FixYa.com
Tags:
Sony COM V.90 Modem
Sony Notebook Built-in Modem
By Beresford - usenet poster
Depends on the actual modem mfr. Take a look at
http://www.56k.com/trouble/int erop.shtml#k56disable for some info re disabling
K56 in some models.
--reed
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
Duke
Duke - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Before proceeding, let me suggest something I should have suggested right at
the get-go... Issue the ATi3 command in terminal mode.  Hopefully, it will
indicate V.90.  I've got a Rockwell based modem and it hasn't been upgraded to
V.90, yet.  The ATi3 command yields the following:
                ATi3
                V1.002-K56_DLP
                OK
If I decide to upgrade to V.90, I'm not sure as to whether it will be indicated
here or not.  If yours is an original and not an upgrade, I would think this
would be revealed under that command.
In article <366037c8.12192 @165.87.194.238>, rjm @ibm.REMOVE.TO.REPLY.net
No real need to go through all of that work.  I examined all of the lines I'm
familiar with and attempted to give you a reasonable explaination of what they
indicated.  There are numerous ways for the problems to be introduced that
might cause those indications and it is always harder to diagnose `blindly'.
Often times, some `small' thing that would be an obvious peculiarity and bring
notice to direct observance by someone experienced, will go unrecognized by
anyone else.
                ... <deleted>...
Duly noted.
                ... <deleted>...
I think it's the S37 register, but I'm not sure what you should be indicated in
order to verify that V.90 `only' (should it be available) is in effect.  I
believe that `S37:000' indicates the auto mode.
                ... <deleted>...
Yep, it may take awhile since the busy part of the season is upon us.  Just
hang in there.  There's a solution somewhere.
I've about come to the conclusion that it is one of two things... either a
defective modem, or the modem is receiving some interference directly from
another component in the laptop.  Like I said, all indications are that it is
compensating for some heavy distortion of the signal.  It could be something as
simple as a bad electrical connection (cold solder joint).  Of course, a "cold"
solder joint could be in the modem, also.
As a last resort, and since it's a laptop, is there a possibility that you can
take it to a friend's house, where you know "he" also has a good connection,
and attempt to check it out (briefly) there?  I'm running out of suggestions...
Tester98
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
In article <365ab413.57515 @165.87.194.238>, rjm @ibm.REMOVE.TO.REPLY.net
Ray,
In most cases, where a V.90 modem is involved, the V.90 protocol is attempted
first, if it is properly setup.  Make sure you're using the correct INF file
and review your manual in order to make sure you haven't inadvertantly disabled
the V.90 protocol with an errant additional command.
Sincerely,
Tester98
Solution #3
Not Rated (0)
Riddle
Riddle - usenet poster
Rating: 0%, 0 votes
In article <365c6b4a.169972 @165.87.194.238>, rjm @ibm.REMOVE.TO.REPLY.net
Ray,
I can see that this is becoming a considerable irritation, but stick with me
and don't despair.  If "I" am ultimately unable to help you, I'm sure someone
in this newsgroup can.
Using the information you gave in the original post, I drew my "conclusions",
such as they were.  Irrespective of the possibility of getting a faster speed
from another computer while on the same phone line, the conclusion was that it
wasn't a "modem" problem.  That doesn't exclude the possibility that in both
cases, concerning the original computer, you may have used a similar setup
which limits the best possible connection achievable by "that" computer, no
matter what modem is in use on it.  In other words, you may have implimented a
maximum port speed which is limiting the connection and operation.  But, the
original post didn't seem to lead in that direction and I've subsequently not
gone in that direction, "yet".  If you find the following to be non productive,
we will proceed in another direction as appears to be warranted.
That notwithstanding, assuming the INIT string you presented is correct for
your modem, I think you're missunderstanding its proper implimentation.  The
most limiting factor in modem communications is dictated by the phone lines.
If the line conditions don't permit a specific speed, then it is useless to
expect the modem to be "forced" into operating at that speed, which the phone
lines will not allow.  With this in mind, you should set the modem (high end)
at slightly more (one increment) than the highest speed you appear to be
getting, and set the lowest speed at that which is the least acceptable.
Assuming that the "12" means to use V.90 the protocol and "1" means to enable
automode, you might try this:
                +ms=12,1,28800,42000
Also, don't rely on the "Connect" speed that may be indicated when you first
log online.  It is better to go into a terminal program immediately after your
online session and type "ATi6" (without the quotes) in command mode, in order
to display the parameters of that last session.  You should see a line
displaying something similar to 38000/28800, where your (actual maximum)
download speed was 38000 and the (actual maximum) upload speed was 28800.  You
should also see a line which indicates the protocol implemented.  If ATi6
doesn't display this info, then try ATi5 or ATi7.  If you have an indication
that as much as a speed of 40000 was attatined, then you might incrementally
raise the upper speed and review the subsequent data in the same manner.  Keep
in mind, that if you have a download speed greater than 33600, then you have
one of the 56K protocols which was accepted by both ends of the communication.
Please keep in mind that almost everyone on the internet uses a different setup
in one a
Solution #4
Not Rated (0)
Joey2
Joey2 - usenet poster
Rating: 0%, 0 votes
Ray,
In article <365cb401.188589 @165.87.194.238>, rjm @ibm.REMOVE.TO.REPLY.net
                ... <deleted>...
Ok, sounds good.
                ... <deleted>...
Have you tried this?... +ms=12,1,42000
                ... <deleted>...
That's good.  At least we won't find that we're taking readings from different
sources.  Since you do check &V1, would you mind posting the next one, along
with the &V command results?  I will assume that `all' issues previously
mentioned have continued, unless otherwise specified.
                ... <deleted>...
Have you gone one step further and tried the above mentioned "limited" INIT
string I suggested?  Although I do have a 56Kflex modem on another port of my
computer, I only use it on very rare ocassions and therefore, am no expert on
the Rockwell/Lucent chips.  As a matter of fact, I've been dissappointed in the
fact that I can only get from 38000 to 44000 connects with it.  Since I already
have the V.90 ability in my main modem and I would lose the 56Kflex if I
flashed the other one, I've refrained from changing it.
But, I did notice something peculiar about my main modem which is a USRobotics.
 I wasn't able to "restrict" the range of its operation as is indicated in the
manual, much the same as you mentioned in a prior post.  Last night, I
refrained from specifying the upper limit and only designated the lower limit,
which is not a "recommended" setup by USR.  It worked in giving me a V.90
connection of 50666/31200 where before, I had only been able to achieve a
connection of 41333/26400.  It consequently occurred to me that a similar
application of the proper commands in your case may have some benefitial
effect, also.
                ... <deleted>...
I'm glad to hear it.  We may whip this thing, yet.
Tester98
Solution #5
Not Rated (0)
Hart
Hart - usenet poster
Rating: 0%, 0 votes
In article <365f34dc.55746 @165.87.194.238>, rjm @ibm.REMOVE.TO.REPLY.net
... <deleted>...
That particular INIT string was just a guess, considering something I
experienced with one of my modems.
Your "Line Quality" leaves something to be desired, judging from the respective
line.  Also, the "RBS" line indicates far too much having to be compensated for
in the way of distortion of the signal.  You can see the results of it in the
"Rate Drop" line, which is tremendously high as well.  I've not seen it
mentioned in this newsgroup, but there is always the possibility that there is
some device introducing noise on the line.  If you can periodically hear noise
when you are on the telephone, it should be corrected.
                ... <deleted>...
With the V.90 protocol, you should hear two very distinct `pings' about a half
second apart, near the later part of the negotiation.  If your modem isn't
attempting to implement the V.90 protocol, one of these three things is most
likely:
1) You are experiencing line noise problems that prevent the protocol's use.
       Line noise appears to be a possible hinderance.
2) Your modem isn't attempting V.90 at all.
       a. Are you sure you have a V.90 capable modem?
       b. Do you know which register indicates the protocol?
3) The POP doesn't support V.90, yet.
That's about it for now,
Tester98
Can you Help with these Modems problems?
Modems
cant find a pci modem for my...
is there any way to fix this Answer This...
Modems
trigonometry
2 csc x= sin... Answer This...
Modems
can't connect to internet
i need the corrent ip address... Answer This...
Modems
HP Pavilion dv1000
i formatted my laptop.. since... Answer This...
Modems
test stam14
test stam14 Answer This...
Repair Service
Find Modem Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
