I have Philips DVD Player model DVP3256x/94. Currently showing all CDs lock. I tried unlcoking CDs, Disk Unlocking option is not enabled on the setup mode. Please advise...
SOURCE: Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Posted on Oct 27, 2008
ANDREIONELUV
  • 29 Answers
SOURCE: philips dvp 5992 Disk drive wont open
HELLO MY NAME IS ANDREI
I THINK YOU MIGHT OF LOCK THE DISC. BY DOING THIS YOU BLOCK THE PLAYBACK OF THE CURRENT DISC. SUBSEQUENT ACESS TO A LOCKED DISC REQUIRES A SIX DIGIT PASSWORD THE DEFAULT PASSWORD IS 136900. THIS WILL UNLOCK THE DISC LOCK FEATURE. MAKE SURE YOU GO YO SETUP AND CHOOSE UNLOCK DISC LOCK PERMANENTLY OR IT WILL KEEP DOING IT EVERYTIME YOU PLAY THE SAME DISC. HOPE THIS MIGHT OF SOLVED YOUR PROBLEM.
Posted on Jan 15, 2009
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
SOURCE: dvd on lock
Dear friend,
Pls upgrade ur dvd player. the problem will be solved.
Posted on Mar 29, 2009
  • 1348 Answers
SOURCE: my dvd palyer shows NO DISC for any disc i want to play.
the laser is probably no good or the tiny motor that spins the disc is no good.there is a clamper assembly that goes in the hole in the disc.turn it and see if it spins freely.there is a bronze bushing on the top of the motor driving it ,and a small drop of light oil on the bearing will make it work again if it is gummed up..if the motor does not get the disc speed from 250 to 600rpm,fast,the laser does generate the proper info and the computer says error.yes the motors can be replaced,but the cost is as much as a new one
Posted on Jul 03, 2009
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
Dvd on lock
Dear friend,
Mar 03, 2009 | Philips DVP3040 DVD Player
READING NO DISK
the disk will not spin at all. the screen says no disk. this device is knew . what will cause this
Oct 08, 2008 | Philips PET702 Portable DVD Player
LG RC797T Region Unlocking Codes
Purchased two of these VCR/DVD recorders (for the ATSC-digital tuner) in March 2007 at Best Buy. They play PAL/region 0 out of the box. To enable region-free playback I used the CD-ROM previously made for my LG LST-3510A. Visit this link for the files to burn your disc:
http://aiwaownersnetwork.tripod.com/pages/lg/5000_series_firmware.html
Next:
--Power on the player and load the CD-ROM
--In a few moments a text box appears displaying current DVD region and a second line to change DVD region
--Press the number you wish (most likely "0") on the remote control
--Press "Enter" on the remote control
--In a few seconds the player will eject the disc. Remove the CD-ROM from the tray and power off
Upon powering on the player my region 2 and 4 DVD's play fine but Macrovision still remains.
OR
Click the HOME button on the remote with the unit in 480i resolution
Click the setup page
Click Start
Click TV Aspect
highlight the 16x9 wide aspect ratio
enter on remote control this coded sequence:
1397139
Edit specific "Options"
Option 2: 35 (enables Divx/Xvid playback)
Option 4: ff (enables Vcd and SVCD playback)
Option 5: ff (enables region free playback (region 0) DVD playback)
Option 6: ce (enables Insignia brand startup logo on boot)
Option 6: c0 (enables LG brand startup logo on boot)
Sep 19, 2008 | Denon DVD-3910 DVD Player
Dvd player
You might be able to convert them to DVD-Video format if you've got a DVD burner and the right software.
Another possible option would be converting them to a Video CD/Super Video CD if the DVD player can play Video CDs or Super Video CDs and you have a CD burner and software that can burn VCDs/SVCDs
CLick this Link to download software
SAM ANDERSON
Sep 16, 2008 | Televison & Video
Philips DVD Player model DVD622/37 wont play movies
Unplug/replug unit, try commercial dvd's again. If fails - call Philips- find out about replacement options
Jun 29, 2008 | Philips DVD 622 DVD Player
PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
Mar 16, 2008 | Philips PET702 Portable DVD Player
My DVD player does not play VCDs or music CDs
replace spindle motor,so i think ur problem vill b solved.. no need 2 change th lense..
Jan 01, 2007 | Philips DVD 622 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
