Question about Impression Products Impression M1 Wireless Internet Keyboard/Mouse
Mouse doesn't move
My friend has a mouse that won't work. It doesn't move, but if there's something under it, you can click. It's a laptop and her touchpad works, but she's got a dock and when she puts it on the dock, the mouse won't work.
I have changed mice, changed USB ports it's plugged into, just restarted the computer without changing the mouse...none of them have helped.
Any suggestions?
Well in case of opto-mechanical mouse all u hav to do is open d mouse and just clean d rollers(as d ball moves d rollers also move and that decide d X-Y coefficients) which are clogged with sticky dirt n dust.
In case of optical mouse it's d crystal which is most vulnerable to failure,so after detailed tests procedures change d faulty component,u might require professional guidance.
Also cleaning d lens below the LED will help.
Repairs of optical Mouse is not worth it,considering d obsolute nature of electronic circuits,and d rapid fall n d prices,replacing is d only option for an optical mouse
Posted on May 31, 2008
Mouse won't function at all
Buy a new one and see if that cures the problem.
Jun 05, 2017 | Dynex Computers & Internet
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
I cant unlock my mouse sensor..
If you can't unlock your mouse sensor then follow these instructions down below:
To make your mouse MOVE first you must
1.Put your mouse usb in your laptop in the usb holders
2.After you done, something should pop up a few seconds later near the bottom right hand side, saying usb mouse connected.
Try moving your mouse now.
if doesn't work:
go in the control panel ( you can find that in your window by pressing the window button on your key bored)
3.Then there should be a topic named " Hardware and sound" click the first topic called " view devices and printers"
4. After you clicked that there should be on the top on the page "Devices" and the bottom should be printers and faxes.
5 then you can double click the device to look if right one. DONE!
I hoped this worked! ^-^
Sep 29, 2012 | Acer Aspire 5102WLMi Notebook
How to unlock a mouse on a laptop
On the top of your keyboard there should be F keys like F1,F2 etc.
Every F key has a little picture.When you see a touchpad picture press Fn+F5. According to my Laptop. For example if your touchpad picture is at F6 then you would press Fn+F6.The Fn key should be located near the ctrl keys. If this does not work then try the following steps:-
1 Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel."
2 Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link.
3 Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button.
4 Click the "Apply" button and then click the "OK" button.
Apr 30, 2012 | Dell Computers & Internet
Cursor won't move on my Acer laptop
Dear Friend,
On your desktop press the following key conbination: Fn + F7 if not, there must be a problem with your mouse pad. It might also be that your OS takes time to load or freeze and it make it look that the mouse is not working. You can also try and external mouse.
Good Luck!!!
Nov 06, 2011 | Acer Computers & Internet
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
I cant get my mouse to move on my samsung lapton
It is possible to turn the mouse pad off. On this laptop, the Fn key plus the F10 at the same time should toggle the mouse pad on and off. If this does not help, try an external mouse. If the Fn + F10 key does not work, but an external mouse does, make sure that you have a driver installed for the mouse pad by doing the following: Click start, then right-click on computer (my computer if you are on Windows XP), and click Manage. When the Computer Management window comes up, look in the left hand pane, and click on Device Manager. Then look in the right hand pane for mice and other pointing devices click the tirangle or plus just to the left of mice and see what pops out from underneath. If any of those have a big yellow exclamation mark, then there is a problem with the driver. right-click the problem driver and click Uninstall. Tell it yes, you want to do that, and then, after it is finished, right-click on the node at the top of the right-hand window that represents your computer, and click Scan for hardware changes. make sure you are connected to the internet, and tell it to connect to windows update to find the right driver. Follow the wizard to finish installing the correct driver. If you see something under Mice that has the word touchpad or obviously represents your touchpad, then that means there is a touchpad driver installed. Right click on it, and click update driver software. Make sure that you are connected to the internet before you go any farther. Then click Search automatically for updated driver software. Follow the wizard to finish installing any updated (if any) drivers. If none of this works, use an external mouse (wired or wireless), because it sounds like your mouse pad is broken. If an external mouse doesn't work, it sounds like you may need to get a new computer.
May 08, 2011 | Samsung N150 Netbook
I have a toshiba laptop the mousepad won't move.
First connect a mouse to your laptop. Click "Start" and open the control panel, click printers and other hardware and then click "mouse". Under mouse properties, click the "device settings" tab. Under the device window, you can see if the touchpad is enabled or not. If it is not enabled, click on the enable button.then click "apply" of "ok" button. Your touchpad should be working again.
Sep 07, 2010 | Computers & Internet
ACER 5315-2326
Disconnect it and connect again.
Oct 27, 2008 | Acer Aspire 5315 Notebook
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Impression Products Impression M1 Wireless Internet Keyboard/Mouse Logo
1,244 people viewed this question
Top Impression Products Computers & Internet Experts
Rocketmanusa
Level 1 Expert
Perry Ralston
Level 1 Expert
Julie Simmons
Julie Simmons
Level 1 Expert
Are you an Impression Products Computer and Internet Expert? Answer questions, earn points and help others
