Question about Braun Syncro 7570 Electric Shaver
At regular times I get the message OIL on the display.There is no description in the user manual what to do and where and with what kind of oil I have to do the action.
  • Braun Master
  • 1,623 Answers
You will find the proper oil at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-accessories/braun/braun-shaver-oil-p-465.html
You should use a drop on the foil when about once per week
Posted on Sep 02, 2010
98 Oldsmobile Aurora There's a on my Dash it says information center and has the oil fuel speed all that it says low oil is there any way anybody knows how to reset that
Check your engine oil using the oil dipstick located on the engine - you need to add oil to the fill line as shown on the dipstick. You should have the oil replaced regularly (every 3-6 months) and keep your eye on the level if the engine is leaking oil underneath or burning a lot of it.
Mar 08, 2017 | Oldsmobile Cars & Trucks
How to reset change oil soon light
Oil Life Monitor Resetting (KD, KE)
Description
The engine oil life monitor will indicate when to change the engine oil and the engine oil filter - usually between 5 000 km (3,000 miles) and 12 500 km (7,500 miles) since the last oil change. Under severe conditions, the CHANGE OIL message may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 12 500 km (7,500 miles) or 12 months without an oil change.
The engine oil life monitor will not detect dust in the oil. If the vehicle is driven in a dusty area, be sure to change the oil every 5 000 km (3,000 miles) or sooner if the CHANGE ENGINE OIL message is displayed.
Reset the oil life monitor when the oil has been changed.
Resetting Procedure
Press the INFORMATION SKIP button on the DIC control panel in order to display the OIL LIFE LEFT message.
Press and hold the RESET NO button until the display shows 100% ENGINE OIL LIFE.
Jan 29, 2016 | 1999 Cadillac DeVille
How reset oil change light 2011 charger
Your vehicle is equipped with an engine oil change
indicator system. The "Oil Change Due" message will
flash in the EVIC display for approximately 10 seconds
after a single chime has sounded to indicate the next
scheduled oil change interval. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate dependent upon
your personal driving style.
Unless reset, this message will continue to display each
time you cycle the ignition to the ON/RUN position. To
turn off the message temporarily, press and release the
MENU button. To reset the oil change indicator system
(after performing the scheduled maintenance), perform
the following procedure:
1. Without pressing the brake pedal, push the ENGINE
START/STOP button and cycle the ignition to the ON/
RUN position (Do not start the engine.)
2. Fully depress the accelerator pedal, slowly, three times
within 10 seconds.
3. Without pressing the brake pedal, push the ENGINE
START/STOP button once to return the ignition to the
OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
Source: Owner's Manual page 293
Dodge Charger Owners Manual
Oct 04, 2013 | 2011 Dodge Charger
Reset oil change indicator on 2011 Dodge Charger
within 10 seconds.
OFF/LOCK position.
Oct 22, 2012 | 2011 Dodge Charger
What kind of oil do i use for a ryobi tiller
If it is a 2 cycle, use 2-cycle oil. If it is a 4-cycle use the oil mentioned in the manual. If no manual, I would use a 30 weight oil. Good luck...Lee
Nov 07, 2009 | Ryobi Cultivator
I don't have the owner's manual for my saturn ion 06. How do you turn off the oil change light once oil has been changed
1.Press and release the trip/reset button until the OIL LIFE message is displayed.
2.Press and hold the trip/reset button until a chime sounds five times and RESET is displayed in the message center. When the system is reset, the odometer will again be displayed in the message center.
3.Turn the key OFF. If the CHG OIL message cames back on when you start the vehicle, the system has not reset. Repeat the procedure
Oct 12, 2009 | 2006 Saturn ION
Engin oil life 50%
How often do you change your oil? Do you change it yourself? look in owners manual it should tell you how to reset your oil change message. Probably reset it through the radio, manual will tell you
Aug 24, 2009 | 2004 GMC Envoy
Change engine oil message stays on
the Change Engine Oil message is diplayed in the driver information center when the oil change is due ,,,,, to RESET display message , press the INFO button to display the ENGINE OIL LIFE message , ,, Press and Hold the RESET button untill 100% ENGINE OIL LIFE is displayed.
Dec 23, 2008 | 2001 Cadillac DeVille
Shaver shows "oil" How do I do so? nothing in owners manual .
http://www.service.braun.com/home.asp?rg=NA&c=US&l=GB&typ=ui&s=&seite=&sString=
The above in a link to brauns website. You can view or download the user manuals for all their products.
Steve
PS. It just says to put some oil on your finger and apply to the outside of the foil.
Dec 22, 2008 | Braun Syncro 7680 Electric Shaver
Display shows "oil!"
Per page 13 of a Braun Shaver manual:
If your skin is very dry and you notice a reduced
operation time of the shaver or if the display shows «oil!»,
apply a drop of light machine oil onto the shaver foil.
Jul 22, 2007 | Braun Syncro 7570 Electric Shaver
Braun Syncro 7570 Electric Shaver Logo
156 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
