-
Altered the input power design of the stereo system.
The switch is there so that the user can connect it to either the USA power supply of 110-120 volts, or connect to the Australian/New Zealand power supply of 230-240 volts.
When you turned the switch over you lowered the input to 110-120 volts yet it was still plugged into a 230-240 volt power supply.
This has blown a component inside the power supply and
now it must be replaced.
This is a specialised replacement process by a service man..
The clicking sound is made by the internal power supply (Its called a switched mode power supply) and it has detected the blown component and it is trying to reset itself automatically for you, but it cant because of the faulty component.
Its very clever in its design and if it wasnt clicking there would have been quite a loud 'bang" and a lot of smoke when the switch was moved to 110-120 volt position.
Regards From YUBEUT
Dec 04, 2007 | Philips MCM570 CD Shelf System
Inverter Xantrex MS2000 Sine Wave  Charger 809-2010 Logo
103 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
