Question about Refrigerators
My american fridge don't appear to be cooling properly and some black stuff keeps appearing in the fridge compartment. it also keeps making rattling noise now and then!! Can you help?
    President:
  • 1,314 Answers
My advice is check and replace the fan in the freezer or the fan blade remove the back cover where the fan is in the freezer the freezer does all the colling for the unit
Posted on May 09, 2008
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
My frost free fridge freezer is working but flashing de on the front. I'd like to know what it means
Error codes are brand (and often model) specific. "de" likely indicates something in the defrost process, especially on G.E. Check for ice build-up in the freezer cooling coil. The control board would be suspect, but must be checked to confirm the precise fault.
Oct 20, 2014 | Refrigerators
My f&p fridge model e442b not cooling properly only one fan in fridge/freezer divide which is operating but cold air not seeming to get to top compartment fridge has been completely emptied checked...
It is possible that it is creating ice in the air passages due to a bad defrosting element.
Unplug it and let it melt, if the problem appears to be fixed, but comes back in a few days, that could be the problem
Nov 21, 2017 | Fisher and Paykel Refrigerators
Frigidaire model FRS24WNF. Will not freeze (except the lower compartment of the freezer) nor transfer cold air to the refrigerator. The back panel above the coils freezes up. Once I turned off the unit...
Of necessity, this is going to be a very LONG answer, BUT... it COULD save you from buying another fridge. There could be several causes for your issue, but the most likely is a blockage [usually a buildup of "frost"] of/in the duct that carries cold air from the freezer compartment to the fridge compartment.
Not all, but MOST refrigerators work by having two controls for the two zones [freezer and fridge sections]. The first control [an actual thermostat] is for the freezer, and is what actually turns the compressor on and off. The other control is for a "damper" in the duct [or, SOMETIMES controls an in-duct FAN] from the freezer to the fridge section.
The compressor system cools the freezer, and the refrigerator section is cooled by transferring colder air from the freezer.
The freezer control should be set to keep the freezer at about minus 10 degrees Fahrenheit to about zero degrees. Then the fridge damper control [usually the control with the letters A, B, C, and D] is usually set to about the MIDDLE position, hopefully to keep the fridge section about 34 or 35 degrees to a max of about 38 degrees.
SINCE you say that the FREEZER IS operating PROPERLY, I suspect that the DUCT that is supposed to supply cold freezer air to the fridge is somehow blocked, and this is usually caused by an accumulation of FROST [frozen water VAPOR] in the duct. Note, and write down the "settings" for BOTH controls. You'll need these later to restart the fridge.
Although the "fix" is a pain in the ____ it is not that difficult. Here are the steps to correct:
1. Get one or more ice chests/coolers.
2. Remove ALL contents from the freezer and place together in one, or if necessary two of the coolers well covered by bag ice to preserve the contents. Put a couple of bowls, or anything, in the bottom first to keep the frozen stuff above water from the melting ice. Then pack the frozen stuff very tightly with as little open space as possible. Then pour crushed ice on top. Several times a day, drain the melt water from the drain on all the ice chests, and as necessary, add ice to replace that which melted.
3. Do the same thing with everything from the fridge section.
4. Then turn OFF the refrigerator, and CLEAN both the fridge and freezer VERY WELL. IF you don't clean both the freezer and fridge WELL you will get mold, mildew, and probably an offensive odor!
5. Then PROP the freezer AND fridge doors open AT LEAST a couple of inches, or MORE if possible. This will allow warmer household air inside. IF you have a portable fan to blow house air into the fridge section that will cause the frost to melt faster.
In a house with no air conditioning, in the summer, the blocked duct should thaw in well less than 24 hours. If you have air conditioning and no fan circulating air into/through the fridge it could take 2 or 3 days, but in any case, after 3 days, you should be ready to test the fridge.
6. Plug the fridge back into the wall outlet, set both the freezer thermostat and the fridge control back to their original settings when the fridge was cooling properly. [AGAIN I remind you that, at the very beginning, make note of, and write down the settings for both the freezer thermostatic control, and the fridge duct control]
7. Place a thermometer on a middle shelf of the fridge [and if possible, one in the freezer also] and check it/them after about 4 to 8 hours.
IF a frost blockage was the cause of the failure, the fridge should now be cooling properly again and when the fridge temperature gets down to below 36 or 37 degrees [F], then you can replace all the stuff into the fridge. IF none of the freezer stuff has thawed, then that can be replaced in the freezer. IF any has thawed, then cook it properly, and you can freeze it again if you want.
I know this is a lot of work, BUT... it sure is A WHOLE LOT LESS EXPENSIVE than replacing a refrigerator that DOESN'T NEED REPLACING!!!!!
Jun 30, 2011 | Frigidaire Model: FRS3HR5HB
Fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Aug 12, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Nov 12, 2008 | Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
