Question about Dishwashers
Helloo! Dishwasher candy futura cdf 312A not work. On button 50 and 1/2 at the same time flashes controls light. I hear drain pump how to boot. When I turn dishwasher off-on defect not disappears. Please help me.. Thanks
  • 11 Answers
SOURCE: Model 17019 ~ Clean light flashing
try pushing heat dry then normal back to back three times. then start. this should clear it up but only temporarily. you have a problem in your heat element or your control board.
Posted on Mar 21, 2007
  • 209 Answers
SOURCE: Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Posted on Oct 07, 2007
  • 249 Answers
SOURCE: Candy cs455 m dishwasher tripping out power
check heating element
Posted on Mar 21, 2008
SOURCE: dishwasher won't drain
Can you kindly help me?
Posted on May 17, 2008
huuum
  • 750 Answers
SOURCE: candy cs 455m dishwasher
Welcome to fixya.
I'm Huuum at your service.
You said, Candy keeps blowing the fuse. It is not the main fuse in the house(was checked). I
You think it may be the heating element. You asked any advice?
I feel you have a short somewhere . and who knows where? How old is the appliance and what did it cost?
I've seen 3 or 4 people in the past 24 hours that replaced the heating element in the same candy 455 dishwasher and still had the problem.
They told me they felt they did not want to spend any more money ont his unit cause they said, it was an inexpensive model!
So my clients told me!
Here is an interesting report I just read.
Repair or replace you appliances?
When to pull the plug on your old Appliance
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your appliance,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your appliance is under warranty or less than four years old
paying for a repair makes sense.
Note that appliances under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your appliance is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new appliance.
Data also shows that it doesn't pay to fix a less-expensive appliance
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a appliances you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave a rating before you sign off!
Thank You, HUUUM
Posted on Sep 30, 2008
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Samsung DMT - 400 delicate light blinking
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Why won't my Kenmore dishwasher display work properly?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Flashing indicator light
follow the next steps and fix it. God bless you
Check Fault Codes
Drain Pump
Touchpad
Jul 06, 2013 | Dishwashers
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
My dishwasher get stuck after the pre rinse with both lights ,the pre rinse and wash lights flashing,failing to go to the wash programe.
It is likely the drain pump or hose is blocked.
It might be helpful if you can provide the full model number of the candy dishwasher.
Dec 12, 2010 | Candy Dishwashers
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Dishwashers Logo
290 people viewed this question
Top Dishwashers Experts
Owen Barnes
