Question about LG Televison & Video
I have a new 42PJ650. How do I connect and see Vcr & DVD
  • mdtwohig986 Sep 01, 2010
    Thank you Sebin.
    I already have made these connections.
    What I want to know is how to switch from TV programs to DVD disks & VCR tapes using the supplied Remote control.
    Thank you for your assistance so far.
    Martin Twohig.
  • 712 Answers
There are three holes on the TV marked with different colors, most probably Yellow, Green and Red or anything like that. Connect similar colors together.
Posted on Sep 01, 2010
  • Sebin Punnacheril
    Sebin Punnacheril Sep 01, 2010
    Now please look your remote for options like AV or AV/TV or anything similar. Press that button and you will be carried to a channel which plays your DVD or VCR or whatever connected.
    Best Regards. Thank You.
  • mdtwohig986 Sep 20, 2010
    All is clear now. Thank you for your assistance and help .
    Martin D.
We did use the Red & White RCA cable in addition to a coax cable. When the VCR tapes starts there is a burst of static coming from the speakers. The dvd sound is perfect but absolutely no sound from...
This is a combo unit (DVD/VCR), which should have RCA AV outputs on the rear - component video, DVD, and DVD/VCR. The latter output allows tapes to be heard and viewed, as well as DVD movies when the respective deck is selected via remote. There appear to be 2 S-video outputs on this model according to the user specs guide.
In other words, examine the rear of your combo unit - and connect the red-white RCA cable to the DVD/VCR 'OUT' sockets on the rear of the unit (L & R) and the S-video cable to the 5-pin socket in the same section if that is what you use instead of yellow RCA. This should fix the no-sound on VCR problem, and the bonus is it won't cost anything, and you don't need a workshop repair or setup quote.
You probably connected the cables to the main DVD output instead of DVD/VCR.
I hope this helps somewhat.
Mar 07, 2011 | Toshiba DVR670 Player
How do i connect my magnavox zv420mw8 to my cable boxconverterand modulator
the cable from the wall is to the cable box in....(do have monitor) cable box out to tv coax in...dvd / vcr & audio outs to tv ins....and tv outs back to dvd vcr audio in....tv is on ch 3 for cable...look for your dvd /vcr or aux ch when want to look a dvd or vcr...now set the dvd to ch 3 settings and cable broadcast...your cable box will determine what you record....note HBO may not record on DVD, but will on VCR tape
May 15, 2010 | Philips Magnavox DVD/VCR Dual Player
DVD and VCR recorder with this product?
As long as you have Composite/SVHS Video Input, Usually a Yellow RCA Socket or a 4 pin Mini-DIN & red & White, AV (Audio Visual) RCA sockets on the machine, AND you can select an "External" input, then YES anything that can connect with this way will work.
Feb 10, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
When I try to play a DVD or VHS on my GO Video DVD/VCR Combo machine, I get audio but no video & the TV (Sanyo 37" HD) says "No Input". I've checked connections, the TV has multiple video inputs but I...
  1. I found the problem - on the back of the VCR/DVD unit there are 3 outputs: L (Wht) & R (Red) Audio + Yellow Video out. The cable from it to the TV was labeled Red/Audio,White/Video, and was connected to the R & W outs, but actually the Wht should have been connected to the Yellow Video out. There is so little space in the TV cabinet/stand that even though I turned the unit around to see the connections, I couldn't see the other (Yellow - Video) out until I pulled the cables out. It's working fine now - I'm not sure how things got connected wrong, since it was working OK before - possibly when I signed up for AT&T U-Verse & the installers moved things around. I'm very happy with that service, by the way - better than Comcast & cheaper, and didn't mean to imply the connection problem was their fault. I may have moved things around in the new cabinet & not realized I hooked up to the wrong outs...
Jan 03, 2010 | GoVideo Go Video DVD/VCR Combo
Where to put scart leads into dvd and video player and panosonic tv
Look at the rear of the TV/VCR/DVD & you will see long black sockets where the Scart cable is connected onto, these are normally indicated as AV1/2 etc. You can then take Scart from DVD to TV on AV1. Then on AV2 take the second scart from VCR to TV or you can take the second scart from the DVD to the VCR & from the VCR to AV2 on the TV.
Nov 29, 2009 | Panasonic CT-32SL14 32" TV
WHAT IS THE CORRECT WAY TO SET-UP TV, VCR, DVD, & DIGITAL CONVERTER BOX?
Connect the antenna to the converter box. Connect the output of the converter box to the vcr. Connect the output of the vcr to the tv. Connect the dvd to the component input (Red-White-Yellow) of the tv (if there is one. If not then connect the dvd to the component input of the vcr.
With this arrangement you will be able to tape programs on the vcr if you want. If the vcr is not on the signal from the converter box will pass through to the tv.
Jul 06, 2009 | Insignia Digital-to-Analog Converter for...
How do i connect this vcr to a dvd recorder?
Take a scart cable & connect it from the VCR to AV1 on the DVD recorder. Then when you want to record from the VCR select either AV1 /EXT.1/ AUX1 on the DVD recorder as your choice of input source.It depends on the make of your DVD as to determine how the manufacturer has named this inout.
Jun 26, 2009 | Mitsubishi HS-U448 VCR
Televison & Video Logo
Computer Repairing
Computer Repairing
