Question about RIM BlackBerry Pearl 8100
Bluetooth for Blackberry Pearl!!!!
When i try to bluetooth ringtones from another phone to my BB pearl, it says unable to connect and the file won't transfer. Is there anything that i need to change in my bluetooth settings or something? HELP =)
  • Anonymous May 18, 2008
    data connection refu...
I use to get that messege because my phone didnt have enought memory for the transfer. I bought the memory card so now it's fine.
Posted on May 09, 2008
I cant receive anythin om my bluetooth yet i can send,,,my device cant be paired
Hi,the BlackBerry Pearl is a versatile mobile phone. It's primarily a Smartphone that's suitable for business use but it's also equipped with some decent entertainment features. The pearl can also play music files which you can enjoy with the help of a hands free Bluetooth headset. Let me teach you how to pair a Blackberry Pearl Smartphone to a Bluetooth headset.
Things You'll Need:
* Blackberry Pearl Smartphone
* Bluetooth headset
Turn on your Bluetooth headset by pressing and holding the multifunction button.
Check if the LED light is a solid blue. Turn off the headset and repeat the first step if the light is blinking.
Activate the Bluetooth wireless connection on your BlackBerry Pearl by Going into your "Settings" menu
Select the "Options" menu to go to your connectivity settings
Click on the "Bluetooth" option to activate the connection
Choose the "Add Device" option on your BlackBerry Pearl to locate the headset
Wait for a while as your Smartphone locates the Bluetooth headset
Enter 0000 for the password after selecting the headset to complete the Bluetooth pairing process
After that, your Done !!!!you can now send and receive. But after following this instruction and no solution yet, that means there is something wrong with your blue tooth. Corrupted. You will need to reset the phone.
Mar 11, 2011 | RIM BlackBerry Pearl 8120 Cellular Phone
8130 blackberry
go to media file and depending on what type of file (ringtones,pics etc) you can choose to recieve it bluetooth
Sep 05, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I can use my bluetooth when sending something out to another phone BUT CANNOT receive anything back via bluetooth
only two possibilities
1. You must have selected invisible to others in bluetooth option. kindly de-select it.
2. The path where the files are saved must be your phone memory which would be less thats why unable to receive bigger files try to receive smaller one if you get it then change the destination to your memory card.
Aug 12, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Don't have the book for my blackberry pearl 8100
Follow this link.
http://docs.blackberry.com/en/smartphone_users/subcategories/?userType=1&category=BlackBerry+Smartphones&subCategory=BlackBerry+Pearl+8100+Series
Aug 02, 2009 | Jabra BT130 Wireless Headset
I can send files via my blackberry pearl 8110 bluetooth, but iam
1. Go to Media.
2. Hit the menu key (left of trackball) and select Explore.
3. Browse to the folder you want to store the file in.
5. Hit Menu key again and select "receive using bluetooth."
6. Send from the other phone.
You'll have to do this for each file individually.
Also make sure that you have paired with the device you are trying to receive from. In my limited experience i noticed that NOTHING transfers unless you are paired.
There is one more setting I would check, go to OPTIONS/SECURITY/GENERAL SETTINGS/make user the the
option for CONTENT PROTECTION is disabled.
Jul 18, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry 8120 bluetooth
First off, did you pair with the phone? Open up your bluetooth menu (under settings) and search for the other phone. After you pair (the passkey is what you choose each time) you'll be able to receive bluetooth connections.
To receive files over bluetooth, you'll need to open up your media area, click the blackberry button, and scroll down to "Receive using bluetooth". At that point, send the file using the other phone and enjoy!
May 21, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Cant receive files via bluetooth, cant transfer files from comp
go on to your media then music, and press the blackberry button and recive a file should come up then do it like that.
Feb 28, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
Okay,
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
And remember, your incoming file transfer WILL NOT WORK UNLESS YOU FIRST "PAIR" (CREATE A FRIENDSHIP BETWEEN) THE DEVICES, go into Media and CLICK MENU-->RECEIVE USING BLUETOOTH!!!
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Plantronics p590 + BB Pearl
Pearl 8100 can not output media audio to Bluetooth. Another BB might.
Sep 12, 2008 | Plantronics - Bluetooth Headset Plus Base...
RIM BlackBerry  Pearl  8100 Logo
83 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
