Question about Whirlpool LSR5132PQ Top Load Washer
Whirlpool basic top loader
My daughter was testing fuses while the washer was running, and accidentally turned off the fuse in mid-cycle. Now it doesn't react. It's full of water, and makes no sound, no sign that it's getting electricity. I've tried plugging it into another outlet but it made no difference. I need help, as it's full of water, not to mention clothes.
  • 1 more comment
  • barberboss May 09, 2008
    She was testing fuses at the fuse box, to turn off electricity so she could hook up a lamp in another room. It had nothing to do with the washer. I wasn't home when it happened, so I'm not absolutely sure how it all came about. But my washer seems as good as dead, stopped just before the rinse cycle. How can I drain it?
  • barberboss May 10, 2008
    As I said in my first description, I already tried another outlet, that I know works, and there was no change. All my lighting and other appliances all work fine, and so does the outlet that my washer is currently plugged into. That was the first thing I tried.
  • robert samples May 11, 2010
    you need to more specif on what she was testing and how as there are no fuses in this machine and why was she testing in the first place plug a light in the out let where the washer is see if it lights then check the breaker if it don't make sure the lid is closed if all that's ok turn it back to wash like it is and tell me if it washes
    President:
  • 1,314 Answers
Ok got ya now hon you may have a bad lid switch nothing to do with power On the control panel locate the two phillips screws at the back or front of the control panel at the bottom where the panel meets the base .Back them out far as you can .Pull the control panel forward and tilt it back(im assuming you've unplugged the washer first) you will see a connector that goes to the lid switch unplug it now on the part of the connector that goes up to the control panel put a piece of wire from one terminal to the other to jump the connection then pull the knob out if it works then replace the lid switch
Posted on May 13, 2008
    Genius:
  • 1,073 Answers
Since you can not get the washer to run if you plug another item into the recepticle will it work use a hair dryer to test if the hair dryer works then the receptical is good and you have a washer problem if the hair dryer does not work then you have a wiring issue on the house wiring
Posted on May 09, 2008
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
www.appliancesonlineblog.com.au/.../6-common-washing-machine-prob...
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
https://www.youtube.com/watch?v=dx2vCzO8828
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
My kenmore top loader 80 series wont start. I traced power to a black cylinder next to motor. i get nothing, no water fill or motor action in any cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following Whirlpool / Kenmore service manual for top load, direct drive washers.
It has troubleshooting and component testing procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Jun 09, 2010 | Kenmore Washing Machines
Is there a rest button on a kenmore dryer? I accidentely left some clothes on top of ther dryer while running the dryer and it shut off in mid-cycle. The top of the dryer was very hot, so I thought there...
Yes, there are - there are two switches. Thermal fuse and the High Limit switch located behind the back panel. Thermal fuse is a white fuse with two blue wires and the High limit switch is a black cylinder shaped fuse above the heating element. Good Luck...
Nov 16, 2009 | Kenmore 63942 Dryer
My old Whirlpool DU8500X stopped yesterday in mid cycle and now will do nothing. Standing water in bottom. Tried breaker reset already.
If it is a top loader, a whirlpool normally has a fuse in a cartridge holder inside the top panel. Once panel is opened, trace the power wires, and look carefully for the fuse cartridge holder. Replace it. This fuse normally protects overloading of washing so as not to damage motor.If the fuse is good, then try and bridge the door limit out for a short while to ascertain if that is the problem. Please let me know.
Oct 02, 2009 | Dishwashers
Washer stopping mid-cycle
Push down on lid. You may have a bad lid switch. Start machine and press the switch down with something like a screwdriver and see if the motor runs.
Jul 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door switch problem top loader
I fixed mine with a toothpick and a piece tape. Make the tab on the door longer that activates the switch. Try triming the lid bumpers
Apr 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR5132PQ Top Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
