Question about LG WM-2277HW Front Load Washer
My lg washer would not drain, so I clean the front filter and there was junk in it. put it to work but will not drain again and would not do spin cycle
    Scholar:
  • 91 Answers
Hi dear.There must be more of that junk blockage between tub to pump hose.To be make sure,it's not blocked,please open the filter,pour some(1 or 2Lt/s of) water inside drum & watch for it to come out of the filter housing as quike as possible.If it's not coming out easly, means it's blocked & needs to be clean it.I hope that helps.Thanks.
Posted on Sep 01, 2010
Front Loader LG Inverter 7.5kg model WM-12330 FB On the last wash it wouldn't drain the water away. Tried 'drain' programme and rinse & spin programme - all works normally till it needs to drain and...
Have you already check your drain clean out? If it's not draining, you'll need to manually drain the washer, via the small hose that pulls out, once it is drained you can unscrew the large clean out filter, and see if anything is caught up in that area.
If all that is clear, it's most likely, you'll need a new drain motor. Also, did you notice if your getting a "OE" error code on the display?
Feb 28, 2011 | LG WM-2277HW Front Load Washer
Samsung WF448AAP chimed and read to check filter. I drained the water out and cleaned the fillter. It had 2 quarters and a bunch of junk. I cleaned it and restarted machine and the washer starts of...
I would believe that the water pump has given out. If it is going thru the spin cycle after you drain the tub of water it is almost certainly the pump.
Nov 12, 2010 | Samsung WF448AAP Front Load Washer
During a wash cycle, the washer will not spin, and displays the message OE after a few minutes of the motor running, but no spinning.
OE drain error. Water not drained after 10 minutes. Look for junk in the filter or pump.
more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 29, 2010 | LG WM2455 Front Load Washer
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
Waher will not start
IF YOU DONT HAVE THE RIGHT TOOLS TO BREAK IT APART AND PUT IT BACK TOGETHER AND THE EXPERIENCE IS CHEPEAR FOR YOU TO CALL A TECHNICIAN OR BUY A NEW ONE!!!
TO FIX THIS PROBLEM IS A LITTLE TO HARD!!! NEEDS TO HAVE EXPERIENCE!!! SORRY!!
Oct 05, 2009 | LG WM0642H Front Load
My LG front loading wm1814cw washer is leaking from the front panel (not from the door but underneath the front panel). I have to say about half of the water from the load is in the drip pan at the end of...
On the bottom left side there is a cover cap open it up an there is a drain pump filter and a drain plug. plug may be lose. But clean the drain pump filter.an tighen the plug. if that dont work call 1-800-243-0000
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Whirlpool LHW0050PQ Front Load Washer
Basically,the machine you have is garbage! - I have one also, It is less than one year old and the repair folks have been out 5 times. It doesn't spin either!
I'd call this one a lemon!
Apr 14, 2008 | Whirlpool LHW0050PQ Front Load Washer
OE problem with the LG WD - 12270BD Washer
Turn the knob to start and restart again let it run thru the course.
AND IF THIS DONT WORK TRY THIS:
Put knob on spin and let it run thru the course.
Nov 26, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
51 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
