Question about Yamaha AX-396 Amplifier
I have a yamaha AX396 amp. . I want to connect my DENON POA2200 power amp. . .How to do it??
    Genius:
  • 1,175 Answers
Does this model (yamaha) have "pre-out" connectors on the back panel?
If so, use those to go to the Denon
Posted on Sep 01, 2010
SOURCE:
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
Power amp 2 channel connection to Denon a/v amp
You don't mention which AR amp we're talking about.
I think you're trying to say you want to know where to extract the front channels from the Denon to feed the AR amp. Right?
That would be an output on the Denon to an input on the AR.
Basically, take an RCA cable pair from the Denon's Pre Out F & L and connect them to the (presumed) L & R inputs on the unnamed amp.
Set the AR amp at a reasonably high volume (if it has a volume knob) and leave it alone. Run through the speaker level adjustments on the Denon to match the Front to everything else and it will control the volume going forward.
May 28, 2010 | Denon AVR-3300 Receiver
I am trying to locate a mains transformer for a Yamaha AX396. Anyone help please? Numbers on the unit are "Bando" XU443, BO BEM WJ, WJYD53580
Have you tried contacting Yamaha itself?
Or alternativly a Yamaha service center. They might supply you with the part for a fee.
Mar 02, 2010 | Yamaha AX-396 Amplifier
Denon avr1403
disconnect all connections and cycle power once again if you have the same results the amp has an internal problem and will need to be repaired. If the amp stays on start reconnecting and cycle power after you connect each device
Jul 29, 2009 | Denon AVR-1403 Receiver
I have a denon avr amp it powers up then goes in
disconnect all connections cycle power if the power stays on reconnect equipment one at a time cycling power after each peice reconnected. If the power goes back to stand by with nothing connected the reciever needs repair
Jul 18, 2009 | Denon AVR 2808Ci Receiver
Denon AVF988 to power amp to whole house speakers
jbell302, Check both remote spkers for operation from the A spks output if good, switch B remote spks to A main connect & main A spks to the B remote connection on the Denon spks outputs . Most amp sources do not like different ohm spks types & different cable or spks A-B. lenghts, because this makes up to resistances problems, making the amp to work harder & understanding what is going on. THE AMPS PROTECTION CIRCUIT IS AT ALERT & TRIES TO BALANCE THE RESISTANCE VOLUME. Best move is to try use the same spks. lenght & a higher qauge wire; 12.14.18qa. to better balance the output volume! All matching spks. pairs would help alot as well!
Feb 04, 2009 | Denon AVR-3805 Receiver
No sound from a yamaha AV receiver preouts connected to ext in
Do not use the ext in plug into the aux, or video input of the denon
Jan 28, 2009 | Denon AVR-3300 Receiver
What kind of amplifier and other accessories are recommended for bose 901 speakers
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
Dec 22, 2008 | Bose 901 VI Main / Stereo Speaker
Power Button Flashing Red
Check to make sure the +/- speaker output wires aren't touching. I've had this problem before with frayed speaker wire strands poking out & intermittently shorting to the other polarity speaker output. This amazing receiver actually continued to play at low volume levels, but if I turned it up it would shut down similar to how you are reporting. I cleaned up the frayed wires & this fixed thr problem. Good luck
Mar 02, 2008 | Denon AVR-2105 Receiver
Yamaha AX-396 Amplifier Logo
226 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
